立即注册 登录
返回首页
uid:182980的个人空间
日志
好东西 收起来!
已有 484 次阅读2017-3-24 09:08
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0
* Date               : 05/23/2008
* DescriptWHY8W-QT9DJ-P0VNX-L15PE-W4DCR-VP3FMion        : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* FOR MORE INFORMATION PLEASE CAREFULLY READ THE LICENSE AGREEMENT FILE LOCATED
* IN THE ROOT DIRECTORY OF THIS FIRMWARE PACKAGE.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "si4432.h"
#define SI4432_CSH()  GPIO_SetBits(GPIOB, GPIO_Pin_12) //P3OUT |= BIT0//  PB12
#define SI4432_CSL()  GPIO_ResetBits(GPIOB, GPIO_Pin_12) //P3OUT &= ~BIT0//
#define SI4432_SDNH() GPIO_SetBits(GPIOB, GPIO_Pin_1) //P3OUT |= BIT4//PB1
#define SI4432_SDNL() GPIO_ResetBits(GPIOB, GPIO_Pin_1) //P3OUT &= ~BIT4
#define SI4432_IRQ()  GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0) //(P2IN & BIT7)  //PB0
static u8 Spi0Write(u8 byte);
void GPIO_Config(void);
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
#define code const
#define uint8 unsigned char
#define BAND_434
//#define BAND_868
//#define BAND_915
// RF specific definitions
#ifdef  BAND_434
   #define FW_VERSION "1.0 434MHz"
   //define the default radio frequency
   #define FREQ_BAND_SELECT 0x53 //frequency band select
   #define NOMINAL_CAR_FREQ1 0x53 //default carrier frequency
   #define NOMINAL_CAR_FREQ2 0x40
#endif
#ifdef  BAND_868
   #define FW_VERSION "1.0 868MHz"
   //define the default radio ferquency
   #define FREQ_BAND_SELECT 0x73 //frequency band select
   #define NOMINAL_CAR_FREQ1 0x2C //default carrier frequency
   #define NOMINAL_CAR_FREQ2 0x60
#endif
#ifdef  BAND_915
   #define FW_VERSION "1.0 915MHz"
   #define FREQ_BAND_SELECT 0x75 //frequency band select
   #define NOMINAL_CAR_FREQ1 0x0A //default carrier frequency
   #define NOMINAL_CAR_FREQ2 0x80
#endif
/* GLOBAL variables  */
const unsigned char RMRfSettings[NMBR_OF_SAMPLE_SETTING1][NMBR_OF_PARAMETER] =
//revV2
// IFBW, COSR, CRO2, CRO1, CRO0, CTG1, CTG0, TDR1, TDR0, MMC1, FDEV, B_TIME
{0x01, 0x83, 0xc0, 0x13, 0xa9, 0x00, 0x05, 0x13, 0xa9, 0x20, 0x3a },   //DR: 2.4kbps, DEV: +-36kHz, BBBW: 75.2kHz
{0x04, 0x41, 0x60, 0x27, 0x52, 0x00, 0x0a, 0x27, 0x52, 0x20, 0x48 }, //DR: 4.8kbps, DEV: +-45kHz, BBBW: 95.3kHz
{0x91, 0x71, 0x40, 0x34, 0x6e, 0x00, 0x18, 0x4e, 0xa5, 0x20, 0x48 }, //DR: 9.6kbps, DEV: +-45kHz, BBBW: 112.8kHz
{0x26, 0x34, 0x02, 0x75, 0x25, 0x07, 0xFF, 0x9D, 0x49, 0x20, 0x15 }, //DR: 19.2kbps, DEV: +-9.6kHz, BBBW: 28.8kHz
{0x16, 0x34, 0x02, 0x75, 0x25, 0x07, 0xFF, 0x09, 0xD5, 0x00, 0x1F }, //DR: 38.4kbps, DEV: +-19.2kHz, BBBW: 57.6kHz
{0x03, 0x45, 0x01, 0xD7, 0xDC, 0x07, 0x6E, 0x0E, 0xBF, 0x00, 0x2E }, //DR: 57.6kbps, DEV: +-28.8kHz, BBBW: 86.4kHz
{0x99, 0x34, 0x02, 0x75, 0x25, 0x07, 0xFF, 0x1D, 0x7E, 0x00, 0x5C }, //DR: 115.2kbps, DEV: +-57.6kHz, BBBW: 172.8kHz
const unsigned char CMRfSettings[NMBR_OF_SAMPLE_SETTING2][NMBR_OF_PARAMETER] =
//revV2
{0x8F, 0xE5, 0x80, 0x1A, 0x28, 0x00, 0x08, 0x4e, 0x79, 0x20, 0x90 }, //DR: 9.6kbps, DEV: +-90kHz, BBBW:184.8kHz
#ifdef BAND_434
//parameters of the frequency setting
const uint8 FreqSettings[4][7] =
// 2.4kbps, 4.8kbps, 9.6kbps, 19.2kbps, 38.4kbps 57.6kbps 115.2kbps
{4, 4, 4, 3, 3, 2, 1  },   //max channel number
{0x53, 0x53, 0x53, 0x58, 0x56, 0x5A, 0x61  }, //start freq. reg1
{0x40, 0x40, 0x40, 0x40, 0xC0, 0x40, 0xC0  }, //start freq. reg2
{33, 33, 33, 39, 45, 36, 0  }, //freq. step
#endif
#ifdef BAND_868
code uint8 FreqSettings[4][7] =
{14, 14, 14, 11, 10, 8, 6    },   //max channel number
{0x2C, 0x2C, 0x2C, 0x2E, 0x2D, 0x2E, 0x32 }, //start freq. reg1
{0x60, 0x60, 0x60, 0x40, 0x40, 0xE0, 0x00 }, //start freq. reg2
{45, 45, 45, 55, 64, 78, 100  }, //freq. step
#endif
#ifdef BAND_915
{60, 60, 60, 52, 45, 37, 29 },   //max channel number
{0x0A, 0x0A, 0x0A, 0x0A, 0x0A, 0x0A, 0x0A }, //start freq. reg1
{0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80 }, //start freq. reg2
{48, 48, 48, 55, 64, 78, 100  }, //freq. step
#endif
unsigned char rf_ch;
unsigned char rf_pwr;
unsigned char rf_dr;
//RF_SAMPLE_SETTINGS rf_dr;
unsigned char mode = 0;   //普通模式
void delay_ms(unsigned int delay)
unsigned int  j;
unsigned short i;
if( delay == 0 )
return;
for(j=0;j<delay;j++)
for(i=0;i<2000;i++);
void  Delay(u32 nCount)
  for(; nCount != 0; nCount--);
void InitSPI2()
SPI_InitTypeDef SPI_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
SPI_Cmd(SPI2, DISABLE);             //必须先禁能,才能改变MODE
    SPI_InitStructure.SPI_Direction =SPI_Direction_2Lines_FullDuplex;  //两线全双工
    SPI_InitStructure.SPI_Mode =SPI_Mode_Master;       //主
    SPI_InitStructure.SPI_DataSize =SPI_DataSize_8b;       //8位
    SPI_InitStructure.SPI_CPOL =SPI_CPOL_High;         //CPOL=1时钟悬空高
    SPI_InitStructure.SPI_CPHA =SPI_CPHA_2Edge;       //CPHA=1 数据捕获第2个
    SPI_InitStructure.SPI_NSS =SPI_NSS_Soft;         //软件NSS
    SPI_InitStructure.SPI_BaudRatePrescaler =SPI_BaudRatePrescaler_256; //256分频
    SPI_InitStructure.SPI_FirstBit =SPI_FirstBit_MSB;      //高位在前
    SPI_InitStructure.SPI_CRCPolynomial =7;         //CRC7
SPI_Init(SPI2,&SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);
//spi的配置结束了可以使用了。
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
//读写十六位数据
unsigned short SpiReadWriteWord(unsigned short spi_in)
  unsigned short temp16;
  SI4432_CSL();
  temp16 = (unsigned short) (Spi0Write( (unsigned char)((spi_in & 0xFF00) >> 8) ));
  temp16 <<= 8;
  temp16 += (unsigned short) (Spi0Write( (unsigned char)(spi_in & 0x00FF) ));
  SI4432_CSH();
  return temp16;
//写入地址和数据
void SpiWriteAddressData(unsigned char addr, unsigned char data)
  SI4432_CSL();
  Spi0Write(addr);
  Spi0Write(data);
  SI4432_CSH();
//while((SPI2->SR &SPI_I2S_FLAG_TXE)==RESET);
while((SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE))==RESET);
//SPI2->DR = byte;
SPI_I2S_SendData(SPI2,byte);
//while((SPI2->SR &SPI_I2S_FLAG_RXNE)==RESET);
while((SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE))==RESET);
//return(SPI2->DR);
return( SPI_I2S_ReceiveData(SPI2) );//读寄存器用硬件清除标志位。
//SPI_I2S_ClearFlag(SPI2,SPI_I2S_FLAG_RXNE) ;直接软件清除标志位。
//SI4432初始化
RF_ENUM RfInitHw(void)
  //Init IO
//  P3DIR |= BIT0;          //cs  PB12
//  P3DIR |= BIT4;          //SDN PB1
//  P2DIR &= ~BIT7;         //nIRQ  PB0
  SI4432_CSH();
  SI4432_SDNL();
  InitSPI2();
  SpiReadWriteWord(InterruptStatus1 << 8);
  SpiReadWriteWord(InterruptStatus2 << 8);
  //SW reset   -> wait for POR interrupt
  SpiWriteAddressData((REG_WRITE | OperatingFunctionControl1), 0x80);
  //wait for POR interrupt from the radio (while the nIRQ pin is high)
  while(SI4432_IRQ());
  //read interrupt status registers to clear the interrupt flags and release NIRQ pin
  //wait for chip ready interrupt from the radio (while the nIRQ pin is high)
  while (SI4432_IRQ());
  //disable all ITs, except 'ichiprdy'
  SpiWriteAddressData((REG_WRITE | InterruptEnable1), 0x00);
  SpiWriteAddressData((REG_WRITE | InterruptEnable2), 0x02);
  //set VCO
  SpiWriteAddressData((REG_WRITE | VCOCurrentTrimming), 0x7F);
  SpiWriteAddressData((REG_WRITE | DividerCurrentTrimming), 0xC0);
  //reset digital testbus, disable scan test
  SpiWriteAddressData((REG_WRITE | DigitalTestBus), 0x00);
  //select nothing to the Analog Testbus
  SpiWriteAddressData((REG_WRITE | AnalogTestBus), 0x0B);
  //set frequency
  SpiWriteAddressData((REG_WRITE | FrequencyBandSelect), FREQ_BAND_SELECT);
  SpiWriteAddressData((REG_WRITE | NominalCarrierFrequency1), NOMINAL_CAR_FREQ1);
  SpiWriteAddressData((REG_WRITE | NominalCarrierFrequency0), NOMINAL_CAR_FREQ2);
  //set  cap. bank rev. V2
  SpiWriteAddressData((REG_WRITE | CrystalOscillatorLoadCapacitance), 0xD7);
  //disable RX-TX headers,
  SpiWriteAddressData((REG_WRITE | HeaderControl1), 0x00 );
  SpiWriteAddressData((REG_WRITE | HeaderControl2), 0x02 );
  SpiWriteAddressData((REG_WRITE | SyncWord3), 0x2D);
  SpiWriteAddressData((REG_WRITE | SyncWord2), 0xD4);
  //set GPIO0 to GND
  SpiWriteAddressData((REG_WRITE | GPIO2Configuration), 0x14);  //接收数据
  //set GPIO1 & GPIO2 to control the TRX switch
  SpiWriteAddressData((REG_WRITE | GPIO0Configuration), 0x15);  //接收状态
  SpiWriteAddressData((REG_WRITE | GPIO1Configuration), 0x12);  //发送状态
  rf_pwr = 0x1F; //default output power
  rf_ch = 0; //default frequency channel
  set_frq(rf_ch);
  set_pwr(rf_pwr);
  if (mode == 0)
    rf_dr = 2; //default datarate 9.6 kbps
    RFSetRfParameters((RF_SAMPLE_SETTINGS)rf_dr);
    rf_dr = 0; //default datarate 9.6 kbps
  return RF_OK;
//发送数据
RF_ENUM RFTransmit(uint8 * packet, uint8 length)
  uint8 temp8;
  //set packet content
  SpiWriteAddressData((REG_WRITE | TransmitPacketLength), length);
  for(temp8=0;temp8<length;temp8++)
    SpiWriteAddressData((REG_WRITE | FIFOAccess),packet[temp8]);
  //enable transmitter
  SpiWriteAddressData((REG_WRITE | OperatingFunctionControl1), 0x09);
  //enable the wanted ITs
  SpiWriteAddressData((REG_WRITE | InterruptEnable1), 0x04);
  SpiWriteAddressData((REG_WRITE | InterruptEnable2), 0x00);
  return RF_OK;
//接收数据
RF_ENUM RFReceive(void)
  //enable receiver chain
  SpiWriteAddressData((REG_WRITE | OperatingFunctionControl1), 0x05);
  SpiWriteAddressData((REG_WRITE | InterruptEnable1), 0x03);
  return RF_OK;
RF_ENUM RFIdle(void)
SpiWriteAddressData((REG_WRITE | OperatingFunctionControl1), 0x01);
//diasble all ITs
return RF_OK;
  + FUNCTION NAME:  RF_ENUM RFPacketReceived(uint8 * packet, uint8 * length)
  + DESCRIPTION:    check wheter the packet received or not.
  + INPUT: pointers for storing data and length
  + RETURN:         RF_PACKET_RECEIVED: packet received
  + RF_NO_PACKET: packet is not yet received
  + NOTES:
uint8 i;
if(SI4432_IRQ() == 0)
i = (uint8)(0x00FF & SpiReadWriteWord(InterruptStatus1 << 8));
if( (i & 0x01) == 0x01 )
{//CRC error
//disable receiver
return RF_CRC_ERROR;
if( (i & 0x02) == 0x02 )
{//packet received
//read buffer
*length =  (uint8)(0x00FF & SpiReadWriteWord(ReceivedPacketLength << 8)) ;
for(i=0;i<*length;i++)
*packet++ = (uint8)(0x00FF & SpiReadWriteWord(FIFOAccess << 8));
//disable receiver
return RF_PACKET_RECEIVED;
return RF_NO_PACKET;
RF_ENUM RFSetRfParameters(RF_SAMPLE_SETTINGS setting)
if (mode == 0)
//set the registers according the selected RF settings in the range mode
SpiWriteAddressData((REG_WRITE | IFFilterBandwidth), RMRfSettings[setting][0] );
SpiWriteAddressData((REG_WRITE | ClockRecoveryOversamplingRatio), RMRfSettings[setting][1]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset2), RMRfSettings[setting][2]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset1), RMRfSettings[setting][3]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset0), RMRfSettings[setting][4]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryTimingLoopGain1), RMRfSettings[setting][5]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryTimingLoopGain0), RMRfSettings[setting][6]);
SpiWriteAddressData((REG_WRITE | TXDataRate1), RMRfSettings[setting][7]);
SpiWriteAddressData((REG_WRITE | TXDataRate0), RMRfSettings[setting][8]);
SpiWriteAddressData((REG_WRITE | ModulationModeControl1), RMRfSettings[setting][9]);
SpiWriteAddressData((REG_WRITE | FrequencyDeviation), RMRfSettings[setting][10]);
//set the registers according the selected RF settings in the compatible mode
SpiWriteAddressData((REG_WRITE | IFFilterBandwidth), CMRfSettings[setting][0] );
SpiWriteAddressData((REG_WRITE | ClockRecoveryOversamplingRatio), CMRfSettings[setting][1]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset2), CMRfSettings[setting][2]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset1), CMRfSettings[setting][3]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryOffset0), CMRfSettings[setting][4]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryTimingLoopGain1), CMRfSettings[setting][5]);
SpiWriteAddressData((REG_WRITE | ClockRecoveryTimingLoopGain0), CMRfSettings[setting][6]);
SpiWriteAddressData((REG_WRITE | TXDataRate1), CMRfSettings[setting][7]);
SpiWriteAddressData((REG_WRITE | TXDataRate0), CMRfSettings[setting][8]);
SpiWriteAddressData((REG_WRITE | ModulationModeControl1), CMRfSettings[setting][9]);
SpiWriteAddressData((REG_WRITE | FrequencyDeviation), CMRfSettings[setting][10]);
//enable packet handler & CRC16
SpiWriteAddressData((REG_WRITE | DataAccessControl), 0x8D);
SpiWriteAddressData((REG_WRITE | ModulationModeControl2), 0x63);
//set preamble length & detection threshold
SpiWriteAddressData((REG_WRITE | PreambleLength), (PREAMBLE_LENGTH << 1));
SpiWriteAddressData((REG_WRITE | PreambleDetectionControl), ( PD_LENGTH << 4) );
SpiWriteAddressData((REG_WRITE | ClockRecoveryGearshiftOverride), 0x03);
SpiWriteAddressData((REG_WRITE | AFCLoopGearshiftOverride), 0x40);
return RF_OK;
RF_ENUM set_frq(uint8 frq)
  //set frequency
  SpiWriteAddressData((REG_WRITE | NominalCarrierFrequency1), FreqSettings[1][rf_dr] );
  SpiWriteAddressData((REG_WRITE | NominalCarrierFrequency0), FreqSettings[2][rf_dr] );
  SpiWriteAddressData((REG_WRITE | FrequencyHoppingStepSize), FreqSettings[3][rf_dr] );
  SpiWriteAddressData((REG_WRITE | FrequencyHoppingChannelSelect), frq);
  delay_ms(100);//wait a bit
  return RF_OK;
RF_ENUM set_pwr(uint8 pwr)
  SpiWriteAddressData((REG_WRITE | TXPower), pwr);
  delay_ms(100); //wait a bit
  return RF_OK;
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |
  RCC_APB2Periph_GPIOB |
RCC_APB2Periph_GPIOC |
                         RCC_APB2Periph_GPIOD |
RCC_APB2Periph_GPIOE |
RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); //JTAG禁用但SW-DP使能
GPIO_DeInit(GPIOB);
LED1 -> PB8 , LED2 -> PB9 , LED3 -> PE0 , LED4 -> PE1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_15|GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/*GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
GPIO_Init(GPIOB, &GPIO_InitStructure); */
#include <string.h>
#include <stdio.h>
int main(void)
char buf[100];
SystemInit();
GPIO_Config();
RfInitHw();
sprintf(buf,"%s","yufujian\n");
    while (1)
// RfInitHw();
RFTransmit((unsigned char*)buf,strlen(buf));
// delay_ms(1000);
// Spi0Write(0x81);
// delay_ms(1);
return 0;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
