/*************************I2C.c文件程序源代码***************************/
#include <reg52.h>
#include <intrins.h>
#define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^7;
sbit I2C_SDA = P3^6;
void I2CStart() //产生总线起始信号
I2C_SDA = 1; //首先确保SDA、SCL都是高电平
I2C_SCL = 1;
I2CDelay();
I2C_SDA = 0; //先拉低SDA
I2CDelay();
I2C_SCL = 0; //再拉低SCL
void I2CStop() //产生总线停止信号
I2C_SCL = 0; //首先确保SDA、SCL都是低电平
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 1; //先拉高SCL
I2CDelay();
I2C_SDA = 1; //再拉高SDA
I2CDelay();
bit I2CWrite(unsigned char dat) //I2C总线写操作,待写入字节dat,返回值为应答状态
bit ack; //用于暂存应答位的值
unsigned char mask; //用于探测字节内某一位值的掩码变量
for (mask=0x80; mask!=0; mask>>=1) //从高位到低位依次进行
if ((mask&dat) == 0) //该位的值输出到SDA上
I2C_SDA = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1; //拉高SCL
I2CDelay();
I2C_SCL = 0; //再拉低SCL,完成一个位周期
I2C_SDA = 1; //8位数据发送完后,主机释放SDA,以检测从机应答
I2CDelay();
ack = I2C_SDA; //读取此时的SDA值,即为从机的应答值
I2CDelay();
I2C_SCL = 0; //再拉低SCL完成应答位,并保持住总线
return (~ack); //应答值取反以符合通常的逻辑:0=不存在或忙或写入失败,1=存在且空闲或写入成功
unsigned char I2CReadNAK() //I2C总线读操作,并发送非应答信号,返回值为读到的字节
unsigned char mask;
unsigned char dat;
I2C_SDA = 1; //首先确保主机释放SDA
I2CDelay();
if(I2C_SDA == 0) //读取SDA的值
dat &= ~mask; //为0时,dat中对应位清零
dat |= mask; //为1时,dat中对应位置1
I2CDelay();
I2C_SCL = 0; //再拉低SCL,以使从机发送出下一位
I2C_SDA = 1; //8位数据发送完后,拉高SDA,发送非应答信号
I2CDelay();
I2CDelay();
I2C_SCL = 0; //再拉低SCL完成非应答位,并保持住总线
return dat;
unsigned char I2CReadACK() //I2C总线读操作,并发送应答信号,返回值为读到的字节
unsigned char mask;
unsigned char dat;
I2CDelay();
I2CDelay();
I2C_SDA = 0; //8位数据发送完后,拉低SDA,发送应答信号
I2CDelay();
I2CDelay();
return dat;
/***********************lcd1602.c文件程序源代码*************************/
#include <reg52.h>
#define LCD1602_DB P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^5;
void LcdWaitReady() //等待液晶准备好
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_E = 1;
sta = LCD1602_DB; //读取状态字
LCD1602_E = 0;
} while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
void LcdWriteCmd(unsigned char cmd) //写入命令函数
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdWriteDat(unsigned char dat) //写入数据函数
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str) //显示字符串,屏幕起始坐标(x,y),字符串指针str
unsigned char addr;
//由输入的显示坐标计算显示RAM的地址
if (y == 0)
addr = 0x00 + x; //第一行字符地址从0x00起始
addr = 0x40 + x; //第二行字符地址从0x40起始
//由起始显示RAM地址连续写入字符串
LcdWriteCmd(addr | 0x80); //写入起始地址
while (*str != '\0') //连续写入字符串数据,直到检测到结束符
LcdWriteDat(*str);
str++;
void LcdInit() //液晶初始化函数
LcdWriteCmd(0x38); //16*2显示,5*7点阵,8位数据接口
LcdWriteCmd(0x0C); //显示器开,光标关闭
LcdWriteCmd(0x06); //文字不动,地址自动+1
LcdWriteCmd(0x01); //清屏
/************************main.c文件程序源代码**************************/
#include <reg52.h>
extern void LcdInit();
extern void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str);
extern void I2CStart();
extern void I2CStop();
extern unsigned char I2CReadACK();
extern unsigned char I2CReadNAK();
extern bit I2CWrite(unsigned char dat);
unsigned char E2ReadByte(unsigned char addr);
void E2WriteByte(unsigned char addr, unsigned char dat);
void main ()
unsigned char dat;
unsigned char str[10];
LcdInit(); //初始化液晶
dat = E2ReadByte(0x02); //读取指定地址上的一个字节
str[0] = (dat/100) + '0'; //转换为十进制字符串格式
str[1] = (dat/10%10) + '0';
str[2] = (dat%10) + '0';
str[3] = '\0';
LcdShowStr(0, 0, str); //显示在液晶上
dat++; //将其数值+1
E2WriteByte(0x02, dat); //再写回到对应的地址上
unsigned char E2ReadByte(unsigned char addr) //读取EEPROM中的一个字节,字节地址addr
unsigned char dat;
I2CStart();
I2CWrite(0x50<<1); //寻址器件,后续为写操作
I2CWrite(addr); //写入存储地址
I2CStart(); //发送重复启动信号
I2CWrite((0x50<<1)|0x01); //寻址器件,后续为读操作
dat = I2CReadNAK(); //读取一个字节数据
I2CStop();
return dat;
void E2WriteByte(unsigned char addr, unsigned char dat) //向EEPROM中写入一个字节,字节地址addr
I2CStart();
I2CWrite(dat); //写入一个字节数据
I2CStop();
