查看: 1477|回复: 1
51 1602液晶模块
ID:298856 发表于 2018-3-29 13:56 | 显示全部楼层 |阅读模式
#include<reg52.h>
uchar code table[]="tu rang shi du:";
sbit lcden=P3^4;
sbit lcdrs=P3^5;//òo¾§êy¾YÃüáîÑ¡Ôñ¶Ë¿ú;
sbit dula=P2^6;
sbit wela=P2^7;
uchar num;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        dula=0;
        wela=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        init();
        write_com(0x80+0x10);
        for(num=0;num<15;num++)
                write_data(table[num]);
                delay(5);
        for(num=0;num<16;num++)
                write_com(0x18);
                delay(300);
        while(1);
/*51单片机1602液晶显示模块代码*/
ID:298856 发表于 2018-3-29 13:58 | 显示全部楼层
很不错  郭天祥书上代码
