课设做的很简单的计算器,基本运算都有,可报错
- // C main line
- #include <m8c.h> // part specific constants and macros
- #include "PSoCAPI.h" // PSoC API definitions for all User Modules
- #include "Shuzi.h"
- #include "Character.h"
- #include "Define.h"
- void Delayms(void){
- unsigned int n = 0x00;
- for(n=2000;n>0;n--);
- void Delays(unsigned int n){
- unsigned int m = 0x00;
- while(n--){
- for(m=0;m<500;m++){
- //向上边LCD还是向下边LCD写数据/命令
- void LCD_Write(unsigned char chn,unsigned char CMD_DAT,unsigned char dat){
- unsigned char n = 0x00;
- if(CMD_DAT == COMMAND){
- LCD_RS_OUT0;
- }else{
- LCD_RS_OUT1;
- LCD_DATA_PORT = dat;
- LCD_WR_OUT0;
- LCD_RD_OUT0;
- if (chn == LCD_UP){//选择上边LCD
- LCD_CS1_OUT0;
- }else{
- if(chn == LCD_DOWN){//选择下边LCD
- LCD_CS2_OUT0;
- }else{//选择两个LCD
- LCD_CS1_OUT0;
- LCD_CS2_OUT0;
- for(n=0;n<10;n++);
- LCD_RD_OUT1;
- //LCD_WR_OUT1;
- LCD_CS1_OUT1;
- }else{
- LCD_CS2_OUT1;
- }else{//选择两个LCD
- LCD_CS1_OUT1;
- LCD_CS2_OUT1;
- LCD_RD_OUT0;
- //在com,seg上写一个字节的数据
- void Draw_Line(unsigned char chn,unsigned char pg,unsigned char seg,unsigned char dat1,unsigned char dat2,unsigned char CNT){
- //unsigned char m = 0x00;
- seg = seg +4;
- LCD_Write(chn,COMMAND,(0xb0 | pg ));// 写 pg 地址
- LCD_Write(chn,COMMAND,(0x10 | (((seg >> 4) & 0x0f))));// 写 seg 高4位地址
- LCD_Write(chn,COMMAND,(0x00 | ((seg & 0x0f))));// 写 seg 低4位地址
- for(n=0;n<CNT;n++){
- LCD_Write(chn,DATA,dat1);
- n++;
- if(n<CNT){
- //for(m=0;m<5;m++);
- LCD_Write(chn,DATA,dat2);
- //清除LCD上所有的数据,使之显示空白
- void Clear_LCD(unsigned char chn){
- for(n=0;n<LCD_HEIGHT_PAGE;n++){
- Draw_Line(chn,n,0x00,0x00,0x00,LCD_WIDTH);
- //初始化LCD
- void LCD_Init(void){
- LCD_RST_OUT0;
- Delays(50);
- LCD_RST_OUT1;
- Delays(50);
- //LCD_Write(LCD_TWO,COMMAND,0xa0);//
- LCD_Write(LCD_TWO,COMMAND,0xc0);
- LCD_Write(LCD_TWO,COMMAND,0xa1);//
- //LCD_Write(LCD_TWO,COMMAND,0xc8);
- LCD_Write(LCD_TWO,COMMAND,0xf8);
- LCD_Write(LCD_TWO,COMMAND,0x00);
- LCD_Write(LCD_TWO,COMMAND,0xa2);
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x2c);
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x2e);
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x2f);
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x24);
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x81);
- LCD_Write(LCD_TWO,COMMAND,41);// 41 = 9.0V
- Delays(10);
- LCD_Write(LCD_TWO,COMMAND,0x40);
- Clear_LCD(LCD_UP);
- Clear_LCD(LCD_DOWN);
- LCD_Write(LCD_TWO,COMMAND,0xaf);
- Delays(10);
- //清除数字区
- void Clear_Num(unsigned char pg,unsigned char seg,unsigned char length){
- Draw_Line(LCD_UP,pg,seg,0x00,0x00,length);
- Draw_Line(LCD_UP,pg+1,seg,0x00,0x00,length);
- //冀雅测试画面
- void Show_Test(unsigned char chn){
- unsigned char m = 0x00;
- for(n=0;n<TEST_CNT;n++){
- for(m=0;m<LCD_HEIGHT_PAGE;m++){
- Draw_Line(chn,m,0x00,TEST_CODE[n*2],TEST_CODE[n*2+1],LCD_WIDTH);
- Delays(TEST_DELAY_VALUE);
- //显示框屏
- void Show_Kuang(unsigned char chn){
- Draw_Line(chn,0,0x00,0x01,0x01,LCD_WIDTH);
- Draw_Line(chn,(LCD_HEIGHT_PAGE - 1),0x00,0x80,0x80,LCD_WIDTH);
- Draw_Line(chn,n,0,0xff,0xff,0x01);
- Draw_Line(chn,n,(LCD_WIDTH - 1),0xff,0xff,0x01);
- //显示冀雅模块汉字
- void Show_Hanzi(unsigned char chn,unsigned char pg,unsigned char seg,unsigned char color){
- unsigned int n = 0x0000;
- unsigned int m = 0x0000;
- unsigned int k = 0x0000;
- for(k=0;k<4;k++){
- for(n=0;n<2;n++){
- for(m=0;m<16;m++){
- if(color == BLACK){
- Draw_Line(chn,pg+n,seg+k*16+m,JIYA[k*32+n*16+m],0x00,0x01);
- }else{
- Draw_Line(chn,pg+n,seg+k*16+m,~JIYA[k*32+n*16+m],0x00,0x01);
- //显示+-*/ 标志触摸区
- // ADD_FUHAO 0
- // MIN_FUHAO 1
- // MUL_FUHAO 2
- // DIV_FUHAO 3
- void Show_Fuhao(unsigned char chn,unsigned char witch,unsigned char pg,unsigned char seg){
- if(witch != 0xff){//如果不是清屏命令
- for(n=0;n<2;n++){
- for(m=0;m<17;m++){
- Draw_Line(chn,pg+n,seg+m,YUN_SUN_CODE[witch*34+n*17+m],0x00,0x01);
- }else{
- for(n=0;n<2;n++){
- Draw_Line(chn,pg+n,seg,0x00,0x00,17);
- //显示单一字符,数字,或者+-*/=C功能按键符号
- void Show_Sig_Char(unsigned char chn,unsigned char pg,unsigned char seg,unsigned char num){
- if(num < 10){//如果是数字
- for(n=0;n<2;n++){
- for(m=0;m<9;m++){
- Draw_Line(chn,pg+n,seg+m,MID_NUM_CODE[num*18+n*9+m],0x00,0x01);
- }else{
- switch(num){
- case 'C':
- Show_CLR_CAL_FUHAO(chn,CLR_FUHAO,pg,seg);
- break;
- case '=':
- Show_CLR_CAL_FUHAO(chn,CAL_FUHAO,pg,seg);
- break;
- case '+':
- Show_Fuhao(chn,ADD_FUHAO,pg,seg);
- break;
- case '-':
- Show_Fuhao(chn,MIN_FUHAO,pg,seg);
- break;
- case '*':
- Show_Fuhao(chn,MUL_FUHAO,pg,seg);
- break;
- case '/':
- Show_Fuhao(chn,DIV_FUHAO,pg,seg);
- break;
- default:
- break;
- //显示数字,long型数据,最多可显示10位数字
- void Show_Num(unsigned char chn,unsigned char pg,unsigned char seg,unsigned long num){
- unsigned long dat[10];
- unsigned long tmp = 0x00000000;
- unsigned char dispay_on = 0x00;
- unsigned char k = 0x00;
- tmp = num;
- dat[0] = tmp / 1000000000;
- dat[1] = (num - dat[0] * 100000000) / 100000000;
- dat[2] = (num - dat[0] * 1000000000 - dat[1] * 100000000) / 10000000;
- dat[3] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000) / 1000000;
- dat[4] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000 - dat[3] * 1000000) / 100000;
- dat[5] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000 - dat[3] * 1000000 - dat[4] * 100000) / 10000;
- dat[6] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000 - dat[3] * 1000000 - dat[4] * 100000 - dat[5] * 10000) / 1000;
- dat[7] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000 - dat[3] * 1000000 - dat[4] * 100000 - dat[5] * 10000 - dat[6] * 1000) / 100;
- dat[8] = (num - dat[0] * 1000000000 - dat[1] * 100000000 - dat[2] * 10000000 - dat[3] * 1000000 - dat[4] * 100000 - dat[5] * 10000 - dat[6] * 1000 - dat[7] * 100) / 10;
- dat[9] = num % 10;
- for(n=0;n<10;n++){//显示10个数字
- if(dat[n] != 0x00){//数字不等于0,需要显示
- dispay_on = 0xff;
- Show_Sig_Char(chn,pg,seg+n*9,dat[n]);
- }else{
- if(dispay_on != 0x00){//已经有不为0的数字了,需要继续显示
- }else{
- if(n == 9){
- //显示输入的数字,最多5个数字
- void Show_Input_Num(unsigned char pg,unsigned char seg,unsigned char dat[5]){
- for(n=0;n<5;n++){
- dispay_on = 0xff;
- Show_Sig_Char(LCD_UP,pg,seg+n*9,dat[n]);
- }else{
- //开始SEG = 30
- void Show_First_Num(unsigned char num){
- if(num > 9){
- //显示计算器界面,下边的屏幕
- void Show_CAL_GUI(void ){
- for(n=0;n<16;n++){
- Show_Sig_Char(LCD_DOWN,CAL_POSITION_GUI[n*2],CAL_POSITION_GUI[n*2+1],TP_KEY_CODE[n]);
- const unsigned int MUL_CODE[]={
- 10000,1000,100,10,1,
- //计算输入值
- unsigned long CAL_Input_Num(unsigned char num[5]){
- unsigned long tmpl = 0x00;
- unsigned long dt = 0x00;
- tmpl = 0x00000000;
- for(n=0;n<5;n++){
- dt = num[n];
- dt = dt * MUL_CODE[n];
- tmpl = tmpl + dt;
- return tmpl;
- //显示 作者
- void Show_Author(unsigned char pg,unsigned char seg){
- for(k=0;k<6;k++){
- for(n=0;n<2;n++){
- Draw_Line(LCD_UP,pg+n,seg+k*16+m,AUTHOR_CODE[k*32+n*16+m],0x00,0x01);
- //显示 冀雅
- void Show_Jiya(unsigned char pg,unsigned char seg){
- for(k=0;k<2;k++){
- for(n=0;n<2;n++){
- Draw_Line(LCD_UP,pg+n,seg+k*16+m,JIYA[k*32+n*16+m],0x00,0x01);
- //显示 计算器
- void Show_Jisuanqi(unsigned char pg,unsigned char seg){
- for(k=0;k<3;k++){
- for(n=0;n<2;n++){
- Draw_Line(LCD_UP,pg+n,seg+k*16+m,JISUANQI_CODE[k*32+n*16+m],0x00,0x01);
- //显示 参数错误
- void Show_Err_Tips(unsigned char pg,unsigned char seg){
- for(k=0;k<4;k++){
- for(n=0;n<2;n++){
- Draw_Line(LCD_UP,pg+n,seg+k*16+m,ERROR_TIPS[k*32+n*16+m],0x00,0x01);
- //在上边屏幕显示冀雅LOGO
- void Show_Logo(void ){
- Show_Jiya(0,8);//显示冀雅
- Show_Jisuanqi(3,0);//显示计算器
- //计算器测试
- void Caculate_Test(void ){
- unsigned char Loop = 0x01;
- unsigned char key = 0x00;
- unsigned char Input_Num_Cnt = 0x00;
- unsigned char Input_NUM[5];
- unsigned char Fuhao = 0xff;
- unsigned char tmpm = 0x00;
- unsigned char last_key = 0xff;
- unsigned long rslt = 0x00;
- First_NUM = 0x00000000;
- Second_NUM= 0x00000000;
- for(n=0;n<5;n++){
- Input_NUM[n] = 0x00;
- Clear_LCD(LCD_UP);//清屏上边的屏幕
- Clear_LCD(LCD_DOWN);//清屏下边的屏幕
- Show_Logo();//显示冀雅LOGO
- Show_CAL_GUI();//显示下边屏幕的数字排列和符号标示
- Input_Num_Cnt = 0x00;
- while(Loop == 0x01){//进入有条件无限循环
- key = TP_Scan();//扫描按键
- if(key != 0xff){//如果有按键按下
- switch(key){//判断按下的是哪个按键
- case '+':
- Show_Fuhao(LCD_UP,ADD_FUHAO,2,55);
- Fuhao = '+';
- for(n=0;n<5;n++){
- break;
- case '-':
- Show_Fuhao(LCD_UP,MIN_FUHAO,2,55);
- Fuhao = '-';
- for(n=0;n<5;n++){
- break;
- case '*':
- Show_Fuhao(LCD_UP,MUL_FUHAO,2,55);
- Fuhao = '*';
- for(n=0;n<5;n++){
- break;
- case '/':
- Show_Fuhao(LCD_UP,DIV_FUHAO,2,55);
- Fuhao = '/';
- for(n=0;n<5;n++){
- break;
- case 'C':
- for(n=0;n<5;n++){//数据清零
- Fuhao = 0xff;
- Clear_Num(0,80,45);//清除第一个数字
- Clear_Num(3,80,45);//清除第二个数字
- Clear_Num(6,36,90);//清除计算结果
- Show_Fuhao(LCD_UP,0xff,2,55);//清除符号区
- Clear_Num(6,20,9);//清除 " = "
- break;
- case '=':
- //Second_NUM = CAL_Input_Num(Input_NUM);
- Show_Sig_Char(LCD_UP,6,20,'=');
- switch(Fuhao){//根据符号做出不同处理;
- case '+':
- rslt = First_NUM + Second_NUM;
- break;
- case '-':
- rslt = First_NUM - Second_NUM;
- break;
- case '*':
- rslt = First_NUM * Second_NUM;
- break;
- case '/':
- if(Second_NUM != 0x00){
- rslt = First_NUM / Second_NUM;
- }else{//有错误
- for(n=0;n<3;n++){
- Show_Err_Tips(3,32);//显示参数错误
- Delays(100);
- Delays(100);
- Loop = 0x00;//从此函数返回去
- break;
- default:
- for(n=0;n<3;n++){
- Delays(100);
- Delays(100);
- break;
- Show_Num(LCD_UP,6,36,rslt);//显示计算结果
- //重新初始化所有参数
- for(n=0;n<5;n++){
- Fuhao = 0xff;
- break;
- default://输入的是0——9数字
- if(last_key == '='){//如果按数字时,之前有计算结果显示,则清除之,再正常显示
- Fuhao = 0xff;
- }//完成准备工作
- if(Fuhao == 0xff){//输入第一个数据
- //判断输入的数据
- if(Input_Num_Cnt < 5){//输入的不够5个数字
- for(n=0;n<4;n++){
- Input_NUM[n] = Input_NUM[n+1];
- Input_NUM[4] = key;
- Input_Num_Cnt++;
- Show_Input_Num(0,80,Input_NUM);
- First_NUM = CAL_Input_Num(Input_NUM);
- }else{//输入第二个数据
- for(n=0;n<4;n++){
- Input_Num_Cnt++;
- Show_Input_Num(3,80,Input_NUM);
- Second_NUM = CAL_Input_Num(Input_NUM);
- break;
- last_key = key;//记录最后一次的按键
- void Start_LED(void ){
- for(n=0;n<1;n++){
- OPEN_LED;
- Delays(100);
- CLOSE_LED;
- //Delays(100);
- void main(void)
- // M8C_EnableGInt ; // Uncomment this line to enable Global Interrupts
- // Insert your main routine code here.
- unsigned char Flash_CNT= 50;
- unsigned char Wait_LED = 0x00;
- unsigned char Pre_Key = 0x00;
- unsigned char Valid_Key;
- unsigned char Valid_CNT = 0x00;
- unsigned char KEY_STATE[SENSOR_CNT];
- for(n=0;n<SENSOR_CNT;n++){
- KEY_STATE[n] = KEY_RELEASE;
- Valid_Key = 0x00;
- LCD_Init();//初始化LCD
- Delays(5);
- Capsense_Init();//初始化Capsense
- Start_LED();
- for(n=0;n<2;n++){
- Show_Test(LCD_TWO);
- Clear_LCD(LCD_TWO);
- Show_Kuang(LCD_TWO);
- Show_Hanzi(LCD_TWO,1,32,BLACK);
- Show_Hanzi(LCD_TWO,5,32,WHITE);
- while(1){
- Caculate_Test();
Calcu.rar
(3.72 KB, 下载次数: 5)
