立即注册 登录
返回首页
uid:265598的个人空间
日志
超声波测距LCD1602显示
已有 1108 次阅读2018-12-2 19:57 |个人分类:程序
SMC1602A(16*2)模拟口线接线方式
连接线图:
       |LCM-----51   | LCM-----51   | LCM------51      |
       |DB0-----P1.0 | DB4-----P1.4 | RW-------P3.4    |
       |DB1-----P1.1 | DB5-----P1.5 | RS-------P3.3    |
       |DB2-----P1.2 | DB6-----P1.6 | E--------P3.5    |
       |DB3-----P1.3 | DB7-----P1.7 | VLCD接1K电阻到GND|
接线:模块TRIG接 P3.7  ECH0 接P3.6
[注:stc89c52使用12M或11.0592M晶振,实测使用11.0592M]
#include <AT89x51.H>
//#include<12C5A60S2.H>
//器件配置文件
#include <intrins.h>
#define  RX  P3_6
#define  TX  P3_7
#define LCM_RW  P2_5 //定义LCD引脚
#define LCM_RS  P2_6
#define LCM_E   P2_7
#define LCM_Data  P0
#define Key_Data P3_3 //定义Keyboard引脚
#define Key_CLK  P3_2
#define Busy    0x80 //用于检测LCM状态字中的Busy标识
void delay21us(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void delay_50us(unsigned int t);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={"==Range Finder=="};
unsigned char code email[] =    {"heyaodz@163.com "};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //显示用指针
       unsigned int  time=0;
   unsigned long S=0;
   bit      flag =0;
   unsigned char disbuff[4]    ={ 0,0,0,0,};
//写数据
ReadStatusLCM(); //检测忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在这后加小的延时
LCM_E = 0; //延时
LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCM(); //根据需要检测忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//读数据
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//读状态
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //检测忙信号
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
    delay_50us(1000);
    delay_50us(1000);
    delay_50us(1000);
WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCM(0x08,1); //关闭显示
WriteCommandLCM(0x01,1); //显示清屏
WriteCommandLCM(0x06,1); // 显示光标移动设置
WriteCommandLCM(0x0F,1); // 显示开及光标设置
          //按指定位置显示一个字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; //算出指令码
WriteCommandLCM(X, 1); //发命令字
WriteDataLCM(DData); //发数据
//按指定位置显示一串字符
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到达字串尾则退出
if (X <= 0xF) //X坐标应小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
ListLength++;
X++;
unsigned char j;
for(;t>0;t--)
for(j=19;j>0;j--);
    void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.8)/10;     //算出来是MM
if((S>=7000)||flag==1) //超出测量范围显示“-”
  flag=0;
  DisplayOneChar(0, 1, ASCII[11]);
  DisplayOneChar(1, 1, ASCII[10]); //显示点
  DisplayOneChar(2, 1, ASCII[11]);
  DisplayOneChar(3, 1, ASCII[11]);
  DisplayOneChar(4, 1, ASCII[11]);
  DisplayOneChar(5, 1, ASCII[12]); //显示M
  disbuff[0]=S/1000;
  disbuff[1]=S/100%10;
  disbuff[2]=S/10%10;
  disbuff[3]=S%10;
  DisplayOneChar(0, 1, ASCII[disbuff[0]]);
  DisplayOneChar(2, 1, ASCII[disbuff[1]]);
  DisplayOneChar(3, 1, ASCII[disbuff[2]]);
  DisplayOneChar(4, 1, ASCII[disbuff[3]]);
     void zd0() interrupt 1 //T0中断用来计数器溢出,超过测距范围
    flag=1; //中断溢出标志
RX=0;
     void  StartModule()          //启动模块
  TX=1;
 delay21us();                       //启动一次模块
  TX=0;
void Timer_Count(void)
TR0=1;     //开启计数
     while(RX); //当RX为1计数并等待
     TR0=0; //关闭计数
         Conut(); //计算
void main(void)
    unsigned int valA;
unsigned char TempCyc;
    delay_50us(80000);//启动等待,等LCM讲入工作状态
LCMInit();//LCM初始化
    delay_50us(5000);
DisplayListChar(0, 0, mcustudio);
DisplayListChar(0, 1, email);
ReadDataLCM();//测试用句无意义
for (TempCyc=0; TempCyc<10; TempCyc++)
    delay_50us(80000);
DisplayListChar(0, 1, Cls);
TMOD=0x01;    //设T0为方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1;             //允许T0中断
EA=1;    //开启总中断
delay_50us(80000);
RX=1;
    StartModule();
        for(valA=7510;valA>0;valA--)
       if(RX==1)
           Timer_Count();
void delay21us(void)   //误差 -0.021990740741us
    unsigned char a,b;
    for(b=1;b>0;b--)
        for(a=55;a>0;a--);
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
