做了一个基于dht11和5001显示模块的温湿度检测器
- #include <reg52.h>
- #include"dht11.h"
- sbit res = P2^0; //复位,0复位
- sbit sce = P2^1; //片选
- sbit dc = P2^2; //1写数据,0写指令
- sbit sdin = P2^3; //数据
- sbit sclk = P2^4; //时钟
- unsigned char code shuzi[]={
- /*-- 文字: 0 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
- /*-- 文字: 1 --*/
- 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: 2 --*/
- 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
- /*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 4 --*/
- 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
- /*-- 文字: 5 --*/
- 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 6 --*/
- 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 7 --*/
- 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
- /*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 9 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,
- /*-- 文字: a --10*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,
- /*-- 文字: b --11*/
- 0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: c --12*/
- 0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,
- /*-- 文字: d --13*/
- 0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,
- /*-- 文字: e --*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,
- /*-- 文字: f --*/
- 0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: g --16*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,
- /*-- 文字: h --*/
- 0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,
- /*-- 文字: i --*/
- 0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: j --19*/
- 0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,
- /*-- 文字: k --*/
- 0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,
- /*-- 文字: l --*/
- 0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: m --22*/
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,
- /*-- 文字: n --23*/
- 0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,
- /*-- 文字: o --24*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,
- /*-- 文字: p --*/
- 0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: q --*/
- 0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,
- /*-- 文字: r --*/
- 0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,
- /*-- 文字: s --*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,
- /*-- 文字: t --*/
- 0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,
- /*-- 文字: u --30*/
- 0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,
- /*-- 文字: v --*/
- 0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,
- /*-- 文字: w --*/
- 0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,
- /*-- 文字: x --*/
- 0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,
- /*-- 文字: y --*/
- 0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,
- /*-- 文字: z --35*/
- 0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,
- /*-- 文字: - --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- /*-- 文字: = --*/
- 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
- /*-- 文字: \ --*/
- 0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,
- /*-- 文字: --39*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: [ --*/
- 0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,
- /*-- 文字: ] --*/
- 0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,
- /*-- 文字: ; --*/
- 0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,
- /*-- 文字: ' --*/
- 0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: , --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: . --45*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: / --*/
- 0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,
- unsigned char code maohao[]={
- /*-- 文字: : --*/
- 0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00
- unsigned char code jiaohao[]={
- /*-- 文字: + - --48*/
- 0x00,0x00,0x10,0x10,0x7C,0x10,0x10,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x00,
- /*-- 文字: + --49*/
- 0x00,0x00,0x10,0x10,0x7C,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: - --50*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x00
- unsigned char code hanzi[]=
- /*-- 文字: 温 --*/
- /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/
- 0x10,0x60,0x02,0x8C,0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
- 0x04,0x04,0x7E,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
- /*-- 文字: 度 --*/
- 0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
- 0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00,
- /*-- 文字: : --*/
- 0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: --*/
- 0x00,0x00,0x00,0xFE,0x10,0x10,0x10,0x10,0x10,0x1F,0x10,0x10,0x10,0x18,0x10,0x00,
- 0x80,0x40,0x30,0x0F,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,0x00,0x00,0x00,0x00,
- /*-- 文字: 机 --*/
- 0x08,0x08,0xC8,0xFF,0x48,0x88,0x08,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
- 0x04,0x03,0x00,0xFF,0x00,0x41,0x30,0x0C,0x03,0x00,0x00,0x00,0x3F,0x40,0x78,0x00,
- /*-- 文字: 湿 --*/
- 0x10,0x60,0x02,0x8C,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
- 0x04,0x04,0x7E,0x01,0x44,0x48,0x50,0x7F,0x40,0x40,0x7F,0x50,0x48,0x44,0x40,0x00,
- /*-- 文字: 度 --*/
- /*-- 文字: 网 --*/
- void delay_1ms(unsigned int i)//1ms延时函数
- for (i=0;i<500;i++);
- LCD_write_byte: 使用SPI接口写数据到LCD
- 输入参数:dt:写入的数据;
- command :写数据/命令选择;
- 编写日期:20080918
- void LCD_write_byte(unsigned char dt, unsigned char command)
- unsigned char i;
- sce=0;
- dc=command;
- for(i=0;i<8;i++)
- if(dt&0x80)
- sdin=1;
- else
- sdin=0;
- dt=dt<<1;
- sclk=0;
- sclk=1;
- dc=1;
- sce=1;
- sdin=1;
- LCD_init: 3310LCD初始化
- 编写日期:20080918
- void LCD_init(void)
- res=0;
- delay_1ms(1);
- res=1;
- LCD_write_byte(0x21,0);//初始化Lcd,功能设定使用扩充指令
- LCD_write_byte(0xa8,0);//设定液晶偏置电压
- LCD_write_byte(0x20,0);//使用基本指令
- LCD_write_byte(0x0C,0);//设定显示模式,正常显示
- LCD_set_XY: 设置LCD坐标函数
- 输入参数:X:0-83 Y:0-5
- 编写日期:20080918
- void LCD_set_XY(unsigned char X, unsigned char Y)
- LCD_write_byte(0x40 | Y, 0);// column
- LCD_write_byte(0x80 | X, 0);// row
- LCD_clear: LCD清屏函数
- 编写日期:20080918
- void LCD_clear(void)
- unsigned char t;
- unsigned char k;
- LCD_set_XY(0,0);
- for(t=0;t<6;t++)
- for(k=0;k<84;k++)
- LCD_write_byte(0x00,1);
- LCD_write_shu: 显示8(宽)*16(高)点阵列数字字母符号等半角类
- 输入参数:c:显示的字符;
- 编写日期:20080918
- void LCD_write_shu(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
- unsigned char i;
- LCD_set_XY(row*8, page);// 列,页
- for(i=0; i<8;i++)
- LCD_write_byte(shuzi[c*16+i],1);
- LCD_set_XY(row*8, page+1);// 列,页
- for(i=8; i<16;i++)
- LCD_write_hanzi: 显示16(宽)*16(高)点阵列汉字等半角类
- 输入参数:c:显示的字符;
- 编写日期:20080918
- void LCD_write_hanzi(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
- unsigned char i;
- for(i=0; i<16;i++)
- LCD_write_byte(hanzi[c*32+i],1);
- for(i=16; i<32;i++)
- void delay(unsigned int i)
- while(i--);
- main()
- unsigned char k,i;
- i=1;
- res=0;
- for(k=0;k<250;k++);
- res=1;
- LCD_init(); //初始化LCD模块
- LCD_clear(); //清屏幕
- dht11_init();
- while(1)
- LCD_write_hanzi(0,0,0); //温
- LCD_write_hanzi(2,0,1); //度
- LCD_write_hanzi(4,0,2); //:
- LCD_write_hanzi(0,2,5); //湿
- LCD_write_hanzi(2,2,6); //度
- LCD_write_hanzi(4,2,7); //:
- LCD_write_shu(5,0,i);
温湿度检测.rar
(29.7 KB, 下载次数: 12)
