Si443是Silicon labs公司专门针对中国市场推出的一款无线收发神器。其工作频段是425MHz到525MHz。这款芯片的技术参数如下:
参数名称 SI4432 SI4463 SI4438
频率范围 240~960MHz 142-175,284-250 424-525MHz
420-525 850-1050
接收灵敏度 -121dBm -126dBm -124dBm
发射功率 +20Db +21Db +20Db
关机电流 50nA 30nA 30nA
待机电流 800nA 50nA 50nA
DATA速率 0.123~256K 0.123~1M 0.1~500k
接收电流 18.5mA 10.0/14mA 14mA
发射电流 85mA 70-80mA 70-75mA
TX/ RX FIFO 64byte 64byte 64byte
- /*! @file radio_config.h
- * @brief This file contains the automatically generated
- * configurations.
- * @n WDS GUI Version: 3.2.11.0
- * @n Device: Si4438 Rev.: B1
- * @b COPYRIGHT
- * @n Silicon Laboratories Confidential
- * @n Copyright 2017 Silicon Laboratories, Inc.
- #ifndef RADIO_CONFIG_H_
- #define RADIO_CONFIG_H_
- // USER DEFINED PARAMETERS
- // Define your own parameters here
- // INPUT DATA
- // Crys_freq(Hz): 30000000 Crys_tol(ppm): 20 IF_mode: 2 High_perf_Ch_Fil: 1 OSRtune: 0 Ch_Fil_Bw_AFC: 0 ANT_DIV: 0 PM_pattern: 0
- // MOD_type: 2 Rsymb(sps): 10000 Fdev(Hz): 20000 RXBW(Hz): 150000 Manchester: 0 AFC_en: 0 Rsymb_error: 0.0 Chip-Version: 2
- // RF Freq.(MHz): 490 API_TC: 29 fhst: 250000 inputBW: 0 BERT: 0 RAW_dout: 0 D_source: 0 Hi_pfm_div: 1
- // # RX IF frequency is -468750 Hz
- // # WB filter 3 (BW = 92.61 kHz); NB-filter 3 (BW = 92.61 kHz)
- // Modulation index: 4
- // CONFIGURATION PARAMETERS
- #define RADIO_CONFIGURATION_DATA_RADIO_XO_FREQ 30000000L
- #define RADIO_CONFIGURATION_DATA_CHANNEL_NUMBER 0x04
- #define RADIO_CONFIGURATION_DATA_RADIO_PACKET_LENGTH 0x07
- #define RADIO_CONFIGURATION_DATA_RADIO_STATE_AFTER_POWER_UP 0x03
- #define RADIO_CONFIGURATION_DATA_RADIO_DELAY_CNT_AFTER_RESET 0xF000
- #define RADIO_CONFIGURATION_DATA_CUSTOM_PAYLOAD {0xC5, 0xC5, 0xC5, 0xC5, 0xC5, 0xC5, 0xC5}
- // CONFIGURATION COMMANDS
- // Command: RF_POWER_UP
- // Description: Command to power-up the device and select the operational mode and functionality.
- #define RF_POWER_UP 0x02, 0x01, 0x00, 0x01, 0xC9, 0xC3, 0x80
- // Command: RF_GPIO_PIN_CFG
- // Description: Configures the GPIO pins.
- #define RF_GPIO_PIN_CFG 0x13, 0x04, 0x10, 0x00, 0x00, 0x14, 0x00, 0x00
- // Set properties: RF_GLOBAL_XO_TUNE_2
- // Number of properties: 2
- // Group ID: 0x00
- // Start ID: 0x00
- // Default values: 0x40, 0x00,
- // Descriptions:
- // GLOBAL_XO_TUNE - Configure the internal capacitor frequency tuning bank for the crystal oscillator.
- // GLOBAL_CLK_CFG - Clock configuration options.
- #define RF_GLOBAL_XO_TUNE_2 0x11, 0x00, 0x02, 0x00, 0x52, 0x00
- // Set properties: RF_GLOBAL_CONFIG_1
- // Number of properties: 1
- // Group ID: 0x00
- // Start ID: 0x03
- // Default values: 0x20,
- // Descriptions:
- // GLOBAL_CONFIG - Global configuration settings.
- #define RF_GLOBAL_CONFIG_1 0x11, 0x00, 0x01, 0x03, 0x60
- // Set properties: RF_INT_CTL_ENABLE_2
- // Group ID: 0x01
- // Start ID: 0x00
- // Default values: 0x04, 0x00,
- // Descriptions:
- // INT_CTL_ENABLE - This property provides for global enabling of the three interrupt groups (Chip, Modem and Packet Handler) in order to generate HW interrupts at the NIRQ pin.
- // INT_CTL_PH_ENABLE - Enable individual interrupt sources within the Packet Handler Interrupt Group to generate a HW interrupt on the NIRQ output pin.
- #define RF_INT_CTL_ENABLE_2 0x11, 0x01, 0x02, 0x00, 0x01, 0x38
- // Set properties: RF_FRR_CTL_A_MODE_4
- // Number of properties: 4
- // Group ID: 0x02
- // Start ID: 0x00
- // Default values: 0x01, 0x02, 0x09, 0x00,
- // Descriptions:
- // FRR_CTL_A_MODE - Fast Response Register A Configuration.
- // FRR_CTL_B_MODE - Fast Response Register B Configuration.
- // FRR_CTL_C_MODE - Fast Response Register C Configuration.
- // FRR_CTL_D_MODE - Fast Response Register D Configuration.
- #define RF_FRR_CTL_A_MODE_4 0x11, 0x02, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_PREAMBLE_TX_LENGTH_9
- // Number of properties: 9
- // Group ID: 0x10
- // Start ID: 0x00
- // Default values: 0x08, 0x14, 0x00, 0x0F, 0x21, 0x00, 0x00, 0x00, 0x00,
- // Descriptions:
- // PREAMBLE_TX_LENGTH - Configure length of TX Preamble.
- // PREAMBLE_CONFIG_STD_1 - Configuration of reception of a packet with a Standard Preamble pattern.
- // PREAMBLE_CONFIG_NSTD - Configuration of transmission/reception of a packet with a Non-Standard Preamble pattern.
- // PREAMBLE_CONFIG_STD_2 - Configuration of timeout periods during reception of a packet with Standard Preamble pattern.
- // PREAMBLE_CONFIG - General configuration bits for the Preamble field.
- // PREAMBLE_PATTERN_31_24 - Configuration of the bit values describing a Non-Standard Preamble pattern.
- // PREAMBLE_PATTERN_23_16 - Configuration of the bit values describing a Non-Standard Preamble pattern.
- // PREAMBLE_PATTERN_15_8 - Configuration of the bit values describing a Non-Standard Preamble pattern.
- // PREAMBLE_PATTERN_7_0 - Configuration of the bit values describing a Non-Standard Preamble pattern.
- #define RF_PREAMBLE_TX_LENGTH_9 0x11, 0x10, 0x09, 0x00, 0x08, 0x14, 0x00, 0x0F, 0x31, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_SYNC_CONFIG_5
- // Number of properties: 5
- // Group ID: 0x11
- // Start ID: 0x00
- // Default values: 0x01, 0x2D, 0xD4, 0x2D, 0xD4,
- // Descriptions:
- // SYNC_CONFIG - Sync Word configuration bits.
- // SYNC_BITS_31_24 - Sync word.
- // SYNC_BITS_23_16 - Sync word.
- // SYNC_BITS_15_8 - Sync word.
- // SYNC_BITS_7_0 - Sync word.
- #define RF_SYNC_CONFIG_5 0x11, 0x11, 0x05, 0x00, 0x01, 0xB4, 0x2B, 0x00, 0x00
- // Set properties: RF_PKT_CRC_CONFIG_7
- // Number of properties: 7
- // Group ID: 0x12
- // Start ID: 0x00
- // Default values: 0x00, 0x01, 0x08, 0xFF, 0xFF, 0x00, 0x00,
- // Descriptions:
- // PKT_CRC_CONFIG - Select a CRC polynomial and seed.
- // PKT_WHT_POLY_15_8 - 16-bit polynomial value for the PN Generator (e.g., for Data Whitening)
- // PKT_WHT_POLY_7_0 - 16-bit polynomial value for the PN Generator (e.g., for Data Whitening)
- // PKT_WHT_SEED_15_8 - 16-bit seed value for the PN Generator (e.g., for Data Whitening)
- // PKT_WHT_SEED_7_0 - 16-bit seed value for the PN Generator (e.g., for Data Whitening)
- // PKT_WHT_BIT_NUM - Selects which bit of the LFSR (used to generate the PN / data whitening sequence) is used as the output bit for data scrambling.
- // PKT_CONFIG1 - General configuration bits for transmission or reception of a packet.
- #define RF_PKT_CRC_CONFIG_7 0x11, 0x12, 0x07, 0x00, 0x84, 0x01, 0x08, 0xFF, 0xFF, 0x00, 0x02
- // Set properties: RF_PKT_LEN_12
- // Number of properties: 12
- // Group ID: 0x12
- // Start ID: 0x08
- // Default values: 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- // Descriptions:
- // PKT_LEN - Configuration bits for reception of a variable length packet.
- // PKT_LEN_FIELD_SOURCE - Field number containing the received packet length byte(s).
- // PKT_LEN_ADJUST - Provides for adjustment/offset of the received packet length value (in order to accommodate a variety of methods of defining total packet length).
- // PKT_TX_THRESHOLD - TX FIFO almost empty threshold.
- // PKT_RX_THRESHOLD - RX FIFO Almost Full threshold.
- // PKT_FIELD_1_LENGTH_12_8 - Unsigned 13-bit Field 1 length value.
- // PKT_FIELD_1_LENGTH_7_0 - Unsigned 13-bit Field 1 length value.
- // PKT_FIELD_1_CONFIG - General data processing and packet configuration bits for Field 1.
- // PKT_FIELD_1_CRC_CONFIG - Configuration of CRC control bits across Field 1.
- // PKT_FIELD_2_LENGTH_12_8 - Unsigned 13-bit Field 2 length value.
- // PKT_FIELD_2_LENGTH_7_0 - Unsigned 13-bit Field 2 length value.
- // PKT_FIELD_2_CONFIG - General data processing and packet configuration bits for Field 2.
- #define RF_PKT_LEN_12 0x11, 0x12, 0x0C, 0x08, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, 0x07, 0x04, 0x80, 0x00, 0x00, 0x00
- // Set properties: RF_PKT_FIELD_2_CRC_CONFIG_12
- // Group ID: 0x12
- // Start ID: 0x14
- // Default values: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- // Descriptions:
- // PKT_FIELD_2_CRC_CONFIG - Configuration of CRC control bits across Field 2.
- // PKT_FIELD_3_LENGTH_12_8 - Unsigned 13-bit Field 3 length value.
- // PKT_FIELD_3_LENGTH_7_0 - Unsigned 13-bit Field 3 length value.
- // PKT_FIELD_3_CONFIG - General data processing and packet configuration bits for Field 3.
- // PKT_FIELD_3_CRC_CONFIG - Configuration of CRC control bits across Field 3.
- // PKT_FIELD_4_LENGTH_12_8 - Unsigned 13-bit Field 4 length value.
- // PKT_FIELD_4_LENGTH_7_0 - Unsigned 13-bit Field 4 length value.
- // PKT_FIELD_4_CONFIG - General data processing and packet configuration bits for Field 4.
- // PKT_FIELD_4_CRC_CONFIG - Configuration of CRC control bits across Field 4.
- // PKT_FIELD_5_LENGTH_12_8 - Unsigned 13-bit Field 5 length value.
- // PKT_FIELD_5_LENGTH_7_0 - Unsigned 13-bit Field 5 length value.
- // PKT_FIELD_5_CONFIG - General data processing and packet configuration bits for Field 5.
- #define RF_PKT_FIELD_2_CRC_CONFIG_12 0x11, 0x12, 0x0C, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_PKT_FIELD_5_CRC_CONFIG_12
- // Group ID: 0x12
- // Start ID: 0x20
- // Descriptions:
- // PKT_FIELD_5_CRC_CONFIG - Configuration of CRC control bits across Field 5.
- // PKT_RX_FIELD_1_LENGTH_12_8 - Unsigned 13-bit RX Field 1 length value.
- // PKT_RX_FIELD_1_LENGTH_7_0 - Unsigned 13-bit RX Field 1 length value.
- // PKT_RX_FIELD_1_CONFIG - General data processing and packet configuration bits for RX Field 1.
- // PKT_RX_FIELD_1_CRC_CONFIG - Configuration of CRC control bits across RX Field 1.
- // PKT_RX_FIELD_2_LENGTH_12_8 - Unsigned 13-bit RX Field 2 length value.
- // PKT_RX_FIELD_2_LENGTH_7_0 - Unsigned 13-bit RX Field 2 length value.
- // PKT_RX_FIELD_2_CONFIG - General data processing and packet configuration bits for RX Field 2.
- // PKT_RX_FIELD_2_CRC_CONFIG - Configuration of CRC control bits across RX Field 2.
- // PKT_RX_FIELD_3_LENGTH_12_8 - Unsigned 13-bit RX Field 3 length value.
- // PKT_RX_FIELD_3_LENGTH_7_0 - Unsigned 13-bit RX Field 3 length value.
- // PKT_RX_FIELD_3_CONFIG - General data processing and packet configuration bits for RX Field 3.
- #define RF_PKT_FIELD_5_CRC_CONFIG_12 0x11, 0x12, 0x0C, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_PKT_RX_FIELD_3_CRC_CONFIG_9
- // Group ID: 0x12
- // Start ID: 0x2C
- // Descriptions:
- // PKT_RX_FIELD_3_CRC_CONFIG - Configuration of CRC control bits across RX Field 3.
- // PKT_RX_FIELD_4_LENGTH_12_8 - Unsigned 13-bit RX Field 4 length value.
- // PKT_RX_FIELD_4_LENGTH_7_0 - Unsigned 13-bit RX Field 4 length value.
- // PKT_RX_FIELD_4_CONFIG - General data processing and packet configuration bits for RX Field 4.
- // PKT_RX_FIELD_4_CRC_CONFIG - Configuration of CRC control bits across RX Field 4.
- // PKT_RX_FIELD_5_LENGTH_12_8 - Unsigned 13-bit RX Field 5 length value.
- // PKT_RX_FIELD_5_LENGTH_7_0 - Unsigned 13-bit RX Field 5 length value.
- // PKT_RX_FIELD_5_CONFIG - General data processing and packet configuration bits for RX Field 5.
- // PKT_RX_FIELD_5_CRC_CONFIG - Configuration of CRC control bits across RX Field 5.
- #define RF_PKT_RX_FIELD_3_CRC_CONFIG_9 0x11, 0x12, 0x09, 0x2C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_MODEM_MOD_TYPE_12
- // Group ID: 0x20
- // Start ID: 0x00
- // Default values: 0x02, 0x80, 0x07, 0x0F, 0x42, 0x40, 0x01, 0xC9, 0xC3, 0x80, 0x00, 0x06,
- // Descriptions:
- // MODEM_MOD_TYPE - Selects the type of modulation. In TX mode, additionally selects the source of the modulation.
- // MODEM_MAP_CONTROL - Controls polarity and mapping of transmit and receive bits.
- // MODEM_DSM_CTRL - Miscellaneous control bits for the Delta-Sigma Modulator (DSM) in the PLL Synthesizer.
- // MODEM_DATA_RATE_2 - Unsigned 24-bit value used to determine the TX data rate
- // MODEM_DATA_RATE_1 - Unsigned 24-bit value used to determine the TX data rate
- // MODEM_DATA_RATE_0 - Unsigned 24-bit value used to determine the TX data rate
- // MODEM_TX_NCO_MODE_3 - TX Gaussian filter oversampling ratio and Byte 3 of unsigned 26-bit TX Numerically Controlled Oscillator (NCO) modulus.
- // MODEM_TX_NCO_MODE_2 - TX Gaussian filter oversampling ratio and Byte 3 of unsigned 26-bit TX Numerically Controlled Oscillator (NCO) modulus.
- // MODEM_TX_NCO_MODE_1 - TX Gaussian filter oversampling ratio and Byte 3 of unsigned 26-bit TX Numerically Controlled Oscillator (NCO) modulus.
- // MODEM_TX_NCO_MODE_0 - TX Gaussian filter oversampling ratio and Byte 3 of unsigned 26-bit TX Numerically Controlled Oscillator (NCO) modulus.
- // MODEM_FREQ_DEV_2 - 17-bit unsigned TX frequency deviation word.
- // MODEM_FREQ_DEV_1 - 17-bit unsigned TX frequency deviation word.
- #define RF_MODEM_MOD_TYPE_12 0x11, 0x20, 0x0C, 0x00, 0x02, 0x00, 0x07, 0x01, 0x86, 0xA0, 0x01, 0xC9, 0xC3, 0x80, 0x00, 0x05
- // Set properties: RF_MODEM_FREQ_DEV_0_1
- // Group ID: 0x20
- // Start ID: 0x0C
- // Default values: 0xD3,
- // Descriptions:
- // MODEM_FREQ_DEV_0 - 17-bit unsigned TX frequency deviation word.
- #define RF_MODEM_FREQ_DEV_0_1 0x11, 0x20, 0x01, 0x0C, 0x76
- // Set properties: RF_MODEM_TX_RAMP_DELAY_8
- // Number of properties: 8
- // Group ID: 0x20
- // Start ID: 0x18
- // Default values: 0x01, 0x00, 0x08, 0x03, 0xC0, 0x00, 0x10, 0x20,
- // Descriptions:
- // MODEM_TX_RAMP_DELAY - TX ramp-down delay setting.
- // MODEM_MDM_CTRL - MDM control.
- // MODEM_IF_CONTROL - Selects Fixed-IF, Scaled-IF, or Zero-IF mode of RX Modem operation.
- // MODEM_IF_FREQ_2 - the IF frequency setting (an 18-bit signed number).
- // MODEM_IF_FREQ_1 - the IF frequency setting (an 18-bit signed number).
- // MODEM_IF_FREQ_0 - the IF frequency setting (an 18-bit signed number).
- // MODEM_DECIMATION_CFG1 - Specifies three decimator ratios for the Cascaded Integrator Comb (CIC) filter.
- // MODEM_DECIMATION_CFG0 - Specifies miscellaneous parameters and decimator ratios for the Cascaded Integrator Comb (CIC) filter.
- #define RF_MODEM_TX_RAMP_DELAY_8 0x11, 0x20, 0x08, 0x18, 0x01, 0x80, 0x08, 0x03, 0x80, 0x00, 0x20, 0x20
- // Set properties: RF_MODEM_BCR_OSR_1_9
- // Group ID: 0x20
- // Start ID: 0x22
- // Default values: 0x00, 0x4B, 0x06, 0xD3, 0xA0, 0x06, 0xD3, 0x02, 0xC0,
- // Descriptions:
- // MODEM_BCR_OSR_1 - RX BCR/Slicer oversampling rate (12-bit unsigned number).
- // MODEM_BCR_OSR_0 - RX BCR/Slicer oversampling rate (12-bit unsigned number).
- // MODEM_BCR_NCO_OFFSET_2 - RX BCR NCO offset value (an unsigned 22-bit number).
- // MODEM_BCR_NCO_OFFSET_1 - RX BCR NCO offset value (an unsigned 22-bit number).
- // MODEM_BCR_NCO_OFFSET_0 - RX BCR NCO offset value (an unsigned 22-bit number).
- // MODEM_BCR_GAIN_1 - The unsigned 11-bit RX BCR loop gain value.
- // MODEM_BCR_GAIN_0 - The unsigned 11-bit RX BCR loop gain value.
- // MODEM_BCR_GEAR - RX BCR loop gear control.
- // MODEM_BCR_MISC1 - Miscellaneous control bits for the RX BCR loop.
- #define RF_MODEM_BCR_OSR_1_9 0x11, 0x20, 0x09, 0x22, 0x01, 0x77, 0x01, 0x5D, 0x86, 0x00, 0xAF, 0x02, 0xC2
- // Set properties: RF_MODEM_AFC_GEAR_7
- // Group ID: 0x20
- // Start ID: 0x2C
- // Default values: 0x00, 0x23, 0x83, 0x69, 0x00, 0x40, 0xA0,
- // Descriptions:
- // MODEM_AFC_GEAR - RX AFC loop gear control.
- // MODEM_AFC_WAIT - RX AFC loop wait time control.
- // MODEM_AFC_GAIN_1 - Sets the gain of the PLL-based AFC acquisition loop, and provides miscellaneous control bits for AFC functionality.
- // MODEM_AFC_GAIN_0 - Sets the gain of the PLL-based AFC acquisition loop, and provides miscellaneous control bits for AFC functionality.
- // MODEM_AFC_LIMITER_1 - Set the AFC limiter value.
- // MODEM_AFC_LIMITER_0 - Set the AFC limiter value.
- // MODEM_AFC_MISC - Specifies miscellaneous AFC control bits.
- #define RF_MODEM_AFC_GEAR_7 0x11, 0x20, 0x07, 0x2C, 0x04, 0x36, 0x80, 0x1D, 0x11, 0xEC, 0x80
- // Set properties: RF_MODEM_AGC_CONTROL_1
- // Group ID: 0x20
- // Start ID: 0x35
- // Default values: 0xE0,
- // Descriptions:
- // MODEM_AGC_CONTROL - Miscellaneous control bits for the Automatic Gain Control (AGC) function in the RX Chain.
- #define RF_MODEM_AGC_CONTROL_1 0x11, 0x20, 0x01, 0x35, 0xE2
- // Set properties: RF_MODEM_AGC_WINDOW_SIZE_3
- // Number of properties: 3
- // Group ID: 0x20
- // Start ID: 0x38
- // Default values: 0x11, 0x10, 0x10,
- // Descriptions:
- // MODEM_AGC_WINDOW_SIZE - Specifies the size of the measurement and settling windows for the AGC algorithm.
- // MODEM_AGC_RFPD_DECAY - Sets the decay time of the RF peak detectors.
- // MODEM_AGC_IFPD_DECAY - Sets the decay time of the IF peak detectors.
- #define RF_MODEM_AGC_WINDOW_SIZE_3 0x11, 0x20, 0x03, 0x38, 0x11, 0x52, 0x52
- // Set properties: RF_MODEM_OOK_PDTC_1
- // Group ID: 0x20
- // Start ID: 0x40
- // Default values: 0x2B,
- // Descriptions:
- // MODEM_OOK_PDTC - Configures the attack and decay times of the OOK Peak Detector.
- #define RF_MODEM_OOK_PDTC_1 0x11, 0x20, 0x01, 0x40, 0x2A
- // Set properties: RF_MODEM_OOK_CNT1_9
- // Group ID: 0x20
- // Start ID: 0x42
- // Default values: 0xA4, 0x03, 0x56, 0x02, 0x00, 0xA3, 0x02, 0x80, 0xFF,
- // Descriptions:
- // MODEM_OOK_CNT1 - OOK control.
- // MODEM_OOK_MISC - Selects the detector(s) used for demodulation of an OOK signal, or for demodulation of a (G)FSK signal when using the asynchronous demodulator.
- // MODEM_RAW_SEARCH - Defines and controls the search period length for the Moving Average and Min-Max detectors.
- // MODEM_RAW_CONTROL - Defines gain and enable controls for raw / nonstandard mode.
- // MODEM_RAW_EYE_1 - 11 bit eye-open detector threshold.
- // MODEM_RAW_EYE_0 - 11 bit eye-open detector threshold.
- // MODEM_ANT_DIV_MODE - Antenna diversity mode settings.
- // MODEM_ANT_DIV_CONTROL - Specifies controls for the Antenna Diversity algorithm.
- // MODEM_RSSI_THRESH - Configures the RSSI threshold.
- #define RF_MODEM_OOK_CNT1_9 0x11, 0x20, 0x09, 0x42, 0xA4, 0x02, 0xD6, 0x83, 0x01, 0x20, 0x01, 0x80, 0xFF
- // Set properties: RF_MODEM_RSSI_CONTROL_1
- // Group ID: 0x20
- // Start ID: 0x4C
- // Descriptions:
- // MODEM_RSSI_CONTROL - Control of the averaging modes and latching time for reporting RSSI value(s).
- #define RF_MODEM_RSSI_CONTROL_1 0x11, 0x20, 0x01, 0x4C, 0x00
- // Set properties: RF_MODEM_RSSI_COMP_1
- // Group ID: 0x20
- // Start ID: 0x4E
- // Default values: 0x32,
- // Descriptions:
- // MODEM_RSSI_COMP - RSSI compensation value.
- #define RF_MODEM_RSSI_COMP_1 0x11, 0x20, 0x01, 0x4E, 0x40
- // Set properties: RF_MODEM_CLKGEN_BAND_1
- // Group ID: 0x20
- // Start ID: 0x51
- // Descriptions:
- // MODEM_CLKGEN_BAND - Select PLL Synthesizer output divider ratio as a function of frequency band.
- #define RF_MODEM_CLKGEN_BAND_1 0x11, 0x20, 0x01, 0x51, 0x0A
- // Set properties: RF_MODEM_CHFLT_RX1_CHFLT_COE13_7_0_12
- // Group ID: 0x21
- // Start ID: 0x00
- // Default values: 0xFF, 0xBA, 0x0F, 0x51, 0xCF, 0xA9, 0xC9, 0xFC, 0x1B, 0x1E, 0x0F, 0x01,
- // Descriptions:
- // MODEM_CHFLT_RX1_CHFLT_COE13_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE12_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE11_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE10_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE9_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE8_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE7_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE6_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE5_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE4_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE3_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE2_7_0 - Filter coefficients for the first set of RX filter coefficients.
- #define RF_MODEM_CHFLT_RX1_CHFLT_COE13_7_0_12 0x11, 0x21, 0x0C, 0x00, 0xCC, 0xA1, 0x30, 0xA0, 0x21, 0xD1, 0xB9, 0xC9, 0xEA, 0x05, 0x12, 0x11
- // Set properties: RF_MODEM_CHFLT_RX1_CHFLT_COE1_7_0_12
- // Group ID: 0x21
- // Start ID: 0x0C
- // Default values: 0xFC, 0xFD, 0x15, 0xFF, 0x00, 0x0F, 0xFF, 0xC4, 0x30, 0x7F, 0xF5, 0xB5,
- // Descriptions:
- // MODEM_CHFLT_RX1_CHFLT_COE1_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COE0_7_0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COEM0 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COEM1 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COEM2 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX1_CHFLT_COEM3 - Filter coefficients for the first set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE13_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE12_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE11_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE10_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE9_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE8_7_0 - Filter coefficients for the second set of RX filter coefficients.
- #define RF_MODEM_CHFLT_RX1_CHFLT_COE1_7_0_12 0x11, 0x21, 0x0C, 0x0C, 0x0A, 0x04, 0x15, 0xFC, 0x03, 0x00, 0xCC, 0xA1, 0x30, 0xA0, 0x21, 0xD1
- // Set properties: RF_MODEM_CHFLT_RX2_CHFLT_COE7_7_0_12
- // Group ID: 0x21
- // Start ID: 0x18
- // Default values: 0xB8, 0xDE, 0x05, 0x17, 0x16, 0x0C, 0x03, 0x00, 0x15, 0xFF, 0x00, 0x00,
- // Descriptions:
- // MODEM_CHFLT_RX2_CHFLT_COE7_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE6_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE5_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE4_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE3_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE2_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE1_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COE0_7_0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COEM0 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COEM1 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COEM2 - Filter coefficients for the second set of RX filter coefficients.
- // MODEM_CHFLT_RX2_CHFLT_COEM3 - Filter coefficients for the second set of RX filter coefficients.
- #define RF_MODEM_CHFLT_RX2_CHFLT_COE7_7_0_12 0x11, 0x21, 0x0C, 0x18, 0xB9, 0xC9, 0xEA, 0x05, 0x12, 0x11, 0x0A, 0x04, 0x15, 0xFC, 0x03, 0x00
- // Set properties: RF_PA_MODE_4
- // Group ID: 0x22
- // Start ID: 0x00
- // Default values: 0x08, 0x7F, 0x00, 0x5D,
- // Descriptions:
- // PA_MODE - Selects the PA operating mode, and selects resolution of PA power adjustment (i.e., step size).
- // PA_PWR_LVL - Configuration of PA output power level.
- // PA_BIAS_CLKDUTY - Configuration of the PA Bias and duty cycle of the TX clock source.
- // PA_TC - Configuration of PA ramping parameters.
- #define RF_PA_MODE_4 0x11, 0x22, 0x04, 0x00, 0x08, 0x7F, 0x00, 0x3D
- // Set properties: RF_SYNTH_PFDCP_CPFF_7
- // Group ID: 0x23
- // Start ID: 0x00
- // Default values: 0x2C, 0x0E, 0x0B, 0x04, 0x0C, 0x73, 0x03,
- // Descriptions:
- // SYNTH_PFDCP_CPFF - Feed forward charge pump current selection.
- // SYNTH_PFDCP_CPINT - Integration charge pump current selection.
- // SYNTH_VCO_KV - Gain scaling factors (Kv) for the VCO tuning varactors on both the integrated-path and feed forward path.
- // SYNTH_LPFILT3 - Value of resistor R2 in feed-forward path of loop filter.
- // SYNTH_LPFILT2 - Value of capacitor C2 in feed-forward path of loop filter.
- // SYNTH_LPFILT1 - Value of capacitors C1 and C3 in feed-forward path of loop filter.
- // SYNTH_LPFILT0 - Bias current of the active amplifier in the feed-forward loop filter.
- #define RF_SYNTH_PFDCP_CPFF_7 0x11, 0x23, 0x07, 0x00, 0x2C, 0x0E, 0x0B, 0x04, 0x0C, 0x73, 0x03
- // Set properties: RF_MATCH_VALUE_1_12
- // Group ID: 0x30
- // Start ID: 0x00
- // Descriptions:
- // MATCH_VALUE_1 - Match value to be compared with the result of logically AND-ing (bit-wise) the Mask 1 value with the received Match 1 byte.
- // MATCH_MASK_1 - Mask value to be logically AND-ed (bit-wise) with the Match 1 byte.
- // MATCH_CTRL_1 - Enable for Packet Match functionality, and configuration of Match Byte 1.
- // MATCH_VALUE_2 - Match value to be compared with the result of logically AND-ing (bit-wise) the Mask 2 value with the received Match 2 byte.
- // MATCH_MASK_2 - Mask value to be logically AND-ed (bit-wise) with the Match 2 byte.
- // MATCH_CTRL_2 - Configuration of Match Byte 2.
- // MATCH_VALUE_3 - Match value to be compared with the result of logically AND-ing (bit-wise) the Mask 3 value with the received Match 3 byte.
- // MATCH_MASK_3 - Mask value to be logically AND-ed (bit-wise) with the Match 3 byte.
- // MATCH_CTRL_3 - Configuration of Match Byte 3.
- // MATCH_VALUE_4 - Match value to be compared with the result of logically AND-ing (bit-wise) the Mask 4 value with the received Match 4 byte.
- // MATCH_MASK_4 - Mask value to be logically AND-ed (bit-wise) with the Match 4 byte.
- // MATCH_CTRL_4 - Configuration of Match Byte 4.
- #define RF_MATCH_VALUE_1_12 0x11, 0x30, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
- // Set properties: RF_FREQ_CONTROL_INTE_8
- // Group ID: 0x40
- // Start ID: 0x00
- // Default values: 0x3C, 0x08, 0x00, 0x00, 0x00, 0x00, 0x20, 0xFF,
- // Descriptions:
- // FREQ_CONTROL_INTE - Frac-N PLL Synthesizer integer divide number.
- // FREQ_CONTROL_FRAC_2 - Frac-N PLL fraction number.
- // FREQ_CONTROL_FRAC_1 - Frac-N PLL fraction number.
- // FREQ_CONTROL_FRAC_0 - Frac-N PLL fraction number.
- // FREQ_CONTROL_CHANNEL_STEP_SIZE_1 - EZ Frequency Programming channel step size.
- // FREQ_CONTROL_CHANNEL_STEP_SIZE_0 - EZ Frequency Programming channel step size.
- // FREQ_CONTROL_W_SIZE - Set window gating period (in number of crystal reference clock cycles) for counting VCO frequency during calibration.
- // FREQ_CONTROL_VCOCNT_RX_ADJ - Adjust target count for VCO calibration in RX mode.
- #define RF_FREQ_CONTROL_INTE_8 0x11, 0x40, 0x08, 0x00, 0x40, 0x0A, 0xAA, 0xAA, 0x44, 0x44, 0x20, 0xFE
- // AUTOMATICALLY GENERATED CODE!
- // DO NOT EDIT/MODIFY BELOW THIS LINE!
- #ifndef FIRMWARE_LOAD_COMPILE
- #define RADIO_CONFIGURATION_DATA_ARRAY { \
- 0x07, RF_POWER_UP, \
- 0x08, RF_GPIO_PIN_CFG, \
- 0x06, RF_GLOBAL_XO_TUNE_2, \
- 0x05, RF_GLOBAL_CONFIG_1, \
- 0x06, RF_INT_CTL_ENABLE_2, \
- 0x08, RF_FRR_CTL_A_MODE_4, \
- 0x0D, RF_PREAMBLE_TX_LENGTH_9, \
- 0x09, RF_SYNC_CONFIG_5, \
- 0x0B, RF_PKT_CRC_CONFIG_7, \
- 0x10, RF_PKT_LEN_12, \
- 0x10, RF_PKT_FIELD_2_CRC_CONFIG_12, \
- 0x10, RF_PKT_FIELD_5_CRC_CONFIG_12, \
- 0x0D, RF_PKT_RX_FIELD_3_CRC_CONFIG_9, \
- 0x10, RF_MODEM_MOD_TYPE_12, \
- 0x05, RF_MODEM_FREQ_DEV_0_1, \
- 0x0C, RF_MODEM_TX_RAMP_DELAY_8, \
- 0x0D, RF_MODEM_BCR_OSR_1_9, \
- 0x0B, RF_MODEM_AFC_GEAR_7, \
- 0x05, RF_MODEM_AGC_CONTROL_1, \
- 0x07, RF_MODEM_AGC_WINDOW_SIZE_3, \
- 0x05, RF_MODEM_OOK_PDTC_1, \
- …………限于本文篇幅 余下代码请从51黑下载附件…………
radio_config_Si4438.zip
(6.13 KB, 下载次数: 27)
