查看: 8126|回复: 2
short-Cricuit Constraint;Between Polygon Region (0 holes(s))AD PCB板子DRC时出错
AD求助~PCB板子DRC时出现这个错误一直找不到
short-Cricuit Constraint;Between Polygon Region (0 holes(s)) Bottom Layer And Via(55.067mm,39.548mm)from Top Layer to Bottom Layer Location:[X = 0mm][Y = 0mm]
ID:379554 发表于 2018-7-26 17:40 | 只看该作者
怎么解决的啊?我也遇到了
ID:939211 发表于 2021-6-17 11:19 | 只看该作者
我把覆铜去掉再重新画线,就解决了
