查看: 1596|回复: 3
矩阵键盘 控制数码管秒表的问题
ID:253035 发表于 2017-11-30 21:35 | 显示全部楼层 |阅读模式
各位大侠帮忙看一下问题出在那儿,秒表开始后按了设定了好的按键不会停止,想实现的功能是按下key2=5的按键开始,再按下停止以此循环查了一下似乎if(key2==5)下面的语句进不去TR0一直都是1,按键编码检查了没有问题,还望指点迷津
#include <reg52.h>
#include<intrins.h>
#define uint  unsigned int
sbit wei=P2^6;
sbit duan=P2^7;
uchar code table_tube[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code a[]={0xFE,0xFD,0xFB,0xF7};
uint xms,temp,key1,key2;
uchar num,bai,shi,ge,tt0;
void delay(uint);
void display(uchar,uchar,uchar);
void init();
uchar keynum();
uchar coding(uchar);
        init();
                key1=keynum();
                key2=coding(key1);
                if(key2==5)
                        key2=0;
                        TR0=~TR0;
void init()
        TMOD=0x11;
        TH0=(65535-10000)/256;
        TL0=(65535-10000)%256;
        TH1=(65535-1000)/256;
        TL1=(65535-1000)%256;
        EA=1;ET0=1;TR0=1;
        ET1=1;TR1=1;
        P1=0xff;
        wei=1;
        P0=0xf8;
        wei=0;
        duan=1;
        P0=table_tube[0];
        duan=0;
void display(uchar bai,uchar shi,uchar ge)
        wei=1;
        P0=0xfe;
        wei=0;
        duan=1;
        P0=table_tube[bai]+0x80;
        duan=0;
        delay(1);
        wei=1;
        P0=0xfd;
        wei=0;
        duan=1;
        P0=table_tube[shi];
        duan=0;
        delay(1);
        wei=1;
        P0=0xfb;
        wei=0;
        duan=1;
        P0=table_tube[ge];
        duan=0;
        delay(1);
uchar coding(uchar m)
  uchar k;
        switch(m)
                case (0xee): k=0;break;
                case (0xde): k=1;break;
                case (0xbe): k=2;break;
                case (0x7e): k=3;break;
                case (0xed): k=4;break;
                case (0xdd): k=5;break;
                case (0xbd): k=6;break;
                case (0x7d): k=7;break;
                case (0xeb): k=8;break;
                case (0xdb): k=9;break;
                case (0xbb): k=10;break;
                case (0x7b): k=11;break;
                case (0xe7): k=12;break;
                case (0xd7): k=13;break;
                case (0xb7): k=14;break;
                case (0x77): k=15;break;
        return k;
uchar keynum()
  uchar i,k;
        P1=0xf0;            //¿éòÔÖ±½óìá衸ßËÄλ±è½Ï£¬èôÎT¼ü°′Ï£¬¸ßËÄλ±Ø¶¨êÇ1111£¬±è½ÏP1&0xf0oí0xf0êÇ·ñÏàí¬¼′¿é
        if((P1&0xf0)!=0xf0)
          delay(5);
                if((P1&0xf0)!=0xf0)
                        i=0;
                  P1=a[i];
                        while(i<4)
                                if((P1&0xf0)!=0xf0)      //¿éòÔÖ±½óìá衸ßËÄ룬±è½ÏP1&0xf0oí0xf0
                                        k=P1;
                                        break;
                                        i++;
                                        P1=a[i];
                //        while((P1&0xf0)!=0xf0);
                        return k;
        return 0;
void delay(uint xms)
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
void timer0()interrupt 1
        temp++;
        if(temp==1000)
                temp=0;
        bai=temp/100;
        shi=temp%100/10;
        ge=temp%100%10;
void timer1()interrupt 3
display(bai,shi,ge);
ID:255904 发表于 2017-11-30 21:45 | 显示全部楼层
按键检测的时候是不是加点延时
ID:255904 发表于 2017-11-30 21:46 | 显示全部楼层
按键检测的时候是不是加点延时
ID:194367 发表于 2017-11-30 22:08 | 显示全部楼层
应该不是延时的问题吧
