立即注册 登录
返回首页
uid:155764的个人空间
日志
检验24c02地址
已有 1175 次阅读2017-11-2 19:00
/***********************lcd1602.c文件程序源代码*************************/
#include <reg52.h>
#define LCD1602_DB   P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
void LcdWaitReady()  //等待液晶准备好
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_E = 1;
        sta = LCD1602_DB; //读取状态字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
void LcdWriteCmd(unsigned char cmd)  //写入命令函数
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
void LcdWriteDat(unsigned char dat)  //写入数据函数
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str)  //显示字符串,屏幕起始坐标(x,y),字符串指针str
    unsigned char addr;
    //由输入的显示坐标计算显示RAM的地址
    if (y == 0)
        addr = 0x00 + x; //第一行字符地址从0x00起始
        addr = 0x40 + x; //第二行字符地址从0x40起始
    //由起始显示RAM地址连续写入字符串
    LcdWriteCmd(addr | 0x80); //写入起始地址
    while (*str != '\0')      //连续写入字符串数据,直到检测到结束符
        LcdWriteDat(*str);
        str++;
void LcdInit()  //液晶初始化函数
    LcdWriteCmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    LcdWriteCmd(0x0C);  //显示器开,光标关闭
    LcdWriteCmd(0x06);  //文字不动,地址自动+1
    LcdWriteCmd(0x01);  //清屏
/*************************main.c文件程序源代码**************************/
#include <reg52.h>
#include <intrins.h>
#define I2CDelay()  {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^7;
sbit I2C_SDA = P3^6;
bit I2CAddressing(unsigned char addr);
extern void LcdInit();
extern void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str);
void main ()
    bit ack;
    unsigned char str[10];
    LcdInit();        //初始化液晶
    ack = I2CAddressing(0x50); //查询地址为0x50的器件
    str[0] = '5';              //将地址和应答值转换为字符串
    str[1] = '0';
    str[2] = ':';
    str[3] = (unsigned char)ack + '0';
    str[4] = '\0';
    LcdShowStr(0, 0, str);     //显示到液晶上
    ack = I2CAddressing(0x62); //查询地址为0x62的器件
    str[0] = '6';              //将地址和应答值转换为字符串
    str[1] = '2';
    str[2] = ':';
    str[4] = '\0';
    LcdShowStr(8, 0, str);     //显示到液晶上
void I2CStart()  //产生总线起始信号
    I2C_SDA = 1; //首先确保SDASCL都是高电平
    I2C_SCL = 1;
    I2CDelay();
    I2C_SDA = 0; //先拉低SDA
    I2CDelay();
    I2C_SCL = 0; //再拉低SCL
void I2CStop()   //产生总线停止信号
    I2C_SCL = 0; //首先确保SDASCL都是低电平
    I2C_SDA = 0;
    I2CDelay();
    I2C_SCL = 1; //先拉高SCL
    I2CDelay();
    I2C_SDA = 1; //再拉高SDA
    I2CDelay();
bit I2CWrite(unsigned char dat) //I2C总线写操作,待写入字节dat,返回值为从机应答位的值
    bit ack;  //用于暂存应答位的值
    unsigned char mask;  //用于探测字节内某一位值的掩码变量
    for (mask=0x80; mask!=0; mask>>=1) //从高位到低位依次进行
        if ((mask&dat) == 0)  //该位的值输出到SDA
            I2C_SDA = 0;
            I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;          //拉高SCL
        I2CDelay();
        I2C_SCL = 0;          //再拉低SCL,完成一个位周期
    I2C_SDA = 1;   //8位数据发送完后,主机释放SDA,以检测从机应答
    I2CDelay();
    I2CDelay();
    ack = I2C_SDA; //读取此时的SDA值,即为从机的应答值
    I2C_SCL = 0;   //再拉低SCL完成应答位,并保持住总线
    return ack;    //返回从机应答值
bit I2CAddressing(unsigned char addr) //I2C寻址函数,即检查地址为addr的器件是否存在,返回值为其应答值,即应答则表示存在,非应答则表示不存在
    bit ack;
    I2CStart();  //产生起始位,即启动一次总线操作
    ack = I2CWrite(addr<<1);  //器件地址需左移一位,因寻址命令的最低位为读写位,用于表示之后的操作是读或写
    I2CStop();   //不需进行后续读写,而直接停止本次总线操作
    return ack;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
