查看: 1428|回复: 0
ModelSim仿真源代码
ID:294494 发表于 2018-3-20 15:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Counter的源代码:
module lin(clk,rst,in1,in2,cin,count,sum);
input [7:0]in1,in2;
input clk,rst,cin;
output [7:0]sum;
output count;
reg [7:0]sum;
reg count;
always @(posedge clk)
begin
if(!rst)
begin
count<=0;
sum<=8'b0;
end
sum<=in1+in2+cin;
if(sum>=8'b11111111)
count<=1;
count<=0;
end
endmodule
Tcounter的源代码:
`timescale 10ns/1ns
module tcounter;
reg clk1, rst1,cin1;
reg[7:0] din1,din2;
wire count1;
wire[7:0] sum1;
lin  adder (  .cin   (cin1),
             .in1  (din1),
             .in2  (din2),
             .clk   (clk1),
             .rst  (rst1),
             .sum   (sum1),
             .count (count1)
initial   // Clock generator
  begin
    clk1 = 0;
  forever #10 clk1 = ~clk1;
  end
   initial
                begin
                        #0                rst1 = 1'b0;
                        #0.5                rst1 = 1'b1;
                        #22                rst1 = 1'b0;
                end
always @ ( negedge clk1 )
                begin
                        din1 = $random%256;
         din2 = $random%256;
         cin1  = $random%2;
                end
                endmodule
