此程序是一个开发板(51单片机的12684显示)的教程程序,void DisplayCGRAM(unsigned char x,unsigned char y)这个函数是如何对void CGRAM()函数进行显示的,Display是一个关键字吗?还有Write_Data(00);这条语句的作用是什么?如何去理解?
求大神解答,谢谢。
- 名称:st7920字库液晶显示
- 修改:无
- 内容:通过显示字符、数字、汉字和图片测试液晶基本功能
- #include <reg52.h>
- #include <intrins.h>
- #include "delay.h"
- sbit RS = P2^4;
- sbit RW = P2^5;
- sbit E = P2^6;
- sbit RES = P2^3;
- sbit PSB = P2^1;
- sbit PAUSE = P3^0;
- #define DataPort P0 //MCU P0<------> LCM
- unsigned char code user16x16[]={ //笑脸图片
- 0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
- 0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
- unsigned char code pic1[]= // 图片代码
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
- 0xC0,0x1F,0xFF,0x81,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
- 0xC0,0x18,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x08,0x00,0x00,0x00,0x03,
- 0xC0,0x1F,0xFF,0x80,0x00,0x00,0x04,0x07,0x81,0xE0,0x10,0x10,0x03,0xC0,0x30,0x03,
- 0xC0,0x1F,0xFF,0x80,0x00,0x00,0x0C,0x0C,0xC3,0x30,0x08,0x20,0x0C,0xE0,0x70,0x03,
- 0xC0,0x18,0x01,0x87,0xFF,0xFE,0x3C,0x18,0x66,0x18,0x04,0x40,0x0C,0x60,0x70,0x03,
- 0xC0,0x1F,0xFF,0x87,0xFF,0xFE,0x0C,0x18,0x66,0x18,0x02,0x80,0x18,0x00,0xB0,0x03,
- 0xC0,0x1F,0xFF,0x80,0x06,0x00,0x0C,0x18,0x66,0x18,0x01,0x00,0x1B,0x81,0x30,0x03,
- 0xC0,0x01,0x98,0x00,0x06,0x00,0x0C,0x00,0xE3,0x30,0x02,0x80,0x1C,0xC1,0x30,0x03,
- 0xC0,0x19,0x99,0x80,0x66,0x60,0x0C,0x00,0xC1,0xE0,0x04,0x40,0x18,0x62,0x30,0x03,
- 0xC0,0x19,0x99,0x80,0x66,0x30,0x0C,0x01,0x83,0x30,0x08,0x20,0x18,0x66,0x30,0x03,
- 0xC0,0x0D,0x9B,0x00,0xC6,0x38,0x0C,0x03,0x06,0x18,0x10,0x10,0x18,0x67,0xFC,0x03,
- 0xC0,0x0D,0x9B,0x01,0xC6,0x1C,0x0C,0x06,0x06,0x18,0x20,0x08,0x18,0x60,0x30,0x03,
- 0xC0,0x01,0x98,0x03,0x86,0x0C,0x0C,0x0C,0x06,0x18,0x00,0x00,0x08,0x60,0x30,0x03,
- 0xC0,0x7F,0xFF,0xE3,0x06,0x00,0x0C,0x18,0x03,0x30,0x00,0x00,0x0C,0xC0,0x30,0x03,
- 0xC0,0x7F,0xFF,0xE0,0x1E,0x00,0x0C,0x1F,0xE1,0xE0,0x00,0x00,0x07,0x80,0x30,0x03,
- 0xC0,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
- 0xC0,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x18,0x00,0x00,0x00,0x06,0x0C,0x03,
- 0xC3,0xFF,0xFC,0x3F,0xF0,0x80,0x0C,0x00,0x3F,0x18,0x01,0xFF,0xFE,0x06,0x0C,0x03,
- 0xC3,0xFF,0xFC,0x3F,0xF1,0x80,0x0F,0xFC,0x3F,0x18,0x01,0xFF,0xFE,0x06,0x0C,0x03,
- 0xC3,0x0C,0x0C,0x0C,0xC3,0x00,0x0F,0xFC,0x33,0x7F,0xE1,0x86,0x06,0x06,0x0C,0x03,
- 0xC3,0x1F,0xCC,0x0C,0xC6,0x00,0x0C,0x00,0x33,0x7F,0xE1,0x8F,0xE6,0x06,0x0C,0x03,
- 0xC3,0x3F,0xCC,0x0C,0xCC,0x00,0x0C,0x00,0x36,0x30,0x01,0x9F,0xE6,0x07,0xFF,0xE3,
- 0xC3,0x79,0x8C,0x0C,0xC8,0x00,0xFF,0xF0,0x36,0x36,0x01,0xBC,0xC6,0x07,0xFF,0xE3,
- 0xC3,0x6F,0x0C,0x7F,0xF0,0xC0,0xFF,0xF0,0x36,0x66,0x01,0xB7,0x86,0x06,0x00,0x03,
- 0xC3,0x0F,0x0C,0x7F,0xF1,0x80,0xC0,0x30,0x36,0x7F,0xC1,0x87,0x86,0x06,0x00,0x03,
- 0xC3,0x79,0xEC,0x0C,0xC3,0x00,0xC0,0x30,0x33,0x7F,0xC1,0xBC,0xF6,0x06,0x00,0x03,
- 0xC3,0x76,0xEC,0x0C,0xC6,0x00,0xC0,0x30,0x33,0x06,0x01,0xBB,0x76,0x07,0xFF,0x03,
- 0xC3,0x07,0x0C,0x0C,0xCC,0x20,0xFF,0xF0,0x33,0x06,0x01,0x83,0x86,0x07,0xFF,0x03,
- 0xC3,0x03,0x0C,0x18,0xC8,0x60,0xFF,0xF0,0x3F,0x06,0x01,0x81,0x86,0x06,0x03,0x03,
- 0xC3,0x1C,0x0C,0x18,0xC0,0xC0,0x00,0x00,0x3E,0xFF,0xE1,0x8E,0x06,0x06,0x03,0x03,
- 0xC3,0x1F,0x0C,0x18,0xC1,0x81,0xB1,0x8C,0x30,0xFF,0xE1,0x8F,0x86,0x06,0x03,0x03,
- 0xC3,0x03,0x0C,0x30,0xC7,0x01,0xB1,0x8C,0x30,0x06,0x01,0x81,0x86,0x0C,0x03,0x03,
- 0xC3,0xFF,0xFC,0x70,0xDE,0x03,0x18,0xC6,0x30,0x06,0x01,0xFF,0xFE,0x0C,0x03,0x03,
- 0xC3,0xFF,0xFC,0x20,0x18,0x03,0x18,0xC6,0x30,0x06,0x01,0xFF,0xFE,0x18,0x03,0x03,
- 检测忙位
- void Check_Busy()
- RS=0;
- RW=1;
- E=1;
- DataPort=0xff;
- while((DataPort&0x80)==0x80);//忙则等待
- E=0;
- 写命令
- void Write_Cmd(unsigned char Cmd)
- Check_Busy();
- RS=0;
- RW=0;
- E=1;
- DataPort=Cmd;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 写数据
- void Write_Data(unsigned char Data)
- Check_Busy();
- RS=1;
- RW=0;
- E=1;
- DataPort=Data;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 液晶屏初始化
- void Init_ST7920()
- DelayMs(40); //大于40MS的延时程序
- PSB=1; //设置为8BIT并口工作模式
- DelayMs(1); //延时
- RES=0; //复位
- DelayMs(1); //延时
- RES=1; //复位置高
- DelayMs(10);
- Write_Cmd(0x30); //选择基本指令集
- DelayUs2x(50); //延时大于100us
- Write_Cmd(0x30); //选择8bit数据流
- DelayUs2x(20); //延时大于37us
- Write_Cmd(0x0c); //开显示(无游标、不反白)
- Write_Cmd(0x01); //清除显示,并且设定地址指针为00H
- DelayMs(15); //延时大于10ms
- Write_Cmd(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
- 用户自定义字符
- void CGRAM()
- int i;
- Write_Cmd(0x30);
- Write_Cmd(0x40);
- for(i=0;i<16;i++)
- Write_Data(user16x16[i*2]);
- Write_Data(user16x16[i*2+1]);
- 显示用户自定义字符
- void DisplayCGRAM(unsigned char x,unsigned char y)
- switch(y)
- case 1: Write_Cmd(0x80+x);break;
- case 2: Write_Cmd(0x90+x);break;
- case 3: Write_Cmd(0x88+x);break;
- case 4: Write_Cmd(0x98+x);break;
- default:break;
- Write_Data(00);
- Write_Data(00);
- 显示字符串
- x:横坐标值,范围0~8
- y:纵坐标值,范围1~4
- void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
- switch(y)
- default:break;
- while(*s>0)
- Write_Data(*s);
- s++;
- DelayUs2x(50);
- 清屏
- void ClrScreen()
- Write_Cmd(0x01);
- DelayMs(15);
- 显示图片
- void LCD_PutGraphic(unsigned char code *img)
- int i,j;
- //显示上半屏内容设置
- for(i=0;i<32;i++)
- Write_Cmd(0x80 + i); //SET 垂直地址 VERTICAL ADD
- Write_Cmd(0x80); //SET 水平地址 HORIZONTAL ADD
- for(j=0;j<16;j++)
- Write_Data(*img);
- img++;
- //显示下半屏内容设置
- for(i=0;i<32;i++)
- Write_Cmd(0x88); //SET 水平地址 HORIZONTAL ADD
- for(j=0;j<16;j++)
- Write_Data(*img);
- img++;
- 设置到绘图模式
- void SetGraphicMode()
- Write_Cmd(0x36); //选择8bit数据流 图形模式
- DelayUs2x(20);
- 主程序
- main()
- unsigned char i;
- CGRAM(); //写入自定义字符
- while(1)
- Init_ST7920(); //初始化
- LCD_PutString(0,1," 单片机 ");
- LCD_PutString(0,2,"技术论坛");
- LCD_PutString(0,3,"LCD12864点阵液晶");
- LCD_PutString(0,4,"ST7920 测试程序");
- DisplayCGRAM(7,1); //在第一行第一个位置和
- DisplayCGRAM(0,1);//最后一个位置写入自定义图片笑脸
- //延时30x200ms
- for(i=0;i<30;i++)
- DelayMs(200);
- LCD_PutString(0,1," 专用技术论坛 ");
- LCD_PutString(0,2," wwwxxxx.net ");
- LCD_PutString(0,3," wwwxxxxxcom ");
- LCD_PutString(0,4," 专业成就卓越! ");
- DisplayCGRAM(0,1); //写入自定义图片笑脸
- DisplayCGRAM(0,4);
- //延时30x200ms
- for(i=0;i<30;i++)
- DelayMs(200);
- ClrScreen(); //清屏
- SetGraphicMode(); //设置成绘图模式
- LCD_PutGraphic(pic1); //调入一幅图画
- //延时20x200ms
- for(i=0;i<20;i++)
- DelayMs(200);
- ClrScreen();
