立即注册 登录
返回首页
uid:155764的个人空间
日志
串口应用实例
已有 2089 次阅读2017-11-2 18:24
#include <reg52.h>
bit flagOnceTxd = 0;  //单次发送完成标志,即发送完一个字节
bit cmdArrived = 0;  //命令到达标志,即接收到上位机下发的命令
unsigned char cntRxd = 0;
unsigned char pdata bufRxd[40]; //串口接收缓冲区
extern bit flagBuzzOn;
extern void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str);
extern void LcdAreaClear(unsigned char x, unsigned char y, unsigned char len);
void ConfigUART(unsigned int baud)  //串口配置函数,baud为波特率
    SCON = 0x50;   //配置串口为模式1
    TMOD &= 0x0F;  //清零T1的控制位
    TMOD |= 0x20;  //配置T1为模式2
    TH1 = 256 - (11059200/12/32) / baud;  //计算T1重载值
    TL1 = TH1;     //初值等于重载值
    ET1 = 0;       //禁止T1中断
    ES  = 1;       //使能串口中断
    TR1 = 1;       //启动T1
unsigned char UartRead(unsigned char *buf, unsigned char len) //串口数据读取函数,数据接收指针buf,读取数据长度len,返回值为实际读取到的数据长度
    unsigned char i;
    if (len > cntRxd) //读取长度大于接收到的数据长度时,
        len = cntRxd; //读取长度设置为实际接收到的数据长度
    for (i=0; i<len; i++) //拷贝接收到的数据
        *buf = bufRxd[ i];
        buf++;
    cntRxd = 0;  //清零接收计数器
    return len;  //返回实际读取长度
void UartWrite(unsigned char *buf, unsigned char len) //串口数据写入函数,即串口发送函数,待发送数据指针buf,数据长度len
    while (len--)
        flagOnceTxd = 0;
        SBUF = *buf;
        buf++;
        while (!flagOnceTxd);
bit CmdCompare(unsigned char *buf, const unsigned char *cmd) //命令比较函数,缓冲区数据与指定命令比较,相同返回1,不同返回0
    while (*cmd != '\0')
        if (*cmd != *buf) //遇到不相同字符时即刻返回0
            return 0;
        else //当前字符相等时,指针递增准备比较下一字符
            cmd++;
            buf++;
    return 1; //到命令字符串结束时字符都相等则返回1
void UartDriver() //串口驱动函数,检测接收到的命令并执行相应动作
    unsigned char i;
    unsigned char len;
    unsigned char buf[30];
    const unsigned char code cmd0[] = "buzz on";
    const unsigned char code cmd1[] = "buzz off";
    const unsigned char code cmd2[] = "showstr ";
    const unsigned char code *cmdList[] = {cmd0, cmd1, cmd2};
    if (cmdArrived) //有命令到达时,读取处理该命令
        cmdArrived = 0;
        for (i=0; i<sizeof(buf); i++) //清零命令接收缓冲区
            buf[ i] = 0;
        len = UartRead(buf, sizeof(buf)); //将接收到的命令读取到缓冲区中
        for (i=0; i<sizeof(cmdList)/sizeof(cmdList[0]); i++) //与所支持的命令列表逐一进行比较
            if (CmdCompare(buf, cmdList[ i]) == 1) //检测到相符命令时退出循环,此时的i值就是该命令在列表中的下标值
                break;
        switch (i) //根据比较结果执行相应命令
            case 0:
                flagBuzzOn = 1; //开启蜂鸣器
                break;
            case 1:
                flagBuzzOn = 0; //关闭蜂鸣器
                break;
            case 2:
                buf[len] = '\0'; //为接收到的字符串添加结束符
                i = sizeof(cmd2) - 1;
                LcdShowStr(0, 0, buf+i);  //显示字符串
                i = len - i;              //计算有效字符个数
                if (i < 16) //有效字符少于16时,清楚液晶上的后续字符位
                    LcdAreaClear(i, 0, 16-i);
                break;
            default:  //i大于命令列表最大下标时,即表示没有相符的命令,给上机发送“错误命令”的提示
                UartWrite("bad command.\r\n", sizeof("bad command.\r\n")-1);
                return;
        buf[len++] = '\r';  //有效命令被执行后,在原命令帧之后添加回车换行符后返回给上位机,表示已执行
        buf[len++] = '\n';
        UartWrite(buf, len);
void UartRxMonitor(unsigned char ms)  //串口接收监控函数
    static unsigned char cntbkp = 0;
    static unsigned char idletmr = 0;
    if (cntRxd > 0)  //接收计数器大于零时,监控总线空闲时间
        if (cntbkp != cntRxd)  //接收计数器改变,即刚接收到数据时,清零空闲计时
            cntbkp = cntRxd;
            idletmr = 0;
            if (idletmr < 30)  //接收计数器未改变,即总线空闲时,累积空闲时间
                idletmr += ms;
                if (idletmr >= 30)  //空闲时间超过30ms即认为一帧命令接收完毕
                    cmdArrived = 1; //设置命令到达标志
        cntbkp = 0;
void InterruptUART() interrupt 4  //UART中断服务函数
if (RI)  //接收到字节
        RI = 0;   //手动清零接收中断标志位
        if (cntRxd < sizeof(bufRxd)) //接收缓冲区尚未用完时,
            bufRxd[cntRxd++] = SBUF; //保存接收字节,并递增计数器
if (TI)  //字节发送完毕
        TI = 0;   //手动清零发送中断标志位
        flagOnceTxd = 1;  //设置单次发送完成标志
/*************************main.c文件程序源代码**************************/
#include <reg52.h>
sbit BUZZ = P1^6;  //蜂鸣器控制引脚
bit flagBuzzOn = 0;   //蜂鸣器启动标志
unsigned char T0RH = 0;  //T0重载值的高字节
unsigned char T0RL = 0;  //T0重载值的低字节
void ConfigTimer0(unsigned int ms);
extern void LcdInit();
extern void ConfigUART(unsigned int baud);
extern void UartRxMonitor(unsigned char ms);
extern void UartDriver();
void main ()
    EA = 1;           //开总中断
    ConfigTimer0(1);  //配置T0定时1ms
    ConfigUART(9600); //配置波特率为9600
    LcdInit();        //初始化液晶
        UartDriver();
void ConfigTimer0(unsigned int ms)  //T0配置函数
    unsigned long tmp;
    tmp = 11059200 / 12;      //定时器计数频率
    tmp = (tmp * ms) / 1000;  //计算所需的计数值
    tmp = 65536 - tmp;        //计算定时器重载值
    tmp = tmp + 18;           //修正中断响应延时造成的误差
    T0RH = (unsigned char)(tmp >> 8);  //定时器重载值拆分为高低字节
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0为模式1
    TH0 = T0RH;     //加载T0重载值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中断
    TR0 = 1;        //启动T0
void InterruptTimer0() interrupt 1  //T0中断服务函数
    TH0 = T0RH;  //定时器重新加载重载值
    TL0 = T0RL;
    if (flagBuzzOn)  //执行蜂鸣器鸣叫或关闭
        BUZZ = ~BUZZ;
        BUZZ = 1;
    UartRxMonitor(1);  //串口接收监控
/***********************lcd1602.c文件程序源代码*************************/
#include <reg52.h>
#define LCD1602_DB   P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
void LcdWaitReady()  //等待液晶准备好
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_E = 1;
        sta = LCD1602_DB; //读取状态字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
void LcdWriteCmd(unsigned char cmd)  //写入命令函数
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_E  = 1;
    LCD1602_DB = cmd;
    LCD1602_E  = 0;
void LcdWriteDat(unsigned char dat)  //写入数据函数
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str)  //显示字符串,屏幕起始坐标(x,y),字符串指针str
    unsigned char addr;
    //由输入的显示坐标计算显示RAM的地址
    if (y == 0)
        addr = 0x00 + x; //第一行字符地址从0x00起始
        addr = 0x40 + x; //第二行字符地址从0x40起始
    //由起始显示RAM地址连续写入字符串
    LcdWriteCmd(addr | 0x80); //写入起始地址
    while (*str != '\0')      //连续写入字符串数据,直到检测到结束符
        LcdWriteDat(*str);
        str++;
void LcdAreaClear(unsigned char x, unsigned char y, unsigned char len)  //区域清除,清除从(x,y)坐标起始的len个字符位
    unsigned char addr;
    if (y == 0)
    //由起始显示RAM地址连续写入字符串
    while (len--)             //连续写入空格
        LcdWriteDat(' ');
void LcdInit()  //液晶初始化函数
    LcdWriteCmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    LcdWriteCmd(0x0C);  //显示器开,光标关闭
    LcdWriteCmd(0x06);  //文字不动,地址自动+1
    LcdWriteCmd(0x01);  //清屏
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
