Quad 2−Input OR Gate
High−Performance Silicon−Gate CMOS
The 74HC32 is identical in pinout to the LS32. The device inputs are
compatible with Standard CMOS outputs; with pullup resistors, they
are compatible with LSTTL outputs.
Features
• Output Drive Capability: 10 LSTTL Loads
• Outputs Directly Interface to CMOS, NMOS and TTL
• Operating Voltage Range: 2.0 to 6.0 V
• Low Input Current: 1.0 A
• High Noise Immunity Characteristic of CMOS Devices
• In Compliance With the JEDEC Standard No. 7A Requirements
• ESD Performance: HBM 2000 V; Machine Model 200 V
• Chip Complexity: 48 FETs or 12 Equivalent Gates
• These are Pb−Free Devices
74hc32引脚图+真值表+逻辑图
完整的pdf格式文档51黑下载地址:
74hc32芯片参数.pdf
(127.09 KB, 下载次数: 11)
