查看: 1711|回复: 0
数码管18B20温度显示程序
ID:313465 发表于 2018-4-22 00:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    #include<reg52.h>
    #include<intrins.h>
    #define  uchar  unsigned  char
    #define  uint   unsigned  int
    #define  duanma  P0
    sbit LSA=P2^2;
        sbit LSB=P2^3;
        sbit LSC=P2^4;
        sbit ds=P3^7;
        bit flag;
        uint temp;
        uint shu=0;
          uchar displaydata[4];
         uchar  code table[]={
        0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
         void digdisplay();
         void digdisplay1();
        void delayus(uint t)
         while(t--);
  void ds_reset() //18b20初始化
   ds=1;
   delayus(5);
        ds=0;
        delayus(80);//480-960us
        ds=1;
        delayus(14);
        if(ds==0)
          flag=1;
          flag=0;
          delayus(20);
bit ds_read_bit()//读一位
  bit dat;
  ds=0;
  _nop_();
  _nop_();
  ds=1;
  _nop_();
  dat=ds;
  delayus(8);
   return dat;
uchar ds_read_byte() //读一个字节
  uchar i,j,k;
  for(i=0;i<8;i++)
            j=ds_read_bit();
         k=(j<<7)|(k>>1);
        return k;
void ds_write_byte(uchar dat)//
   uchar i;
   for(i=0;i<8;i++)
            ds=0;
         _nop_();
         ds=dat&0x01;//
         delayus(1);
         ds=1;
         dat=dat>>1;
   //delayus(3);
uint read_temperature()//
  uchar a,b;
  ds_reset();
  ds_write_byte(0xcc);
  ds_write_byte(0xbe);
   a=ds_read_byte();
   b=ds_read_byte();
   temp=b;
   temp=temp<<8;
   temp=temp|a;
   temp=temp*0.0625*10+0.5;
   return temp;
void digdisplay1()
         displaydata[2]=table[temp/100];
                         displaydata[1]=table[temp%100/10]|0x80;
                        displaydata[0]=table[temp%10];
        void  main()
                 ds_reset();
           ds_write_byte(0x44);
          read_temperature();
                digdisplay1();
                 digdisplay( );
                } //while(1);
         void digdisplay()
                switch(shu)         //
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;//
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;//
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;//
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;
                        case(5):
                                LSA=1;LSB=0;LSC=1; break;
                        case(6):
                                LSA=0;LSB=1;LSC=1; break;
                        case(7):
                                LSA=1;LSB=1;LSC=1; break;
                duanma=displaydata[shu];
                shu++;
                if(shu>3)
                 shu=0;
