- // F500_SPI0_EEPROM_Polled_Mode.c
- // Copyright 2008 Silicon Laboratories, Inc.
- // Program Description:
- // This program accesses a SPI EEPROM using polled mode access. The 'F500 MCU
- // is configured in 4-wire Single Master Mode, and the EEPROM is the only
- // slave device connected to the SPI bus. The read/write operations are
- // tailored to access a Microchip 4 kB EEPROM 25LC320. The relevant hardware
- // connections of the 'F500 MCU are shown here:
- // P0.0 - SPI SCK (digital output, push-pull)
- // P0.1 - SPI MISO (digital input, open-drain)
- // P0.2 - SPI MOSI (digital output, push-pull)
- // P0.3 - SPI NSS (digital output, push-pull)
- // P0.4 - UART TXD (digital output, push-pull)
- // P0.5 - UART RXD (digital input, open-drain)
- // P1.3 - LED (digital output, push-pull)
- // How To Test:
- // Method1:
- // 1) Download the code to a 'F500 device that is connected as above.
- // 2) Run the code. The LED will blink fast during the write/read/verify
- // operations.
- // 3) If the verification passes, the LED will blink slowly. If it fails,
- // the LED will be OFF.
- // Method2 (optional):
- // 1) Download code to a 'F500 device that is connected as above
- // 2) Connect USB cable from the development board to a PC
- // 3) On the PC, open HyperTerminal (or any other terminal program) and connect
- // to the USB port (virtual com port) at <BAUDRATE>, 8 data bits, no parity,
- // 1 stop bit, no flow control.
- // 4) HyperTerminal will print the progress of the write/read operation, and in
- // the end will print the test result as pass or fail. Additionally, if the
- // verification passes, the LED will blink slowly. If it fails, the LED will
- // be OFF.
- // Target: C8051F500 (Side A of a C8051F500-TB)
- // Tool chain: Keil C51 8.0 / Keil EVAL C51
- // Command Line: None
- // Release 1.0 / 06 MAR 2008 (GP)
- // -Initial Revision
- // Includes
- #include <compiler_defs.h>
- #include <C8051F500_defs.h> // SFR declarations
- #include <stdio.h> // printf is declared here
- // Global Constants
- #define BAUDRATE 115200 // Baud rate of UART in bps
- #define SYSCLK 24000000 // Internal oscillator frequency in Hz
- // Microchip 25AA320 Slave EEPROM Parameters
- #define F_SCK_MAX 2000000 // Max SCK freq (Hz)
- #define T_NSS_DISABLE_MIN 500 // Min NSS disable time (ns)
- #define EEPROM_CAPACITY 4096 // EEPROM capacity (bytes)
- // EEPROM Instruction Set
- #define EEPROM_CMD_READ 0x03 // Read Command
- #define EEPROM_CMD_WRITE 0x02 // Write Command
- #define EEPROM_CMD_WRDI 0x04 // Reset Write Enable Latch Command
- #define EEPROM_CMD_WREN 0x06 // Set Write Enable Latch Command
- #define EEPROM_CMD_RDSR 0x05 // Read Status Register Command
- #define EEPROM_CMD_WRSR 0x01 // Write Status Register Command
- SBIT (LED, SFR_P1, 3); // LED==1 means ON
- // Function Prototypes
- void PCA0_Init (void);
- void OSCILLATOR_Init (void);
- void PORT_Init (void);
- void TIMER2_Init (void);
- void UART0_Init (void);
- void SPI0_Init (void);
- void Init_Device (void);
- void Delay_us (U8 time_us);
- void Delay_ms (U8 time_ms);
- void EEPROM_Write (U16 address, U8 value);
- U8 EEPROM_Read (U16 address);
- // main() Routine
- void main (void)
- U16 address; // EEPROM address
- U8 test_byte; // Used as a temporary variable
- Init_Device (); // Initializes hardware peripherals
- // The following code will test the EEPROM by performing write/read/verify
- // operations. The first test will write 0xFFs to the EEPROM, and the
- // second test will write the LSBs of the EEPROM addresses.
- SFRPAGE = ACTIVE_PAGE; // Set for printf()
- // Fill EEPROM with 0xFF's
- LED = 1;
- printf("Filling with 0xFF's...\n");
- for (address = 0; address < EEPROM_CAPACITY; address++)
- test_byte = 0xFF;
- EEPROM_Write (address, test_byte);
- // Print status to UART0
- if ((address % 16) == 0)
- printf ("\nWriting 0x%04x: %02x ", address, (U16)test_byte);
- LED = !LED;
- else
- printf ("%02x ", (U16)test_byte);
- // Verify EEPROM with 0xFF's
- printf("\n\nVerifying 0xFF's...\n");
- test_byte = EEPROM_Read (address);
- printf ("\nVerifying 0x%04x: %02x ", address, (U16)test_byte);
- LED = !LED;
- else
- if (test_byte != 0xFF)
- LED = 0;
- printf ("Error at %u\n", address);
- while (1); // Stop here on error (for debugging)
- // Fill EEPROM with LSB of EEPROM addresses
- printf("\n\nFilling with LSB of EEPROM addresses...\n");
- test_byte = address & 0xFF;
- LED = !LED;
- else
- // Verify EEPROM with LSB of EEPROM addresses
- printf("\n\nVerifying LSB of EEPROM addresses...\n");
- // print status to UART0
- LED = !LED;
- else
- if (test_byte != (address & 0xFF))
- LED = 0;
- printf ("\n\nVerification success!\n");
- while (1) // Loop forever
- LED = !LED; // Flash LED when done (all verified)
- Delay_ms (200);
- // Initialization Subroutines
- // PCA0_Init
- // Return Value : None
- // Parameters : None
- // This function disables the watchdog timer.
- U8 SFRPAGE_save = SFRPAGE;
- PCA0MD &= ~0x40;
- SFRPAGE = SFRPAGE_save;
- // OSCILLATOR_Init
- // This function initializes the system clock to use the internal oscillator
- // at 24 MHz.
- SFRPAGE = CONFIG_PAGE;
- OSCICN = 0x87;
- // PORT_Init
- // This function configures the crossbar and GPIO ports.
- // P0.0 - SCK (SPI0), Push-Pull, Digital
- // P0.1 - MISO (SPI0), Open-Drain, Digital
- // P0.2 - MOSI (SPI0), Push-Pull, Digital
- // P0.3 - NSS (SPI0), Push-Pull, Digital
- // P0.4 - TX0 (UART0), Push-Pull, Digital
- // P0.5 - RX0 (UART0), Open-Drain, Digital
- // P1.3 - Skipped, Push-Pull, Digital (LED D2 on Target Board)
- // P1.4 - Skipped, Open-Drain, Digital (Switch S2 on Target Board)
- P0MDOUT = 0x1D; // Configure P0.0/2/3/4 to push-pull
- P1MDOUT = 0x08; // Configure P1.3 to push-pull
- P1SKIP = 0x18; // Skip P1.3 and P1.4 on the crossbar
- XBR0 = 0x05; // Enable SPI and UART0 on crossbar
- XBR2 = 0x40; // Enable crossbar
- // TIMER2_Init
- // Initializes Timer2 to be clocked by SYSCLK for use as a delay timer.
- // CKCON is available on all pages
- CKCON |= 0x10;
- // UART0_Init
- // Configure the UART0 using Baudrate generator, for <BAUDRATE1> and 8-N-1.
- SCON0 = 0x10; // SCON0: 8-bit variable bit rate
- // clear RI0 and TI0 bits
- // Baud Rate = [BRG Clock / (65536 - (SBRLH0:SBRLL0))] x 1/2 x 1/Prescaler
- #if ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 1)
- SBRL0 = -(SYSCLK / BAUDRATE / 2);
- SBCON0 |= 0x03; // Set prescaler to 1
- #elif ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 4)
- SBRL0 = -(SYSCLK / BAUDRATE / 2 / 4);
- SBCON0 &= ~0x03;
- SBCON0 |= 0x01; // Set prescaler to 4
- #elif ((SYSCLK / BAUDRATE / 2 / 0xFFFF) < 12)
- SBRL0 = -(SYSCLK / BAUDRATE / 2 / 12);
- SBCON0 &= ~0x03; // Set prescaler to 12
- #else
- SBRL0 = -(SYSCLK / BAUDRATE / 2 / 48);
- SBCON0 &= ~0x03;
- SBCON0 |= 0x02; // Set prescaler to 48
- #endif
- SBCON0 |= 0x40; // Enable baud rate generator
- TI0 = 1; // Indicate TX0 ready
- // SPI0_Init
- // Configures SPI0 to use 4-wire Single-Master mode. The SPI timing is
- // configured for Mode 0,0 (data centered on first edge of clock phase and
- // SCK line low in idle state). The SPI clock is set to 1.75 MHz. The NSS pin
- // is set to 1.
- void SPI0_Init()
- SPI0CFG = 0x40; // Enable the SPI as a Master
- // CKPHA = '0', CKPOL = '0'
- SPI0CN = 0x0D; // 4-wire, single master mode
- // SPI0 enable
- // The equation for SPI0CKR is (SYSCLK/(2*F_SCK_MAX))-1, but this yields
- // a SPI frequency that is slightly more than 2 MHz. But, 2 MHz is the max
- // frequency spec of the EEPROM used here. So, the "-1" term is omitted
- // in the following usage:
- SPI0CKR = (SYSCLK / (2 * F_SCK_MAX));
- // Init_Device
- // Calls all device initialization functions.
- PCA0_Init ();
- OSCILLATOR_Init ();
- PORT_Init ();
- TIMER2_Init ();
- UART0_Init ();
- SPI0_Init ();
- // Support Subroutines
- // Delay_us
- // Parameters : 1. time_us - time delay in microseconds
- // range: 1 to 255
- // Creates a delay for the specified time (in microseconds) using TIMER2. The
- // time tolerance is approximately +/-50 ns (1/SYSCLK + function call time).
- TR2 = 0; // Stop timer
- TF2H = 0; // Clear timer overflow flag
- TMR2 = -((U16)(SYSCLK / 1000000) * (U16)(time_us));
- TR2 = 1; // Start timer
- while (!TF2H); // Wait till timer overflow occurs
- // Delay_ms
- // Parameters : 1. time_ms - time delay in milliseconds
- // Creates a delay for the specified time (in milliseconds) using TIMER2. The
- U8 i;
- while(time_ms--)
- for(i = 0; i< 10; i++) // 10 * 100 microsecond delay
- Delay_us (100);
- // EEPROM_Write
- // Parameters : 1. address - the destination EEPROM address.
- // range: 0 to EEPROM_CAPACITY
- // 2. value - the value to write.
- // range: 0x00 to 0xFF
- // Writes one byte to the specified address in the EEPROM. This function polls
- // the EEPROM status register after the write operation, and returns only after
- // the status register indicates that the write cycle is complete. This is to
- // prevent from having to check the status register before a read operation.
- // Writing a byte to the EEPROM is a five-step operation.
- // Step1: Set the Write Enable Latch to 1
- NSSMD0 = 0; // Step1.1: Activate Slave Select
- SPI0DAT = EEPROM_CMD_WREN; // Step1.2: Send the WREN command
- while (!SPIF); // Step1.3: Wait for end of transfer
- SPIF = 0; // Step1.4: Clear the SPI intr. flag
- NSSMD0 = 1; // Step1.5: Deactivate Slave Select
- Delay_us (1); // Step1.6: Wait for at least
- // T_NSS_DISABLE_MIN
- // Step2: Send the WRITE command
- NSSMD0 = 0;
- SPI0DAT = EEPROM_CMD_WRITE;
- while (!SPIF);
- SPIF = 0;
- // Step3: Send the EEPROM destination address (MSB first)
- SPI0DAT = (U8)((address >> 8) & 0x00FF);
- while (!SPIF);
- SPIF = 0;
- SPI0DAT = (U8)(address & 0x00FF);
- while (!SPIF);
- SPIF = 0;
- // Step4: Send the value to write
- SPI0DAT = value;
- while (!SPIF);
- SPIF = 0;
- NSSMD0 = 1;
- Delay_us (1);
- // Step5: Poll on the Write In Progress (WIP) bit in Read Status Register
- do
- NSSMD0 = 0; // Activate Slave Select
- SPI0DAT = EEPROM_CMD_RDSR; // Send the Read Status Register command
- while (!SPIF); // Wait for the command to be sent out
- SPIF = 0;
- SPI0DAT = 0; // Dummy write to output serial clock
- while (!SPIF); // Wait for the register to be read
- SPIF = 0;
- NSSMD0 = 1; // Deactivate Slave Select after read
- Delay_us (1);
- } while((SPI0DAT & 0x01) == 0x01);
- // EEPROM_Read
- // Return Value : The value that was read from the EEPROM
- // Parameters : 1. address - the source EEPROM address.
- // Reads one byte from the specified EEPROM address.
- U8 spi_data;
- // Reading a byte from the EEPROM is a three-step operation.
- // Step1: Send the READ command
- SPI0DAT = EEPROM_CMD_READ;
- while (!SPIF);
- SPIF = 0;
- // Step2: Send the EEPROM source address (MSB first)
- while (!SPIF);
- SPIF = 0;
- while (!SPIF);
- SPIF = 0;
- // Step3: Read the value returned
- while (!SPIF); // Wait for the value to be read
- SPIF = 0;
- Delay_us (1);
- spi_data = SPI0DAT; // Read data before restoring SFR page
- return spi_data;
- #ifdef SDCC
- // SDCC does not include a definition for putchar(), which is used in printf()
- // and so it is defined here. The prototype does not need to be explicitly
- // defined because it is provided in stdio.h
- // putchar
- // Parameters : character to send to UART
- // This function outputs a character to the UART.
- void putchar (char input)
- if (output == '\n')
- while (!TI0);
- TI0 = 0;
- SBUF0 = 0x0d;
- while (!TI0);
- TI0 = 0;
- SBUF0 = output;
- #endif
- // End Of File
