数字示波器仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
- #include <AT89X52.h>
- #include <intrins.h>
- //12864控制引脚定义
- sbit DI = P2 ^ 2; //数据\指令选择引脚
- sbit RW = P2 ^ 1; //读\写选择引脚
- sbit E= P2 ^ 0; //读\写使能引脚
- sbit CS1 = P2 ^ 4; //片选1引脚
- sbit CS2 = P2 ^ 3; //片选2引脚
- sbit BUSY= P1 ^ 7; //忙标志位
- //按键控制定义
- sbit Y1 = P3 ^ 0;
- sbit Y2 = P3 ^ 1;
- sbit X1 = P3 ^ 3;
- sbit X2 = P3 ^ 7;
- //ADC0832控制引脚
- sbit START=P3^4;
- sbit OE=P3^6;
- sbit EOC=P3^5;
- unsigned int ADdata; //AD采集值
- unsigned int Ldata;
- unsigned char ye,lei,shu;
- unsigned char ADViewdata[91]; //AD显示数据存储区
- char code FrameData[]={ //提示字符存储区
- 0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x01,0x00,
- 0x01,0x00,0x11,0x10,0x11,0x08,0x21,0x04,0x41,0x02,0x81,0x02,0x05,0x00,0x02,0x00, //示
- 0x00,0x20,0x20,0x20,0x10,0x20,0x13,0xFE,0x82,0x22,0x42,0x24,0x4A,0x20,0x0B,0xFC,
- 0x12,0x84,0x12,0x88,0xE2,0x48,0x22,0x50,0x22,0x20,0x24,0x50,0x24,0x88,0x09,0x06, //波
- 0x00,0x00,0x3E,0x7C,0x22,0x44,0x22,0x44,0x3E,0x7C,0x01,0x20,0x01,0x10,0xFF,0xFE,
- 0x02,0x80,0x0C,0x60,0x30,0x18,0xC0,0x06,0x3E,0x7C,0x22,0x44,0x22,0x44,0x3E,0x7C, //器
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //" "
- //AD转换软件
- void ADCChage()
- START=1;
- START=0;
- while(EOC==0) //等待转换完成
- OE=1;
- ADdata = P0; //读取AD数据
- OE=0;
- //检查12864液晶状态
- void CheckState()
- DI=0;
- RW=1;
- do
- E=1;
- E=0;
- //仅当第7位为0时才可操作(判别busy信号)
- }while(BUSY==1);
- //向12864写入一个字节的命令
- void WriteCommand(unsigned char cmd)
- CheckState(); //检查当前的12864状态
- DI = 0;
- RW = 0;
- P1 = cmd; //送出相应的命令
- E = 1;
- E = 0;
- //向12864写入一个字节的数据
- void WriteData(unsigned char dat)
- DI = 1;
- RW = 0;
- P1 = dat; //送出相应的数据
- E = 1;
- E = 0;
- //12864液晶的选择控制引脚
- void LCMCSControl(unsigned int csl)
- if(csl==1) //根据参数不同判断当前的12864控制引脚状态
- CS1=0,
- CS2=1;
- if(csl==2)
- CS1=1,
- CS2=0;
- if(csl==3)
- CS1=0,
- CS2=0;
- //12864显示函数
- void LCMView()
- LCMCSControl(Ldata); //先发送控制命令
- WriteCommand(ye);
- WriteCommand(lei);
- WriteData(shu); //然后发送数据
- //12864的清屏函数
- void CleanScreen()
- unsigned char page,i;
- LCMCSControl(3);
- for(page=0xb8;page<=0xbf;page++)
- WriteCommand(page);
- WriteCommand(0x40);
- for(i=0;i<64;i++)
- WriteData(0x00);
- LCMCSControl(1);
- lei=0x40;
- for(ye=0xb8;ye<0xbf;ye++)
- shu=0xff;
- LCMView();
- ye=0xb8;
- for(lei=0x40;lei<=0x7f;lei++)
- shu=0x80;
- LCMView();
- ye=0xbf;
- shu=0x01;
- LCMView();
- LCMCSControl(2);
- ye=0xb8;
- for(lei=0x40;lei<=0x5b;lei++)
- shu=0x80;
- LCMView();
- ye=0xbf;
- shu=0x01;
- LCMView();
- lei=0x5b;
- for(ye=0xb9;ye<=0xbe;ye++)
- shu=0xff;
- LCMView();
- //12864的初始化函数
- void InitLCM(void)
- WriteCommand(0xc0);
- WriteCommand(0x3f);
- //50us的延时函数
- void Delay50us(unsigned int t)
- unsigned char j;
- for(;t>0;t--)
- for(j=19;j>0;j--);
- //刷新12864液晶
- void RefreshLCM()
- unsigned char i;
- for(i=0xb9;i<=0xbe;i++)
- ye=i;
- shu=0x00;
- LCMView();
- //主函数
- void main()
- unsigned int r,j,q,k;
- unsigned int Xaxis =0;
- unsigned int Yaxis = 1;
- unsigned char l;
- unsigned char d1,d2,d3,d4,d5;
- CleanScreen();
- InitLCM();
- LCMCSControl(2);
- l=0xb8;
- for(k=0;k<4;k++,l=l+0x02) //首先显示右侧的提示
- ye=l;
- lei=0x70;
- for(r=0;r<16;r++)
- shu=FrameData[2*r+1+32*k];
- LCMView();
- lei++;
- ye=l+0x01;
- lei=0x70;
- for(r=0;r<16;r++)
- shu=FrameData[2*r+32*k];
- LCMView();
- lei++;
- while(1)
- while(X2==0) //调节X轴
- while(X2==0);
- Xaxis = Xaxis + 1;
- while(X1==0)
- while(X1==0);
- if(Xaxis!=0)
- Xaxis = Xaxis - 1;
- while(Y1==0) //调节Y轴
- while(Y1==0);
- Yaxis = Yaxis + 1;
- while(Y2==0)
- while(Y2==0);
- if(Yaxis!=1)
- Yaxis=Yaxis-1;
- for(j=0;j<90;j++) //AD采样最大值
- ADCChage();
- ADViewdata[j]=ADdata;
- if(ADViewdata[j]>ADViewdata[91])
- ADViewdata[91]=ADViewdata[j];
- Delay50us(Xaxis);
- while(ADdata!=ADViewdata[91]) //如果采集值不相等,则继续
- ADCChage();
- for(j=0;j<90;j++) //连续采样90次
- ADCChage();
- Delay50us(Xaxis);
- lei=0x41;
- for(r=0,j=0;r<90;r++,j++)
- if(j<63)
- Ldata=1;
- if(j==63)
- lei=0x40;
- if(j>=63)
- Ldata=2;
- RefreshLCM(); //刷新当前显示
- if(ADViewdata[j>=127])//正电压
- ADdata=(ADViewdata[j]-127)*0.196/Yaxis; //计算电压值
- if(ADdata<=7)
- ye=0xbb;
- shu=(0x80>>ADdata);
- else if(ADdata<=15)
- ye=0xba;
- shu=(0x80>>(ADdata-8));
- else if(ADdata<=23)
- ye=0xb9;
- shu=(0x80>>(ADdata-16));
- else if(ADdata<=31)
- ye=0xb9;
- shu=(0x80>>(ADdata-24));
- if(ADViewdata[j]<127) //负电压
- ADdata=(127-ADViewdata[j])*0.196/Yaxis; //计算电压值
- if(ADdata<=7)
- ye=0xbc;
- shu=(0x01<<(ADdata));
- ye=0xbd;
- shu=(0x01<<(ADdata-8));
- ye=0xbe;
- shu=(0x01<<(ADdata-16));
- ye=0xbe;
- shu=(0x01<<(ADdata-24));
- if(r==0)//判断正负
- d1=shu;
- d2=ye;
- if(r!=0)
- d3=shu;
- d4=ye;
- if(ye==d2) //如果相等,则判断是否显示完成
- if(shu>d1)
- d5=shu;
- d5=d5>>1;
- while(d5!=d1)
- d5=d5>>1;
- shu=shu|(shu>>1);
- if(shu<d1)
- d5=shu;
- d5=d5<<1;
- while(d5!=d1)
- d5=d5<<1;
- shu=shu|(shu<<1);
- if(ye<d2)
- for(q=0;q<7;q++)
- shu=shu|(shu<<1);
- LCMView();
- ye++;
- while(ye<d2)
- shu=0xff;
- LCMView();
- ye++;
- if(ye==d2)
- shu=0x01;
- if(shu<d1)
- d5=shu;
- d5=d5<<1;
- while(d5!=d1)
- d5=d5<<1;
- shu=shu|(shu<<1);
- …………限于本文篇幅 余下代码请从51黑下载附件…………
数字示波器.rar
(74.51 KB, 下载次数: 57)
