立即注册 登录
返回首页
uid:90541的个人空间
日志
51模拟串口
热度 1已有 463 次阅读2015-9-19 17:21 |个人分类:51
#include <reg51.h>
    #define uint    unsigned int
    sbit Tx_Pin = P1^1;
    sbit Rx_Pin = P1^2;         //定义接收、发送引脚
    I/O口模拟232通讯程序
    使用两种方式的C程序 占用定时器0
    #define MODE                                                    //定义工作模式,决定使用哪种算法
    #define Flg F0                                              //标志位,使用PSW的F0位
    #define Start_Timer0 TL0=TH0;TR0=1;     //定时计数器0的启动处理
    #define Close_Timer0 TR0=0;                     //定时计数器0的关闭处理
    sbit ACC0 = ACC^0;
    sbit ACC1 = ACC^1;
    sbit ACC2 = ACC^2;
    sbit ACC3 = ACC^3;
    sbit ACC4 = ACC^4;
    sbit ACC5 = ACC^5;
    sbit ACC6 = ACC^6;
    sbit ACC7 = ACC^7;
    void Timer0() interrupt 1                           //定时计数器中断处理
        Flg = 1;                                                        //置位标志位
    //发送一个字符
    void SendByte(uchar adata)
        #ifdef MODE                                                 //算法一
            ACC = adata;                                                //待发送数据放入ACC
            Flg = 0;
            Tx_Pin = 0;                                             //启动位
            Start_Timer0;                                           //启动定时器
            while(!Flg)
            Tx_Pin = ACC0;                                      //先送出低位
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC1;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC2;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC3;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC4;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC5;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC6;
            Flg = 0;
            while(!Flg)
            Tx_Pin = ACC7;
            Flg = 0;
            while(!Flg)                                             //停止位
            Tx_Pin = 1;
            Flg = 0;
            while(!Flg)
            Close_Timer0;                                           //停止定时计数器
        #else                                                               //第二种算法
        uchar j;
        j = 0;
        Flg = 0;                                                        //初始化
        Tx_Pin = 0;                                                 //起始位
        Start_Timer0;                                               //启动定时计数器
        while(!Flg)
        while(j<8)                                                   //如果没有发送完一个字节
            if(adata&1)                                             //如果待发送位是1
                Tx_Pin = 1;
            else                                                            //如果待发送位是0
                Tx_Pin = 0;
            Flg = 0;
            while(!Flg)
            j++;
            adata>>=1;                                                    //移位
        Tx_Pin = 1;
        Flg = 0;
        while(!Flg)                                                 //停止发送
        #endif
    //接收一个字符
    uchar RecByte()
        #ifdef MODE                                                 //算法一
        Start_Timer0;
        Flg = 0;
        while(!Flg)                                                 //等待起始位
        ACC0 = Rx_Pin;                                          //接收一位数据
        TL0 = TH0;
        Flg = 0;
        while(!Flg)
        ACC1 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC2 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC3 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC4 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC5 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC6 = Rx_Pin;
        Flg = 0;
        while(!Flg)
        ACC7 = Rx_Pin;
        Flg = 0;
        while(!Flg)                                                 //等待停止位
            if(Rx_Pin)
                break;
        Close_Timer0;                                               //停止timer
        return ACC;                                                 //函数返回值通过ACC寄存器传递
        #else                                                               //第二种算法
        uchar Rx_Data, j;
        Start_Timer0;
        Flg = 0;
        j = 0;
        Rx_Data = 0;                                                //等待起始位
        while(!Flg)
        while(j<8)
            Rx_Data>>=1;
            if(Rx_Pin)
                Rx_Data |= 0x80;                                //判断引脚电平
            j++;
            Flg = 0;
            while(!Flg)
        Flg = 0;
        while(!Flg)
            if(Rx_Pin)
                break;
        return Rx_Data;
        #endif
    //检查是不是起始位
    bit CheckStartBit()
        return (Rx_Pin == 0);                               //返回引脚状态
        uchar temp;
        TMOD = 0x02;                                                //定时器0 模式2 8位重装
        PCON = 0x00;
        TR0 = 0;                                                            //在发送或接收才开始使用
        TH0 = (256.96);
        //9600bps 就是1000000/9600=104.167us 执行时间即是104.167*10.0592/12=96
        TL0 = TH0;
        ET0 = 1;
        EA = 1;
        SendByte(0x55);
        SendByte(0xaa);
        SendByte(0x00);
        SendByte(0xff);                                         //发送数据
            if(CheckStartBit())                             //如果检测到起始位
                temp = RecByte();                               //接收数据
                SendByte(temp);                                 //发送数据
1
路过
鸡蛋
鲜花
握手
雷人
刚表态过的朋友 (1 人)
评论 (0 个评论)
返回顶部
