基于stm8的ds1302模块千万别把数据写在第3个区,不然卡就锁住了,只能写在第2个区
电路原理图如下:
stm8单片机源码:
- /* Includes ------------------------------------------------------------------*/
- #include "stm8s.h"
- #include "stm8s_clk.h"
- #include "intrinsics.h"
- #include "stm8s_uart1.h"
- #include "uart.h"
- #include "rc522.h"
- #include "string.h"
- #include "IWDG.h"
- #include "tim2.h"
- #include "1602i2c.h"
- void Delay(u32 nCount);
- extern u8 RxBuffer[RxBufferSize];
- extern u8 UART_RX_NUM;
- extern int time2;
- extern int tim2test;
- extern int tim2test1;
- unsigned char CT[2];//卡类型
- unsigned char SN[4]; //卡号
- unsigned char M1UID[8]={0x2e,0x55,0,0,0,0,0,0};//读卡器向上发送,读到卡后自动发
- extern unsigned char controlflag;//接收到控制LED beep指令标志 01表示收到
- extern unsigned char sendflag;//发送标志 =1表示还未发送过 =0表示已经发送一次 等待回复 如果超时重新发送
- unsigned char write[16] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10};
- unsigned char read[16] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- extern unsigned char receive[8];
- u8 read_flag=0;//读卡标志位 1;读到卡 0;还没读到卡
- u8 time_flag=0;//超时标志 0;未超时 1:超时
- //unsigned char key[6] = {0x19,0x84,0x07,0x15,0x76,0x14};
- unsigned char key[6] = {0xff,0xff,0xff,0xff,0xff,0xff};
- int sum=0;
- //unsigned char key[6] = {0x00,0x00,0x00,0x00,0x00,0x00};
- /* Private macro -------------------------------------------------------------*/
- #define countof(a) (sizeof(a) / sizeof(*(a)))
- #define BufferSize (countof(Tx_Buffer)-1)
- /* Private variables ---------------------------------------------------------*/
- u8 Tx_Buffer[] = "请刷卡";
- u8 Rx_Buffer[BufferSize];
- u32 FLASH_ID ;
- /* Private defines -----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- void cardNo2String(u8 *cardNo, u8 *str);
- /* Private functions ---------------------------------------------------------*/
- #define ReadWriteAddr 3 //读写扇区
- void SN_UID(void)
- unsigned int tempUID;
- M1UID[2]=SN[0];
- M1UID[3]=SN[1];
- M1UID[4]=SN[2];
- M1UID[5]=SN[3];
- tempUID=M1UID[1]+M1UID[2]+M1UID[3]+M1UID[4]+M1UID[5];
- M1UID[6]=tempUID&0x00ff;
- M1UID[7]=tempUID>>8;
- void rxfromPIC(void)
- u8 i;
- sum=receive[1]+receive[2]+receive[3]+receive[4]+receive[5];
- if((receive[0]==0x7e)&&(receive[1]==0x55)&&(receive[6]==(sum&0x00ff))&&(receive[7]==(sum&0xff00)>>8))
- read_flag=0;
- if(receive[2]==0x01)
- else if(receive[2]!=0x01)
- if(receive[3]==0x01)
- else if(receive[3]!=0x01)
- if(receive[4]==0x01)
- receive[0]=0x7e;
- UART1_SendString(receive, 8);
- for(i=2;i<8;i++)
- M1UID[i]=0;
- tim2test1=0;//启动计时
- for(i=0;i<8;i++)
- receive[i]=0;
- if(tim2test1>5000)//超时全部关闭
- tim2test1=0;
- // GPIO_HIGH(GPIOD, GPIO_PIN_3);
- // GPIO_HIGH(GPIOD, GPIO_PIN_7);
- // GPIO_LOW(GPIOD, GPIO_PIN_2);
- void main(void)
- unsigned char status;
- /*设置内部时钟16M为主时钟*/
- CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV2);
- status = memcmp(read,write,16);//清0
- InitRc522();//rc522初始化
- sendflag=1;
- I2C1602_Configuration();
- init1602_i2c();
- __enable_interrupt();//开启总中断
- write[0] =1;//
- write[1] =3;//
- write[2] =2;//
- write[3] =6;//
- write[4] =7;//
- write[5] =7;//
- write[6] =6;//
- write[7] =0;//
- write[8] =2;//
- write[9] =8;//
- write[10] =5;//
- ///////////////// 要写入的值,最多16个///////
- while(1)
- status = PcdRequest(PICC_REQALL,CT); // 扫描卡
- status= PcdAnticoll(SN);
- //防冲撞
- rxfromPIC();
- if (status==MI_OK)
- SN_UID();
- status = PcdSelect(SN); //选择要操作的卡
- if( MI_OK == PcdAuthState(0x61,ReadWriteAddr,key,SN) ) //验证A密码
- // status = PcdWrite(2,write);//写入M1卡第2块块数据
- status = PcdRead(2,read);//读取M1卡第2块块数据
- if(MI_OK == status)
- zl_i2c(0x80);
- sj_i2c(0x30+ read[0]);
- sj_i2c(0x30+ read[1]);
- sj_i2c(0x30+ read[2]);
- sj_i2c(0x30+ read[3]);
- sj_i2c(0x30+ read[4]);
- sj_i2c(0x30+ read[5]);
- sj_i2c(0x30+ read[6]);
- sj_i2c(0x30+ read[7]);
- sj_i2c(0x30+ read[8]);
- sj_i2c(0x30+ read[9]);
- sj_i2c(0x30+ read[10]);
- /* Decrement nCount value */
- while (nCount != 0)
- nCount--;
- void Hex2String(u8 hex,u8 *str)
- str[0] = (hex / 100) + '0';
- str[1] = (hex % 100 / 10) + '0';
- str[2] = (hex % 10) + '0';
- u8 Count = 0;
- for(Count = 0; Count < 4; Count++)
- Hex2String(cardNo[Count], str + Count * 4);
- if(Count == 3)
- str[15] = '\n';
- else
- str[Count * 4 + 3] = ':';
- …………限于本文篇幅 余下代码请从51黑下载附件…………
第5周任务及代码.rar
(15.54 MB, 下载次数: 209)
