s128智能小车测试程序源码
- #include <hidef.h> /* common defines and macros */
- #include <MC9S12XS128.h> /* derivative information */
- #include "math.h"
- #pragma LINK_INFO DERIVATIVE "mc9s12xs128"
- /*********************DEFINE************************/
- #define WHITE 50
- #define BLACK 40
- #define KD 0
- #define EnableSCIReInt SCI0CR2 |= 0x20
- #define DisableSCIReInt SCI0CR2 &= 0xDF
- #define RTI_SWITCH_ON CRGINT_RTIE=1
- #define RTI_SWITCH_OFF CRGINT_RTIE=0
- #define IC_SWITCH_ON TSCR1_TEN=1
- #define IC_SWITCH_OFF TSCR1_TEN=0
- //-----------------define key---------------------//
- #define KEY_RUN_OR_LCD PORTK_PK0
- #define KEY_START_RUN PORTA_PA1
- #define KEY_UP PORTA_PA2
- #define KEY_DOWN PORTA_PA3
- #define KEY_ENTER PORTA_PA4
- //-----------------part of lcd---------------------//
- #define LINE1 0
- #define LINE2 1
- #define LINE1_HEAD 0x80
- #define LINE2_HEAD 0xC0
- #define DATA_MODE 0x38 // 8 bit data transmission mode, double line
- #define CLR 0x01
- #define BUSY 0x80 // LCD Busy Tag
- #define CURSOR_RESET 0x02
- #define INPUTMODE_CUR_R 0x06
- #define INPUTMODE_CUR_L 0x04
- #define INPUTMODE_ALL_E 0x05
- #define INPUTMODE_ALL_D 0x04
- #define SCREEN_OPEN 0x0C
- #define SCREEN_OPEN_CUR 0x02
- #define SCREEN_OPEN_FLASH 0x01
- #define SCSHIFT_CUR_L 0x10 // Screen or Cursor shift
- #define SCSHIFT_CUR_R 0x14
- #define SCSHIFT_SCR_L 0x18
- #define SCSHIFT_SCR_R 0x1C
- //-----------------define lcd pins--------------------//
- #define RS PORTA_PA5 //Data Command Pin 1 data 0 command
- #define RW PORTA_PA6 //Read Write Pin 1 read 0 write
- #define EN PORTA_PA7 //LCD Enable Signal
- #define LCD_DATA PTH
- #define LCD_DATA_DIR DDRH
- #define LCD_DIR_IN 0x00
- #define LCD_DIR_OUT 0xff
- /*********************END************************/
- /***************HARDWARE INIT FUN DECLARE******************/
- void uart_init(void);
- extern void uart_PutChar(unsigned char);
- unsigned char TERMIO_GetChar(void);
- void printp( char * , ...);
- void CPU_Init(void);
- void IO_Init(void);
- void SciTx(unsigned char text);
- char SciRx(void);
- void RTI_Init(void);
- void IC_Init(void);
- void OC7_Init(void);
- void PTI0_Init(void);
- void PWM_Init(void);
- void AD_Init(void);
- void LcdCommand(unsigned char command,unsigned char BusyC);
- void LcdData(unsigned char temp,unsigned char BusyC);
- void LcdInit(void);
- unsigned char ReadStatus(void);
- void GotoXY( unsigned char x, unsigned char y );
- void Print(unsigned char *str);
- void Lcd_Print_Str(unsigned char x,unsigned char y,char *s);
- void Lcd_Print_Int( unsigned char x,unsigned char y,unsigned int data);
- void Lcd_Print_Char( unsigned char x,unsigned char y,unsigned char data);
- void Lcd_Print_uChar( unsigned char x,unsigned char y,char data);
- /***************SOFTWARE FUN DECLARE******************/
- void light_flip(void);
- void AD_DATA_HIGHT(void);
- void AD_DATA_LOW(void);
- void VOL_Normaliz(void);
- void err_calculate_hight(void);
- void err_calculate_low(void);
- signed int PID(void);
- void key_scan_deal(void);
- void LCD_DISPLAY(void);
- uint err_Std(void);
- void check_line(void);
- void LcdDelay(byte k);
- void Dly_ms(int ms);
- void delay(unsigned int ref);
- /*********************DEFINE VAR************************/
- //---------------sensor data var-----------------//
- uchar THRESHOLD_black=40;
- uchar max_vol[9],min_vol[9]={255,255,255,255,255,255,255,255,255};
- uchar WHITE_MIN=240,WHITE_MAX=250;
- uchar percent[9],data[9],det_vol[9],flip_data[9];
- schar err[100],err_e[3];
- uchar L_times=130;
- byte flip=0,max_num_p=0;
- //---------------sensor_2 data var-----------------//
- uchar data_2[5],THRESHOLD_2=200,flip_data_2[5],err_e2[3];
- //-----------------speed var---------------------//
- byte load_bit=0;
- uchar pluse_1=0,pluse_2=0,get_speed=0,set_speed=30,now_speed=0;
- uchar MAX_SPEED=30;
- //-----------------check var-------------------- //
- uint check_pluse=0;
- uchar start_line=0,stop=0,stop_delay=0,slope_time=0,slope_timing=0;
- byte check=0,check_bit=0,line_num=0,triangle_status=0,slope_bit=0,black_bit=0;
- //------------------key&lcd var----------------------//
- byte key_r_o_l=0,lcd_print=1;
- uchar menu=1,menu_option=1,bits=0;
- //----------------- calc var---------------------//
- uchar KP=8,period_1=0,period_2=0;
- char std_err[10];
- int temp_std;
- void main()
- DisableInterrupts;
- CPU_Init();
- IO_Init();
- uart_init();
- //EnableSCIReInt;
- LcdInit();
- PWM_Init();
- AD_Init();
- VOL_Normaliz();
- Dly_ms(3000);
- Dly_ms(2000);
- RTI_Init();
- IC_Init();
- for(;;)
- EnableInterrupts;
- //err_calculate_hight();
- key_scan_deal();
- // HARDWARE FUN START
- void CPU_Init()
- CLKSEL=0X00;
- PLLCTL_PLLON=1;
- REFDV=0x01; //BUS_CLOCK = 40M
- SYNR=0x04;
- _asm(nop);
- _asm(nop);
- while(!(CRGFLG_LOCK==1));
- CLKSEL_PLLSEL=0x01;
- FCLKDIV=0x0F;//Flash Clock Divide Factor 40M/16=?M
- unsigned char temp;
- temp=SCI0SR1; /*clear flag*/
- while (!(SCI0SR1&0x80)); /* wait for output buffer empty */
- SCI0DRH=0;
- SCI0DRL=text;
- char SciRx(void)
- unsigned char result,temp;
- while(!(SCI0SR1&0x20));
- result=SCI0DRL;
- return result;
- void RTI_Init()
- RTICTL=0b10010011; //0010000=2*10^3,10010011=8*10^3=0.5ms,10001111=16*10^3=1ms,11000111=160x10^3=10ms ,11101111=1.6*10^6=100ms
- //CRGINT_RTIE=1;
- void IC_Init(){
- TIOS_IOS0=0; //channel 0 input capture
- TCTL4_EDG0B=1;
- TCTL4_EDG0A=1;
- TIE_C0I=1; //channel 0 interrupt enable
- TSCR2=0x03; //TIMEclock = 40M / 8 =0.2us
- TFLG1 = 0xFF;
- TFLG2 = 0x80;
- //TSCR1_TEN=1; //Timer enable
- EnableInterrupts;
- void OC7_Init()
- TSCR2_TCRE=1;
- TSCR2_PR=0;
- TIOS_IOS7=1;
- TC7=0x5dc0; //24000,1ms
- TCTL1=0x00;
- TIE_C7I=1;
- TSCR1_TEN = 1;
- void PTI0_Init()
- PITCFLMT=0x00;
- PITCE_PCE0=1;
- PITMUX_PMUX0=0;
- PITMTLD0=0x01;
- PITLD0=0x0001; //2x2x25ns=1us;
- PITINTE_PINTE0=1;
- PITCFLMT_PITE=1;
- void PWM_Init()
- PWME=0xaa; //enable c_1,c_3,c_5,c_7
- PWMPOL=0xaa;
- PWMCAE=0X00;
- PWMCTL=0xf0; //com 0&1 2&3 4&5
- PWMPRCLK=0x00;
- PWMCLK_PCLK1=1; //0&1---SA
- PWMSCLA=0x04; //SA = 5M
- PWMPER01=50000; //舵机: 5000000/50000=100Hz ;
- PWMDTY01=7100;
- PWMPER23=5000; //电机: 24000000/12000=2000Hz ;24000000/2400=10000Hz ;40000000/5000=8000Hz
- PWMDTY23=2500;
- PWMPER45=5000;
- PWMDTY45=2500;
- void AD_Init()
- //[3:0]---WRAP
- //ATD0CTL0=0x00;
- //7---ETRIGSEL, [6:5]---Resolution Select, 4---Discharge, [3:0]---External Trigger Channel Select
- ATD0CTL1=0x00;
- //6---AFFC;5---ICLKSTP; [4:3]---External Trigger Edge/Polarity; 2---ETRIGE;
- //1---ASCIE,Sequence Complete Interrupt Enable; 0---ACMPIE,Compare Interrupt Enable
- ATD0CTL2=0x40;
- //7---DJM,Data Justification; [6:3]---S8C,S4C,S2C,S1C,Sequence Length;2---FIFO;
- //[1:0]---Background Debug Freeze Enable;
- ATD0CTL3=0x98;
- //[7:5]---SMP,Sample Time Select; [4:0]---PRS,fATDCLK=fBUS/2/(PRS + 1)
- ATD0CTL4=0x01;
- //6---SC5,Special Channel Conversion; 5---SCAN,Continuous Conversion Sequence Mode
- //4---MULT,Multi-Channel Sample Mode; [3:0]---Analog Input Channel Select Code CD,CC,CB,CA
- //ATD0CTL5=0x01;
- //ATD0CMPE_CMPE0=1;
- //ATD0CMPHT_CMPHT0=0; //>AD0
- //ATD0DR0L=0x000f;
- ATD0DIEN=0x00;
- void IO_Init(){
- // SENSOR
- DDRB=0xff;
- PORTB=0x00;
- DDRA=0x01;
- PORTA_PA0=0;
- // KEY DEFINE
- DDRK_DDRK0 = 0;
- DDRA_DDRA1 = 0;
- DDRA_DDRA2 = 0;
- DDRA_DDRA3 = 0;
- DDRA_DDRA4 = 0;
- DDRK_DDRK1 = 0;
- DDRK_DDRK2 = 0;
- DDRK_DDRK3 = 0;
- // LCD CONTORL
- DDRA_DDRA5 = 1;
- DDRA_DDRA6 = 1;
- DDRA_DDRA7 = 1;
- //LED
- DDRK_DDRK4 = 1;
- DDRK_DDRK5 = 1;
- PORTK_PK4 = 0;
- PORTK_PK5 = 0;
- //sensor_2
- DDRK_DDRK7 = 1;
- PORTK_PK7 = 0;
- int ii,jj;
- if (ms<1) ms=1;
- for(ii=0;ii<ms;ii++)
- for(jj=0;jj<2670;jj++); //busclk:16MHz--1ms
- void delay(unsigned int ref){
- uint kk;
- for(kk=0;kk<ref;kk++){
- asm nop;
- /************************LCD drive start*************************/
- void LcdInit(){
- LCD_DATA_DIR = LCD_DIR_OUT;
- LcdDelay(21);
- LcdCommand(DATA_MODE,1); //set 8 bit data transmission mode
- LcdDelay(7);
- LcdDelay(7);
- LcdCommand(CLR,0); //clear screen
- LcdCommand(INPUTMODE_CUR_R | INPUTMODE_ALL_D, 1); // cursor right, disable moving
- LcdCommand(SCREEN_OPEN, 1); //open display (enable lcd display)
- LcdCommand(LINE1_HEAD,1); //set lcd first display address
- LcdCommand(CLR,1); //clear screen
- unsigned char cRtn;
- LCD_DATA_DIR = LCD_DIR_IN;
- RS = 0;
- RW = 1;
- EN = 0;
- delay(500);
- EN = 1;
- while (LCD_DATA & BUSY); //Test Busy State
- cRtn = LCD_DATA_DIR; // if Not save the port value, it should be change
- return(cRtn);
- void LcdCommand(unsigned char command,unsigned char BusyC){
- if (BusyC)
- ReadStatus(); //Test it busy or not
- LCD_DATA=command;
- RS=0;
- RW=0;
- EN=0;
- delay(500);
- EN=1;
- void LcdData(unsigned char dat,unsigned char BusyC)
- if (BusyC)
- LCD_DATA=dat;
- RS=1;
- RW=0;
- EN=0;
- delay(500);
- EN=1;
- void LcdDelay(byte k){ //k=7=5ms
- uint i, j;
- for (i = 0; i < k; i++)
- for(j = 0; j < 4780; j++);
- void GotoXY( unsigned char x, unsigned char y ){
- unsigned char address;
- if (y == LINE1)
- address = LINE1_HEAD + x;
- else
- address = LINE2_HEAD + x;
- LcdCommand(address,1);
- void Lcd_Print_Int( unsigned char x,unsigned char y,unsigned int data){
- char i=0;
- unsigned char a[5];
- a[0]=(data/10000)%10+'0';
- a[1]=(data/1000)%10+'0';
- a[2]=(data/100)%10+'0';
- a[3]=(data/10)%10+'0';
- a[4]=data%10+'0';
- for(i=0; i<5; i++)
- GotoXY(i+x, y);
- LcdData(a[i],1);
- char j=0;
- unsigned char a[3];
- a[0]=(data/100)%10+'0';
- a[1]=(data/10)%10+'0';
- a[2]=data%10+'0';
- for(j=0; j<3; j++)
- GotoXY(j+x, y);
- LcdData(a[j],1);
- char j=0,k=0;
- if(data>=0){
- a[2]=data%10+'0';
- GotoXY(j+x, y);
- LcdData(a[j],1);
- else{
- data=~data;
- data++;
- a[2]=data%10+'0';
- Lcd_Print_Str(x,y,"-");
- for(k=0; k<3; k++)
- GotoXY(k+x+1, y);
- LcdData(a[k],1);
- GotoXY(x,y); //set address
- while(*s!='\0') // write character
- LcdData(*s, 1);
- s++;
- /************************LCD drive end***************************/
- // HARDWARE FUN END
- // STARTEGY FUN START
- void light_flip(){
- ATD0CTL3=0xc8;
- ATD0CTL5=0x10;
- while(!ATD0STAT0_SCF);
- flip_data[0]=ATD0DR0L;
- flip_data[1]=ATD0DR1L;
- flip_data[2]=ATD0DR2L;
- flip_data[3]=ATD0DR3L;
- flip_data[4]=ATD0DR4L;
- flip_data[5]=ATD0DR5L;
- flip_data[6]=ATD0DR6L;
- flip_data[7]=ATD0DR7L;
- flip_data[8]=ATD0DR8L;
- void AD_DATA_HIGHT()
- //light_flip();
- ATD0CTL3=0x98;
- ATD0CTL5=0x13;
- flip_data[3]=ATD0DR0L;
- flip_data[4]=ATD0DR1L;
- flip_data[5]=ATD0DR2L;
- PORTB = 0x08|0x10|0x20;
- delay(L_times);
- ATD0CTL3=0x98;
- ATD0CTL5=0x13;
- data[3]= ATD0DR0L;
- data[4]= ATD0DR1L;
- data[5]= ATD0DR2L;
- PORTB = 0x00;
- ATD0CTL3=0x98;
- ATD0CTL5=0x10;
- PORTB = 0x01|0x02|0x04;
- delay(L_times);
- ATD0CTL3=0x98;
- ATD0CTL5=0x10;
- data[0]= ATD0DR0L;
- data[1]= ATD0DR1L;
- data[2]= ATD0DR2L;
- PORTB = 0x00;
- ATD0CTL3=0x98;
- ATD0CTL5=0x16;
- flip_data[6]=ATD0DR0L;
- flip_data[7]=ATD0DR1L;
- flip_data[8]=ATD0DR2L;
- PORTB = 0x40|0x80;
- PORTA_PA0=1;
- delay(L_times);
- ATD0CTL3=0x98;
- ATD0CTL5=0x16;
- data[6]= ATD0DR0L;
- data[7]= ATD0DR1L;
- data[8]= ATD0DR2L;
- PORTB = 0x00;
- PORTA_PA0=0;
- //printp("\n %D,%D,%D,%D,%D,%D,%D,%D,%D \n",flip_data[0],flip_data[1],flip_data[2],flip_data[3],flip_data[4],flip_data[5],flip_data[6],flip_data[7],flip_data[8]);
- void AD_DATA_LOW(){
- ATD0CTL3=0xa8;
- ATD0CTL5=0x19;
- data_2[0]=ATD0DR0L;
- data_2[1]=ATD0DR1L;
- data_2[2]=ATD0DR2L;
- data_2[3]=ATD0DR3L;
- data_2[4]=ATD0DR4L;
- //----------------------------压差归一------------------------------//
- void VOL_Normaliz(){
- uchar aa;
- char show_vol=0;
- if(PORTK_PK3==1&&PORTK_PK2==1&&PORTK_PK1==1) line_num=0;
- else if(PORTK_PK3==1&&PORTK_PK2==1&&PORTK_PK1==0) line_num=6;
- else if(PORTK_PK3==1&&PORTK_PK2==0&&PORTK_PK1==1) line_num=7;
- else if(PORTK_PK3==1&&PORTK_PK2==0&&PORTK_PK1==0) line_num=8;
- else if(PORTK_PK3==0&&PORTK_PK2==1&&PORTK_PK1==1) line_num=9;
- else if(PORTK_PK3==0&&PORTK_PK2==1&&PORTK_PK1==0) line_num=10;
- else if(PORTK_PK3==0&&PORTK_PK2==0&&PORTK_PK1==1) line_num=11;
- else if(PORTK_PK3==0&&PORTK_PK2==0&&PORTK_PK1==0) line_num=12;
- while(KEY_RUN_OR_LCD==1) {
- LCD_DISPLAY();
- key_r_o_l=0xff;
- while(KEY_START_RUN ==1){
- AD_DATA_HIGHT();
- for(aa=0;aa<9;aa++){
- if(data[aa]>max_vol[aa]) max_vol[aa]=data[aa];
- if(data[aa]<min_vol[aa]) min_vol[aa]=data[aa];
- if((max_vol[aa]-min_vol[aa])>det_vol[aa]){ //det_vol impossible zero
- det_vol[aa]=max_vol[aa]-min_vol[aa];
- if(lcd_print==1) {
- if(KEY_DOWN==0)
- Dly_ms(1);
- if(KEY_DOWN==0){
- show_vol++;
- if(show_vol>10) show_vol=0;
- while(!KEY_DOWN);
- if(KEY_UP==0){
- Dly_ms(1);
- if(KEY_UP==0){
- show_vol--;
- if(show_vol<0) show_vol=10;
- while(!KEY_UP);
- if(show_vol==0){
- Lcd_Print_Str(0,0,"data[0]-data[2]:");
- Lcd_Print_Char(0,1,data[0]);
- Lcd_Print_Char(6,1,data[1]);
- Lcd_Print_Char(12,1,data[2]);
- if(show_vol==1){
- Lcd_Print_Str(0,0,"data[3]-data[5]:");
- Lcd_Print_Char(0,1,data[3]);
- Lcd_Print_Char(6,1,data[4]);
- Lcd_Print_Char(12,1,data[5]);
- if(show_vol==2){
- Lcd_Print_Str(0,0,"data[6]-data[8]:");
- Lcd_Print_Char(0,1,data[6]);
- Lcd_Print_Char(6,1,data[7]);
- Lcd_Print_Char(12,1,data[8]);
- if(show_vol==3){
- Lcd_Print_Str(0,0," det[0]-det[2]: ");
- Lcd_Print_Char(0,1,det_vol[0]);
- Lcd_Print_Char(6,1,det_vol[1]);
- Lcd_Print_Char(12,1,det_vol[2]);
- if(show_vol==4){
- Lcd_Print_Str(0,0," det[3]-det[5]: ");
- Lcd_Print_Char(0,1,det_vol[3]);
- Lcd_Print_Char(6,1,det_vol[4]);
- Lcd_Print_Char(12,1,det_vol[5]);
- if(show_vol==5){
- Lcd_Print_Str(0,0," det[6]-det[8]: ");
- Lcd_Print_Char(0,1,det_vol[6]);
- Lcd_Print_Char(6,1,det_vol[7]);
- Lcd_Print_Char(12,1,det_vol[8]);
- if(show_vol==6){
- Lcd_Print_Str(0,0," flip[0]---[2]: ");
- Lcd_Print_Char(0,1,flip_data[0]);
- Lcd_Print_Char(6,1,flip_data[1]);
- Lcd_Print_Char(12,1,flip_data[2]);
- if(show_vol==7){
- Lcd_Print_Str(0,0," flip[3]---[5]: ");
- Lcd_Print_Char(0,1,flip_data[3]);
- Lcd_Print_Char(6,1,flip_data[4]);
- Lcd_Print_Char(12,1,flip_data[5]);
- if(show_vol==8){
- Lcd_Print_Str(0,0," flip[6]---[8]: ");
- Lcd_Print_Char(0,1,flip_data[6]);
- Lcd_Print_Char(6,1,flip_data[7]);
- Lcd_Print_Char(12,1,flip_data[8]);
- if(show_vol==9)
- Lcd_Print_Str(0,0,"data_2[0--3]");
- Lcd_Print_Char(0,1,data_2[0]);
- Lcd_Print_Char(6,1,data_2[1]);
- Lcd_Print_Char(12,1,data_2[2]);
- if(show_vol==10)
- Lcd_Print_Str(0,0,"data_2[4--5]");
- Lcd_Print_Char(0,1,data_2[3]);
- Lcd_Print_Char(6,1,data_2[4]);
- if(lcd_print==2){
- printp("\n %D %D %D %D %D %D %D %D %D \n",data[0],data[1],data[2],data[3],data[4],data[5],data[6],data[7],data[8]);
- printp("\n det :%D %D %D %D %D %D %D %D %D \n",det_vol[0],det_vol[1],det_vol[2],det_vol[3],det_vol[4],det_vol[5],det_vol[6],det_vol[7],det_vol[8]);
- void err_calculate_low(){
- uchar jj,b_num=0;
- AD_DATA_LOW();
- for(jj=0;jj<5;jj++){
- if(data_2[jj]<THRESHOLD_2) b_num++;
- if(b_num==1||b_num==2)
- if(data_2[0]<THRESHOLD_2&&data_2[1]<THRESHOLD_2) err_e2[0]=37;
- else if(data_2[1]<THRESHOLD_2&&data_2[2]<THRESHOLD_2) err_e2[0]=15;
- else if(data_2[2]<THRESHOLD_2&&data_2[3]<THRESHOLD_2) err_e2[0]=-15;
- else if(data_2[3]<THRESHOLD_2&&data_2[4]<THRESHOLD_2) err_e2[0]=-37;
- else if(data_2[2]<THRESHOLD_2) err_e2[0]=0;
- else if(data_2[0]<THRESHOLD_2) err_e2[0]=45;
- else if(data_2[1]<THRESHOLD_2) err_e2[0]=30;
- else if(data_2[3]<THRESHOLD_2) err_e2[0]=-30;
- else if(data_2[4]<THRESHOLD_2) err_e2[0]=-45;
- err[0]=err_e2[1];
- err_e2[1]=err_e2[0];
- void err_calculate_hight()
- byte black_l=0,black_r=8,slope_num=0,min_slope=0,black=0;
- uchar ii=0,max_num=0,max_black=100,n=0;
- schar det_spacing=0,spacing=0;
- uchar up_edge=0,down_edge=0;
- byte black_num=0,white_num=0,zero_num=0;
- //flip=0;
- AD_DATA_HIGHT();
- for(ii=0;ii<9;ii++)
- if(data[ii]<=min_vol[ii]) percent[ii]=1;
- else if(data[ii]>=max_vol[ii]) percent[ii]=100;
- else percent[ii]=(data[ii]-min_vol[ii])*100/det_vol[ii];
- if(percent[ii]<max_black&&percent[ii]<=40)
- max_black=percent[ii];
- max_num=ii;
- if(percent[ii]<=40) {
- black_num++;
- if(data[ii]-max_vol[ii]>25) slope_num++;
- if(percent[ii]<=20) zero_num++;
- if(percent[ii]>=50) white_num++;
- for(ii=0;ii<9;ii++){
- if(percent[ii]<40) {
- black_l=ii;
- break;
- for(ii=8;ii>0;ii--){
- if(percent[ii]<40){
- black_r=ii;
- break;
- //----------------------flip----------------------//
- if(black_r-black_l==0||black_r-black_l==1) {
- flip=1; //黑线连续,个数规定,数据可用?
- PORTK_PK5=1;
- else if((black_r-black_l)==2&&(black_r+black_l)/2<40) {
- flip=1;
- PORTK_PK5=1;
- else {
- flip=0;
- PORTK_PK5=0;
- //------------------------slope------------------------//
- //前排为上坡
- if(check==0&&slope_num>=7&&slope_bit==0){
- slope_bit=1; //连续检测到正常时清除标志
- PORTK_PK7=1;
- //PORTK_PK4=1;
- KP=13;
- check=0;
- //------------------------start-line------------------------//
- else if(slope_bit==0&&zero_num>=2&&black_num>=6&&check==0&&abs(err_e[0]-err_e[1])<=120){
- slope_bit=0;
- check=1;
- PORTK_PK7 = 1; //打开下排
- //PORTK_PK4=1;
- //----------------------前排检测到跑道-------------------------//
- if(flip==1&&abs(max_num-max_num_p)<=4)
- if(slope_bit==1){ //连续地看到了数值
- slope_time=1;
- else if(slope_bit==0){
- if(max_num==0) err_e[0]=120-30*percent[max_num]/(percent[max_num]+percent[max_num+1]);
- else if(max_num==8) err_e[0]=-120+30*percent[max_num]/(percent[max_num]+percent[max_num-1]);
- else
- switch(max_num)
- case 1:spacing=90; break;
- case 2:spacing=60; break;
- case 3:spacing=30; break;
- case 4:spacing=0; break;
- case 5:spacing=-30; break;
- case 6:spacing=-60; break;
- case 7:spacing=-90; break;
- default:
- break;
- if(percent[max_num+1]==percent[max_num-1]) err_e[0]=spacing;
- else if(percent[max_num+1]<percent[max_num-1])
- err_e[0]=spacing-30*percent[max_num]/(percent[max_num+1]+percent[max_num]);
- else if(percent[max_num+1]>percent[max_num-1])
- err_e[0]=spacing+30*percent[max_num]/(percent[max_num]+percent[max_num-1]);
- err[0]=err_e[0];
- err_e[1]=err_e[0];
- max_num_p=max_num;
- else if(slope_bit==1){
- err_calculate_low();
- if(slope_bit==0&&white_num==9&&flip==0&&abs(max_num-max_num_p)<=4){
- if(err_e[0]>=50) {
- err_e[0]=120;
- err[0]=err_e[0];
- else if(err_e[0]<=-50){
- err_e[0]=-120;
- err[0]=err_e[0];
- if(check==1)
- AD_DATA_LOW();
- for(ii=0;ii<5;ii++){
- if(data_2[ii]<THRESHOLD_2) black++;
- if(black>=3){
- black_bit=1;
- //check_pluse=0;
- //check=0;
- //PORTK_PK7=0;
- signed int PID(){
- uchar kk=0,low=0;
- sint u;
- if(err[0]<=45&&err[0]>=-45) {
- KP=5;
- u=7000+KP*err[0];
- else if(err[0]>45){
- KP=9;
- u=6920+KP*err[0];
- else if(err[0]<-45) {
- KP=9;
- u=7180+KP*err[0];
- //u=7000+KP*err[0]+KD*(err[0]-2*err[1]+err[2]);
- if(u>=8050) u=8050;
- if(u<=6100) u=6100;
- for(kk=100;kk>0;kk--) {
- err[kk]=err[kk-1];
- return(u);
- void key_scan_deal(void){
- if(PORTK_PK3==0&&PORTK_PK2==0&&PORTK_PK1==0) line_num=6;
- else if(PORTK_PK3==0&&PORTK_PK2==0&&PORTK_PK1==1) line_num=7;
- else if(PORTK_PK3==0&&PORTK_PK2==1&&PORTK_PK1==0) line_num=8;
- else if(PORTK_PK3==1&&PORTK_PK2==0&&PORTK_PK1==0) line_num=10;
- else if(PORTK_PK3==1&&PORTK_PK2==0&&PORTK_PK1==1) line_num=11;
- else if(PORTK_PK3==1&&PORTK_PK2==1&&PORTK_PK1==0) line_num=12;
- else if(PORTK_PK3==1&&PORTK_PK2==1&&PORTK_PK1==1) line_num=13;
- if(KEY_RUN_OR_LCD==0)
- LcdDelay(14);
- key_r_o_l=~key_r_o_l;
- while(!KEY_RUN_OR_LCD);
- if(key_r_o_l==0){
- //DisableInterrupts;
- RTI_SWITCH_OFF;
- IC_SWITCH_OFF;
- LCD_DISPLAY();
- PWMDTY45=PWMDTY23;
- else{
- //EnableInterrupts;
- RTI_SWITCH_ON;
- IC_SWITCH_ON;
- /*************************LCD show start************************/
- /************************KEY_DOWN*************************/
- if(KEY_DOWN==0)
- LcdDelay(7);
- if(KEY_DOWN==0)
- //控制主菜单向下 1---9
- …………限于本文篇幅 余下代码请从51黑下载附件…………
7.15(2).rar
(583.2 KB, 下载次数: 14)
