代码如下:
- #include <dht11.h>
- dht11 DHT11;
- #define DHT11PIN 2
- void setup(){
- Serial.begin(9600);
- void loop(){
- Serial.println("\n");
- int chk = DHT11.read(DHT11PIN);
- Serial.print("Read sensor: ");
- switch (chk)
- case DHTLIB_OK:
- Serial.println("OK");
- break;
- case DHTLIB_ERROR_CHECKSUM:
- Serial.println("Checksum error");
- break;
- case DHTLIB_ERROR_TIMEOUT:
- Serial.println("Time out error");
- break;
- default:
- Serial.println("Unknown error");
- break;
- Serial.print("Humidity (%): ");
- Serial.println((float)DHT11.humidity, 2);
- Serial.print("Temperature (oC): ");
- Serial.println((float)DHT11.temperature, 2);
- delay(2000);
复制代码 注:压缩包有dht11.h文件
Arduino 328 DHT11.rar
(76.26 KB, 下载次数: 109)
