查看: 1353|回复: 0
3x8e做的智能监控陀螺仪程序
ID:288254 发表于 2018-3-6 16:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3x8e做的智能监控陀螺仪程序,陀螺仪用的MP6000A
#include "intell_monitor_api.h"
#include "asf.h"
#include "def.h"
#include "string.h"
#include "compiler.h"
#include "stdio.h"
#include "math.h"
#define PI           3.14159265
#define SDA_IO_OUTPUT           0x00
#define SDA_IO_INPUT              0x01
#define IIC_CLOCK_DELAY         100/*20->10, for test*/
#define IIC_HIGH                       0x01
#define IIC_LOW                        0x00
//定义MPU3050内部地址********************
#define WHO     0x75
#define SMPL 0x19
#define   DLPF 0x1a
#define GYRO_CONFIG  0x1b //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
#define ACCEL_CONFIG 0x1c //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
#define  INT_CONFIG 0x37
#define  INT_ENABLE 0x38
#define  INT_STATUS 0x3a
#define TMP_H 0x41
#define TMP_L 0x42
#define GX_H 0x43
#define GX_L 0x44
#define GY_H 0x45
#define GY_L 0x46
#define   GZ_H 0x47
#define   GZ_L 0x48
#define AUX_H 0x3b
#define AUX_L 0x3c
#define AUY_H 0x3d
#define AUY_L 0x3e
#define   AUZ_H 0x3f
#define   AUZ_L 0x40
#define  PWR_M1 0x6b
#define  PWR_M2 0x6c
#define SlaveAddress   0xd0
UNIVOLTAGE_t vtg;
static void CLK_Delay(void)
unsigned long i;
for (i=0; i<IIC_CLOCK_DELAY; i++);
static STATUS setSCL_GYRO(uchar_t value)
  if(value == IIC_LOW)
   gpio_set_pin_low(TWI1_CLK_GPIO);
   gpio_set_pin_high(TWI1_CLK_GPIO);
return ok;
static STATUS SDA_IO_Direction_GYRO(uchar_t value)
  if(value == SDA_IO_OUTPUT)  /*定义SDA为输出方向*/
   gpio_configure_pin(TWI1_DATA_GPIO,MDIO_OUTPUT_FLAGS);
  if(value == SDA_IO_INPUT)    /*定义SDA为输入方向*/
   gpio_configure_pin(TWI1_DATA_GPIO,MDIO_INPUT_FLAGS);
CLK_Delay();//delay_us(5);
return ok;
static STATUS setSDA_GYRO(uchar_t value)
/*SDA_IO_Direction_SFP(SDA_IO_OUTPUT);*/
   gpio_set_pin_low(TWI1_DATA_GPIO);
   gpio_set_pin_high(TWI1_DATA_GPIO);
return ok;
static uchar_t  getSDA_GYRO()
  if((pio_get_pin_value(TWI1_DATA_GPIO)) == 1)
   return IIC_HIGH;
   return IIC_LOW;
/*读/写操作的START条件*/
static void START_GYRO()
SDA_IO_Direction_GYRO(SDA_IO_OUTPUT);
setSDA_GYRO(IIC_HIGH);
setSCL_GYRO(IIC_HIGH);
setSDA_GYRO(IIC_LOW);
setSCL_GYRO(IIC_LOW);
/*读/写操作的STOP条件*/
static void STOP_GYRO()
/*setSCL_SFP(IIC_LOW);CLK_Delay();*/
/*发送1字节*/
static void BYTE_SND_GYRO(uchar_t WR_data)
uchar_t i;
printf("WR_DATA=%x\r\n",WR_data);
for(i=0;i<8;i++)
  if(WR_data&0x80)
  WR_data<<=1;
/*接收1字节*/
static uchar_t BYTE_RCV_GYRO()
uchar_t temp=0;
uchar_t i;
SDA_IO_Direction_GYRO(SDA_IO_INPUT);
for(i=0;i<8;i++)
  temp <<= 1;
  if(getSDA_GYRO() == IIC_HIGH)
   temp |= 0x01;
return temp;
/*发送确认比特(ACK)*/
static void SND_ACK_GYRO()
/*发送非确认比特(noACK)*/
static void SND_noACK_GYRO()
/*接收确认比特,返回ACK/noACK*/
static uchar_t RCV_ACK_GYRO()
if(getSDA_GYRO() == IIC_LOW)
  return IIC_LOW;
return IIC_HIGH;
static STATUS IIC_ERROR_Release_GYRO()
     STOP_GYRO();
  printf("error\r\n");
     return error;
static STATUS IIC_OK_Release_GYRO()
     STOP_GYRO();
     return ok;
STATUS sndsIICRead_GYRO(uchar_t slaveAddr, uchar_t readAddr, uchar_t *pBuff)
uchar_t regAddr;
unsigned short num;
if (pBuff == NULL)
  return  error;
       regAddr  = readAddr;
START_GYRO();
BYTE_SND_GYRO(slaveAddr);
if(RCV_ACK_GYRO()==IIC_HIGH)
  IIC_ERROR_Release_GYRO();
  return error;
BYTE_SND_GYRO(regAddr);
  return error;
START_GYRO();
BYTE_SND_GYRO(slaveAddr |0x01);
  return error;
      *pBuff = BYTE_RCV_GYRO();
      SND_ACK_GYRO();
SND_noACK_GYRO();
IIC_OK_Release_GYRO();
return ok;
STATUS sndsIICWriteGYRO(uchar_t slaveAddr, uchar_t writeAddr, uchar_t *pBuff)
uchar_t regAddr;
unsigned short i;
if (pBuff == NULL)
  return  error;
       regAddr  = writeAddr;
START_GYRO();
  return error;
  return error;
     BYTE_SND_GYRO(*pBuff);
     SND_ACK_GYRO();
return ok;
void InitMPU6050(void)
     delay_ms(500);
    uchar_t gyro_value2;
   gyro_value2=0x00;
   write_GYRO_register(SlaveAddress,PWR_M1,&gyro_value2,1);
    delay_ms(10);
   gyro_value2=0x07;
   write_GYRO_register(SlaveAddress,SMPL,&gyro_value2,1);
   delay_ms(10);
   gyro_value2=0x06;
   write_GYRO_register(SlaveAddress,DLPF,&gyro_value2,1);
   delay_ms(10);
   gyro_value2=0x18;
   write_GYRO_register(SlaveAddress,GYRO_CONFIG,&gyro_value2,1);
   delay_ms(10);
   gyro_value2=0x01;
   write_GYRO_register(SlaveAddress,ACCEL_CONFIG,&gyro_value2,1);
   delay_ms(10);
    /*uchar_t add,gyro_value1;
    for(add=25;add<118;add++)
      read_GYRO_register(SlaveAddress,add,&gyro_value1,1);
      printf("REG_VALUE=%x %x\r\n",add,gyro_value1);
   delay_ms(10);
//  write_GYRO_register(SlaveAddress,PWR_M1,0x80,1);
#if 0
    delay_ms(1000);
   write_GYRO_register(SlaveAddress,PWR_M1,0x00,1);
    delay_ms(10);
   delay_ms(10);
   write_GYRO_register(SlaveAddress,SMPL,0x07,1);
   delay_ms(10);
   write_GYRO_register(SlaveAddress,DLPF,0x06,1);
   delay_ms(10);
   write_GYRO_register(SlaveAddress,GYRO_CONFIG,0x18,1);
   delay_ms(10);
   write_GYRO_register(SlaveAddress,ACCEL_CONFIG,0x01,1);
   delay_ms(10);
   write_GYRO_register(SlaveAddress,INT_CONFIG,0x00,1);
   delay_ms(10);
#endif
//合成数据
/*ushort_t GetData(uchar_t REG_Address)
uchar_t H,L;
H=read_GYRO_register(REG_Address);
L=read_GYRO_register(REG_Address+1);
return (H<<8)+L;   //合成数据
/*float SqrtByNewton(float x)
    float val = x;//最终
    float last;//保存上一个计算的值
    do
        last = val;
        val =(val + x/val) / 2;
    }while(Abs(val-last) > eps);
    return val;
float Sqrt(float x)
    float xhalf = 0.5f * x;
    int i = *(int*)&x;
    i = 0x5f375a86 - (i>>1);
    x = *(float*)&i;
    x = x*(1.5f-xhalf*x*x);
    printf("GYRO_XOUT=%.2f \r\n",1/x);
    return 1/x;
double atan(double x)
//atan(x)=x-x^3/3+x^5/5-x^7/7+.....(-1<x<1)
//return:[-pi/2,pi/2]
    double mult,sum,xx;
    sum=0;
    if(x==1){
        return PI/4;
    if(x==-1){
        return -PI/4;
    if((x>1||x<-1))
        mult=1/x;
        mult=x;
    xx=mult*mult;
    for(int i=1;i<200;i+=2){
        sum+=mult*((i+1)%4==0?-1:1)/i;
        mult*=xx;
    if(x>1||x<-1){
        return PI/2-sum;
    else{
        return sum;
  /*union UNIVOLTAGE
     float fVoltage;
     char voltage4Byte[4];
  UNIVOLTAGE vtg;
// char RS232ComBuf[4096];
// strcpy(vtg.voltage4Byte, RS232ComBuf);
  //printf("%f", vtg.fVoltage);
void display_who(void)
    uchar_t gyro_value;
    read_GYRO_register(SlaveAddress,WHO,&gyro_value,1);
    printf("WHO=%02x\r\n",gyro_value);
    //lcd_printf(dis, dis_data);     //转换数据显示
    //DisplayListChar(2,0,dis,4);    //启始列,行,显示数组,显示长度
//显示x轴
void display_x(void)
     uchar_t gyro_value1=0,gyro_value2=0;
     ushort_t gyro_value3=0,gyro_value4=0;
     sshort_t data=0;
  float x;
  double y;
    read_GYRO_register(SlaveAddress,GX_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,GX_H,&gyro_value2,1);
gyro_value3=gyro_value1;
gyro_value4=gyro_value2;
    data=(sshort_t)((gyro_value4<<8)+gyro_value3);   //合成数据
   // data=data/16.4;
       printf("GYRO_XOUT=%d \r\n",data);
   x=Sqrt(Abs(data));
       y=atan(1);
  vtg.fVoltage=y;
  sprintf("changeGYRO_XOUT=%f\r\n", vtg.fVoltage);
        //printf("changeGYRO_XOUT=%d %d \r\n",y,(y*180)/PI);
          //printf("sshort_t=%d \r\n",sizeof(sshort_t));
    //data/=16.4;              //计算对应 度/秒
       // printf("changeGYRO_XOUT=%d\r\n",data);
    /*printf("\r\n");
    lcd_printf(dis, data);     //转换数据显示
    printf("changedataGYRO_XOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//显示y轴
void display_y(void)
     sshort_t data=0;
  read_GYRO_register(SlaveAddress,GY_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,GY_H,&gyro_value2,1);
    //data=data/16.4;
    printf("GYRO_YOUT=%d \r\n",data);
   // dis_data/=16.4;              //计算对应 度/秒
  /*     printf("\r\n");
    printf("changedataGYRO_YOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//显示z轴
void display_z(void)
     sshort_t data=0;
  read_GYRO_register(SlaveAddress,GZ_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,GZ_H,&gyro_value2,1);
    //data=data/16.4;
    printf("GYRO_ZOUT=%d \r\n",data);
  /*  printf("\r\n");
//dis_data/=16.4;                //计算对应 度/秒
    printf("changedataGYRO_ZOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//显示x_g轴
void display_x_g(void)
     sshort_t data=0;
  read_GYRO_register(SlaveAddress,AUX_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,AUX_H,&gyro_value2,1);
    data=(gyro_value4<<8)|gyro_value3;   //合成数据
    //data=data/16384;
    printf("GYRO_AUXOUT=%d\r\n",data);
/*     printf("\r\n");
    printf("changedataGYRO_AUXOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//显示y轴
void display_y_g(void)
     sshort_t data=0;
    read_GYRO_register(SlaveAddress,AUY_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,AUY_H,&gyro_value2,1);
    //data=data/16384;
    printf("GYRO_AUYOUT=%d\r\n",data);
   /* printf("\r\n");
//显示z轴
void display_z_g(void)
     sshort_t data=0;
    read_GYRO_register(SlaveAddress,AUZ_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,AUZ_H,&gyro_value2,1);
    //data=data/16384;
    printf("GYRO_AUZOUT=%d\r\n",data);
  /*  printf("\r\n");
//显示TEM
void display_tem(void)
    uchar_t fanwei1=0,fanwei2=0;
     sshort_t data=0;
    sshort_t Temperature=0;
    read_GYRO_register(SlaveAddress,TMP_L,&gyro_value1,1);
delay_ms(1);
    read_GYRO_register(SlaveAddress,TMP_H,&gyro_value2,1);
   Temperature = 35+ ((sshort_t) (data + 13200)) / 280; // 计算出温度
    printf("GYRO_TEMPOUT=%d\r\n",Temperature);
      //write_GYRO_register(SlaveAddress,0x19,0x07,1);
//  delay_ms(10);
      //printf("accset=%x\r\n",fanwei);
      read_GYRO_register(SlaveAddress,0x1b,&fanwei1,1);
      printf("GYRO_CONFIG_1B=%x\r\n",fanwei1);
   delay_ms(1);
      read_GYRO_register(SlaveAddress,0x1c,&fanwei2,1);
      printf("ACCEL_CONFIG_1C=%x\r\n",fanwei2);
     printf("\r\n");
/*      printf("\r\n");
    printf("changedataGYRO_TEMPOUT=%s %s %s %s %s %s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//整数转字符串
void lcd_printf(uchar_t *s,int temp_data)
if(temp_data<0)
  temp_data=-temp_data;
  *s='-';
else *s=' ';
*++s =temp_data/10000+0x30;
temp_data=temp_data%10000;     //取余运算
*++s =temp_data/1000+0x30;
temp_data=temp_data%1000;     //取余运算
*++s =temp_data/100+0x30;
temp_data=temp_data%100;     //取余运算
*++s =temp_data/10+0x30;
temp_data=temp_data%10;      //取余运算
*++s =temp_data+0x30;
void IIC_init(void)
twi_options_t optsfp;
pmc_enable_periph_clk(BOARD_ID_TWI1);
optsfp.master_clk = sysclk_get_cpu_hz();
optsfp.speed      = TWI_CLK;
if (twi_master_init(BOARD_BASE_TWI1, &optsfp) != TWI_SUCCESS)
  puts("-E-\tTWI0 master initialization failed.\r");
uint8_t read_GYRO_register(uint8_t slave_addr, uint8_t reg_addr, uint8_t *reg_value, uint32_t reg_len)
twi_packet_t packet_sfp_rx;
delay_ms(1);
packet_sfp_rx.chip         = slave_addr >> 1;
packet_sfp_rx.addr[0]      = reg_addr;
packet_sfp_rx.addr_length  = TWI_MEM_ADDR_LENGTH;
packet_sfp_rx.buffer       = reg_value;
packet_sfp_rx.length       = reg_len;
  return twi_master_read(BOARD_BASE_TWI1, &packet_sfp_rx);
uint8_t write_GYRO_register(uint8_t slave_addr, uint8_t reg_addr, uint8_t *reg_value, uint32_t reg_len)
twi_packet_t packet_sfp_tx;
packet_sfp_tx.chip         = slave_addr >> 1;
packet_sfp_tx.addr[0]      = reg_addr;
packet_sfp_tx.addr_length  = TWI_MEM_ADDR_LENGTH;
packet_sfp_tx.buffer       = reg_value;
packet_sfp_tx.length       = reg_len;
  return twi_master_write(BOARD_BASE_TWI1, &packet_sfp_tx);
收藏收藏1 分享淘帖 顶 踩
