查看: 2397|回复: 1
51单片机用4x4键盘控制12864写入
ID:302040 发表于 2018-4-4 15:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
键盘0~9一共10个键,还有一个确认键,一个修改键。我照着书比葫芦画瓢自己写了一个,怎么用protues仿真不成功呢,大佬们帮帮忙。
#include<reg52.h>
#include<intrins.h>
#include<stdlib.h>
sbit dula=P3^2;        //修改
sbit wela=P3^3;
#define LCD_data P0        //12864显示用P0口
sbit LCD_RS=P3^5;
sbit LCD_RW=P3^6;
sbit LCD_EN=P3^4;
sbit LCD_PSB=P3^7;
uchar code dis1[]={"欢迎通行"};
uchar code dis2[]={"车牌号:"};
uchar code dis3[]={"每公里5元"};
void delay(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--)
void write_cmd(uchar cmd)                           //写命令
        LCD_RS=0;
        LCD_RW=0;
        LCD_EN=0;
        P0=cmd;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
void write_dat(uchar dat)                                  //写数据
        LCD_RS=1;
        LCD_RW=0;
        LCD_EN=0;
        P0=dat;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
void lcd_pos(uchar X,uchar Y)
        uchar pos;
        if(X==0)
                {X=0x80;}
        if(X==1)
                {X=0x90;}
        if(X==2)
                {X=0x88;}
        if(X==3)
                {X=0x98;}
        pos=X+Y;
        write_cmd(pos);
void lcd_init()                                                   //LCD初始化设定
        LCD_PSB=1;
        write_cmd(0x30);
        delay(5);
        write_cmd(0x0C);
        delay(5);
        write_cmd(0x01);
        delay(5);
        write_cmd(0x06);
        delay(5);
        lcd_pos(0,0);
        uchar i=0;
        while(dis2[i]!='\0')
                write_dat(dis2[i]);
                i++;
        lcd_pos(1,0);
        i=0;
        while(dis3[i]!='\0')
                write_dat(dis3[i]);
                i++;
void matrixkeyscan()                                 //键盘扫描程序,使用P2口
        uchar temp,key;
        P2=0xfe;
        temp=p2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                                case 0xee:
                                        key=0;
                                        break;
                                case 0xde:
                                        key=1;
                                        break;
                                case 0xbe:
                                        key=2;
                                        break;
                                case 0x7e:
                                        key=3;
                                        break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
                        write_dat(key);
        P2=0xfd;
        temp=p2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                                case 0xed:
                                        key=4;
                                        break;
                                case 0xdd:
                                        key=5;
                                        break;
                                case 0xbd:
                                        key=6;
                                        break;
                                case 0x7d:
                                        key=7;
                                        break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
                        write_dat(key);
        P2=0xfb;
        temp=p2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                                case 0xeb:
                                        key=8;
                                        break;
                                case 0xdb:
                                        key=9;
                                        break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
                        write_dat(key);
        P2=0xfb;
        temp=p2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                                case 0xbb:                                 //此键位为数字确认按键
                                        break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
                        write_cmd(0x01);
                        delay(5);
                        lcd_pos(1,0);
                        uchar i=0;
                        while(dis1[i]!='\0')
                                write_dat(dis1[i]);
                                i++;
        P2=0xfb;
        temp=p2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                                case 0x7b:                                 //此键位为数字修改按键
                                        break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
                        lcd_init();
                        lcd_pos(0,8);
void main()        //主函数
        wela=0;
        dula=0;
        uchar i;
        delay(10);
        lcd_init();
        lcd_pos(0,8);
        matrixkeyscan();
ID:302297 发表于 2018-4-5 10:29 | 只看该作者
·······························································共同进步·1······························
