查看: 2609|回复: 0
超声波测距显示并避障的单片机程序
ID:194367 发表于 2017-11-30 22:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
超声波测距显示和避障
  1. #include <reg52.h>
  2. #define        uchar unsigned char
  3. #define uint unsigned int
  4. sbit K1=P1^0;          //P1.0到P1.4为寻线检测端
  5. sbit K2=P1^1;
  6. sbit K3=P1^2;
  7. sbit K4=P1^3;
  8. sbit K5=P1^4;
  9. sbit KIN1=P1^5;           //P1.5 P1.6是避障检测端
  10. sbit KIN2=P1^6;
  11. sbit out1 = P2^0  ;           //P2.0到P2.3是电机驱动输出控制端
  12. sbit out2 = P2^1  ;
  13. sbit out3 = P2^2  ;
  14. sbit out4 = P2^3  ;
  15. sbit Trig  = P3^3; //产生脉冲引脚
  16. sbit Echo  = P3^2; //回波引脚
  17. sbit beem=  P3^7;                   //蜂鸣器控制引脚
  18. sbit PWM=P1^7; //舵机pwm//
  19. sbit SET1=P2^4        ;
  20. sbit SET2 =P2^5;
  21. sbit SET3 =P2^6;
  22. sbit SET4 =P2^7;
  23. uchar code seg7code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  24. uint distance[4];  //测距接收缓冲区
  25. uint distance1;
  26. uchar ge,shi,bai,temp,flag,outcomeH,outcomeL,PDATA;  //自定义寄存器
  27. bit succeed_flag;  //测量成功标志
  28. unsigned long xdata rec_code;
  29. unsigned long xdata time_us;
  30. unsigned char xdata rec_cnt;
  31. unsigned char xdata kbuf;
  32. uchar sdata,flag;          //sdata是红外遥控接收键值变量  flag是启动小车 或停止小车变量
  33. uint j,a;
  34. uchar pro;
  35. bit rec_b;
  36. bit key_save;
  37. bit keyp;
  38. void chaoshengbo();
  39. void conversion(uint temp_data);
  40. void delay_20us();
  41. void delay_ms(uint x);
  42. void display ();
  43. void Init()                         //初始化
  44. {
  45.     flag=0;
  46.     Trig=0;
  47.
  48.         TMOD = 0x11;        //T/C1采用16位定时器/计数器
  49.         ET1  = 1;                //定时器1开中断
  50.     ET0  = 1;
  51.         TH0 = 0x00;
  52.     TL0 = 0x00;
  53.         TH1 = 0xff;
  54.     TL1 = 0xce;
  55.         TR1=0;
  56.     TR0        = 0;
  57.                         //定时计数器启动计数
  58.         EX0         = 1;                //外部中断0关中断
  59.         PX0 = 1;
  60.         PT1 = 1;
  61.         EA         = 1;                //CPU开中断
  62. }
  63. //--------------------------------------------------
  64. //-------超声波测距----------------------------
  65. void chaoshengbo()
  66. {
  67.     uint distance_data;
  68.                  display ();
  69.                  EA=0;
  70.              Trig=1;
  71.          delay_20us();
  72.          Trig=0;         //产生一个20us的脉冲,在Trig引脚
  73.          while(Echo==0); //等待Echo回波引脚变高电平
  74.              succeed_flag=0; //清测量成功标志
  75.                  TH0=0;          //定时器1清零
  76.          TL0=0;          //定时器1清零
  77.                  EX0=1;          //打开外部中断
  78.          TR0=1;          //启动定时器1
  79.                  EA=1;
  80.                  display ();
  81.                  display ();
  82.                  display ();
  83.                  display ();
  84.                  display ();
  85.                  EX0=0;          //打开外部中断
  86.          TR0=0;
  87.                  if(succeed_flag==1)
  88.              {
  89.                    distance_data=outcomeH;                //测量结果的高8位
  90.            distance_data<<=8;                   //放入16位的高8位
  91.                      distance_data=distance_data|outcomeL;//与低8位合并成为16位结果数据
  92.            distance_data=(distance_data/25)*43/100+1;
  93.          }
  94.                          a=distance_data;          //超声波测距 距离
  95.                         distance1=a;
  96.                     display ();
  97.                         display ();         display ();
  98. }
  99. void delay_us(uint x)           //演示程序
  100. {
  101. do {
  102.      x--;
  103.    }
  104. while(x>1);
  105. }
  106. void delay_ms(uint x)
  107. {
  108. while(x!=0)
  109. {
  110. delay_us(500);
  111. x--;
  112. }
  113. }
  114. void baidong()        //舵机转动
  115. {
  116. TR1=1;
  117. pro=30;        //90°
  118. delay_ms(100);
  119.   pro=10;  //小于10°
  120. delay_ms(100);
  121. pro=50;   //大于160°
  122. delay_ms(100);
  123. pro=25;   //90°
  124. delay_ms(100);
  125. TR1=0;
  126. }
  127. void timer0() interrupt 3//定时0.1ms
  128. {
  129. EX0=0;
  130. TH1=0xff;
  131. TL1=0xce;
  132. j++;
  133. if(j<=pro)
  134. {
  135. PWM=1;
  136. }
  137. else
  138. {
  139. PWM=0;
  140. }
  141. if(j==400)   //周期20ms
  142. {
  143.    j=0;
  144.    PWM=~PWM;
  145. }
  146. }
  147. //左转
  148. void comeleft()
  149. {
  150.         out1=0;
  151.         out2=1;
  152.         out3=1;
  153.         out4=0;
  154.         delay_ms(40);
  155. }
  156. //右转
  157. void comeright ()
  158. {
  159.         out1=1;
  160.         out2=0;
  161.         out3=0;
  162.         out4=1;
  163.         delay_ms(40);
  164. }
  165. //前进加速;
  166. void comeon()
  167. {          out2=1;
  168.         delay_us(440);
  169.         out2=0;
  170.         out4=0;
  171.         out1=1;
  172.         out3=1;
  173. }
  174. //后退;
  175. void back()
  176. {          out2=1;
  177.         out4=1;
  178.         out1=0;
  179.         out3=0;
  180.         delay_ms(200);
  181. }
  182. void stop()                  //停止
  183. {
  184.                    out1=0;
  185.                 out2=0;
  186.                 out3=0;
  187.                 out4=0;
  188. }
  189. //避障
  190. void shunback()
  191. {        uint DATA1,DATA2,i;
  192.          chaoshengbo();
  193.          display ();
  194.
  195.         if(distance1<12)        //当超声波测距距离小于8则
  196.         {
  197.         stop();                //小车停止运动
  198.           beem=0;
  199.           for(i=0;i<200;i++){display ();}
  200.           beem=1;
  201.           for(i=0;i<200;i++){display ();}
  202.           beem=0 ;
  203.           for(i=0;i<200;i++){display ();}
  204.           beem=1;
  205.           EX0=0;            //关闭外部中断
  206.          TR0=0;
  207.          TR1=1;
  208.          pro=10;        //舵机转动到0°
  209.         delay_ms(50);
  210.          TR1=0;
  211.          PWM=1;
  212.          delay_ms(10);
  213.          chaoshengbo();        //检测0°方向 障碍物距离
  214.          DATA1= distance1;
  215.           for(i=0;i<200;i++){display ();}
  216.           distance1=0;
  217.           EX0=0;            //关闭外部中断
  218.          TR0=0;
  219.          TR1=1;
  220.          pro=50;        //舵机转动到180°
  221.          delay_ms(50);
  222.          TR1=0;
  223.          PWM=1;
  224.          delay_ms(10);
  225.          chaoshengbo();        //检测180°方向障碍物距离
  226.          DATA2= distance1;
  227.           for(i=0;i<200;i++){display ();}
  228.           distance1=0;
  229.
  230.          EX0=0;            //关闭外部中断
  231.          TR0=0;
  232.          TR1=1;
  233.          pro=25;        //舵机返回90°方向
  234.          delay_ms(50);
  235.          TR1=0;
  236.          delay_ms(10);
  237.          if(DATA1>=12 && DATA1>DATA2){comeright ();comeon();  }//当0度方向大于 8cm  并大于180度方向 则右转 前进
  238.          else if (DATA2>=12 && DATA2>=DATA1){comeleft(); comeon(); }        //当180度方向大于 8cm  并大于0度方向 则左转 前进
  239.          else if (DATA2<12 && DATA1<8) {back(); comeleft();comeon();  }//当180度方向和0度方向都小于8cm 则小车后退一定距离 左转 前进
  240.         }
  241.         else{ comeon(); }//否则小车直走
  242. }
  243. void display ()
  244. {
  245.         P2=P2|0XF0;
  246.         P0=~seg7code[0];
  247.         SET1=0;
  248.         delay_us(20);
  249.         P2=P2|0XF0;
  250.
  251.         P0=~seg7code[distance1/100];
  252.         SET2=0;
  253.         delay_us(20);
  254.         P2=P2|0XF0;
  255.         P0=~seg7code[(distance1%100)/10];
  256.         SET3=0;
  257.         delay_us(20);
  258.         P2=P2|0XF0;
  259.         P0=~seg7code[distance1%10];
  260.         SET4=0;
  261.         delay_us(20);
  262.         P2=P2|0XF0;
  263.
  264. }
  265. void main(void)
  266. {
  267.         P1=0XFF;
  268.         P2=0XFF;
  269.         P3=0XFF;
  270.         P0=0XFF;
  271.         Init();   //初始化
  272.         baidong();
  273.         while(1)
  274.          {
  275.          shunback();
  276. ……………………
  277. …………限于本文篇幅 余下代码请从51黑下载附件…………
超声波测距显示并避障.rar (33.77 KB, 下载次数: 10)
