#include<reg52.h>
uchar a,count,S1num,xqnum;
char yue,ri,shi,fen,miao;
int nian;
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
sbit S1=P3^0; //定义键——进入设置
sbit S2=P3^1; //定义键——增大
sbit S3=P3^2; //定义键——减小
sbit S4=P3^3; //定义键——退出设置
uchar code table0[]="2014-08-13 WED";
uchar code table1[]="00:00:00";
uchar code xingqi[][3]={"MON","TUE","WED","THU","FRI","SAT","SUN"};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
1602液晶显示器模块
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
void write_com(uchar com) //液晶写指令
lcdrw=0;
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar dat) //液晶写数据
lcdrw=0;
lcdrs=1;
P0=dat;
delay(5);
lcden=1;
delay(5);
lcden=0;
年月日写入1602函数
void write_sfm(uchar add,uchar dat) //写时分秒函数
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+0x40+add);
write_data(0x30+shi);
write_data(0x30+ge);
void write_yr(uchar add,uchar dat) //写月日函数
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+add);
void write_nian(uchar add,uint dat) //写年函数
uint qian,bai,shi,ge;
qian=dat/1000;
bai=dat%1000/100;
shi=dat%100/10;
ge=dat%10;
write_data(0x30+qian);
write_data(0x30+bai);
初始化
void init_lcd() //液晶初始化
lcden=0;
nian=2014;
yue=8;
ri=13;
shi=0; //初始shi、fen、miao
fen=0;
miao=0;
write_com(0x38); //设置16x2显示,5x7点阵,8位数据口
write_com(0x0c); //设置开显示,不显示光标
write_com(0x06); //写一个字符后地址指针加1
write_com(0x01); //显示清0,数据指针清0
void init() //初始化函数
init_lcd(); //液晶初始化
write_com(0x80); //设置显示初始坐标
for(a=0;a<14;a++) //显示年月日初始值
write_data(table0[a]);
delay(5);
write_com(0x80+0x40); //设置显示初始坐标
for(a=0;a<8;a++) //显示时分秒初始值
write_data(table1[a]);
delay(5);
write_nian(0,nian);
write_sfm(6,miao); //分别将shi、fen、miao送去液晶显示
write_sfm(3,fen);
write_sfm(0,shi);
count=0;
xqnum=0;
S1num=0; //初始化全局变量count
TMOD=0x01; //设置定时器0工作模式1
TH0=(65535-50000)/256; //定时器装初始值
TL0=(65535-50000)%256;
EA=1; //开总中断
ET0=1; //开定时器0中断
TR0=1; //启动定时器0
独立键盘
独立键盘已接地
void keyscan()
if(S1==0)
delay(5); //确认定义键被按下
if(S1==0)
S1num++; //定义键S1按下次数记录
while(!S1); //释放按键确认
if(S1num==1) //S1按下一次时
TR0=0; //关闭定时器
write_com(0xc0+7); //光标定位到秒位置
write_com(0x0f); //光标闪烁
if(S1num==2) //S1按下两次时
write_com(0xc0+4); //光标定位到分位置
if(S1num==3) //S1按下三次时
write_com(0xc0+1); //光标定位到时位置
if(S1num==4) //S1按下四次时
write_com(0x80+13); //光标定位到星期位置
if(S1num==5) //S1按下五次时
write_com(0x80+9); //光标定位到日位置
if(S1num==6) //S1按下六次时
write_com(0x80+6); //光标定位到月位置
if(S1num==7) //S1按下七次时
write_com(0x80+3); //光标定位到年位置
if(S1num==8) //S1按下八次时
S1num=0; //S1记录按键次数清零
TR0=1; //开启定时器
write_com(0x0c); //取消光标闪烁
if(S1num!=0) //只有定义键按下后S2、S3、S4才有效
if(S2==0)
delay(5); //防抖
if(S2==0) //确认按键被按下
while(!S2); //释放按键确认
miao++; //调整秒加1
if(miao==60) //满60清零
miao=0;
write_sfm(6,miao); //每调节一次送液晶显示一次
write_com(0x80+0x40+6); //显示位置重新回到调节处
fen++; //调整分加1
if(fen==60)
fen=0;
write_sfm(3,fen);
write_com(0x80+0x40+3);
shi++; //调整时加1
if(shi==24)
shi=0;
write_sfm(0,shi);
if(S1num==4) //星期加调整
xqnum++;
if(xqnum==7)
xqnum=0;
write_com(0x80+0x0b);
for(a=0;a<3;a++)
write_data(xingqi[xqnum][a]);
delay(5);
if(S1num==5) //日加调整
ri++;
if(yue==2)
if(nian%400==0)
if(ri==30)
ri=1;
if(nian%400!=0)
if(ri==29)
ri=1;
else if(yue<=7)
if(yue%2==0&yue!=2)
if(ri==31)
ri=1;
else if(yue%2!=0&yue!=2)
if(ri==32)
ri=1;
else if(yue>=8)
if(yue%2==0)
if(ri==32)
ri=1;
else if(yue%2!=0)
if(ri==31)
ri=1;
write_yr(8,ri);
if(S1num==6) //月加调整
yue++;
if(yue==13)
yue=1;
write_yr(5,yue);
if(S1num==7) //年加调整
nian++;
if(nian==2019)
nian=2014;
write_nian(0,nian);
if(S3==0)
delay(5);
if(S3==0) //确认按键被按下
while(!S3);
if(S1num==1)
miao--; //调整秒减1
if(miao==-1) //减到00后再减重新设置为59
miao=59;
write_sfm(6,miao);
if(S1num==2)
fen--; //调整分减1
if(fen==-1)
fen=59;
write_sfm(3,fen);
if(S1num==3)
shi--; //调整时减1
if(shi==-1)
shi=23;
write_sfm(0,shi);
if(S1num==4)
xqnum--; //调整星期减一
if(xqnum==-1)
xqnum=6;
for(a=0;a<3;a++)
delay(5);
if(S1num==5) //调整日
ri--;
if(yue==2)
if(nian%400==0)
if(ri==0)
ri=29;
if(nian%400!=0)
if(ri==0)
ri=28;
else if(yue<=7)
if(yue%2==0&yue!=2)
if(ri==0)
ri=30;
if(ri==0)
ri=31;
else if(yue>=8)
if(yue%2==0)
if(ri==0)
ri=31;
else if(yue%2!=0)
if(ri==0)
ri=30;
write_yr(8,ri);
if(S1num==6) //调整月
yue--;
if(yue==0)
yue=12;
write_yr(5,yue);
if(S1num==7) //调整年
nian--;
if(nian==2013)
nian=2018;
write_nian(0,nian);
if(S4==0) //退出设置、开启中断
delay(5);
if(S4==0)
S1num=0;
TR0=1;
write_com(0x0c);
定时器0
void timer0() interrupt 1 //定时器0中断服务程序
TH0=(65535-50000)/256; //重装定时器初始值
count++; //中断次数累加
if(count==20) //20次50毫秒即一秒
count=0;
miao++;
if(miao==60) //秒加到60时分进位
miao=0;
fen++;
if(fen==60) //分加到60时时进位
fen=0;
shi++;
if(shi==24) //时加到24时清0
shi=0;
xqnum++;
ri++;
if(yue==2) //如果是二月
if(nian%400==0) //闰年判断
if(ri==30)
ri=1;
yue++;
write_yr(5,yue);
if(nian%400!=0) //平年判断
if(ri==29)
ri=1;
yue++;
write_yr(5,yue);
else if(yue<=7&yue!=2) //一月到七月
if(yue%2==0) //偶数月(除二月)
if(ri==31)
ri=1;
yue++;
else if(yue%2!=0) //奇数月
if(ri==32)
ri=1;
yue++;
write_yr(5,yue);
else if(yue>=8) //八月到12月
if(ri==32)
ri=1;
yue++;
if(yue==13) //如果判断月份为12月,则加一后重新定义月份为1
yue=1;
nian++;
write_nian(0,nian);
write_yr(5,yue);
if(ri==31)
ri=1;
yue++;
write_yr(5,yue);
write_yr(8,ri);
if(xqnum==7) //星期写入
xqnum=0;
for(a=0;a<3;a++)
delay(5);
write_sfm(0,shi); //重新写入数据
write_sfm(3,fen); //重新写入数据
write_sfm(6,miao); //重新写入数据
主函数
init();
keyscan(); //不停的检测按键是否被按下
