查看: 2692|回复: 0
SP207E–SP213E引脚图与datasheet
SP207E–SP213E ic datasheet
Low Power, High ESD +5V RS-232 Transceivers
■     Meets    All    EIA-232    and    ITU    V.28     Specifcations
■     Single    +5V    Supply    Operation
■     3mA    Typical    Static    Supply    Current
■     4    x    0.1μF    External    Charge    Pump    Capacitors
■     Typical    230kbps    Transmission    Rates
■     Standard    SOIC    and    SSOP    Footprints
■     1μA    Shutdown    Mode    (SP211E    &    SP213E)
■     Two    Wake-Up    Receivers    (SP213E)
■     Tri-State/RxEnable    (SP211E    &    SP213E)
■     Improved    ESD    Specifcations:
    +5kV Human Body Model
    +5kV IEC000-4-2 Air Discharge
    +8kV IEC000-4-2 Contact Discharge
SP207E–SP213E引脚图
完整的pdf格式文档51黑下载地址(共19页):
sp.pdf (995.78 KB, 下载次数: 5)
