查看: 4501|回复: 1
matlab生成51单片机的pwm源代码 附仿真图等资料
用matlab自动生成PWM源代码,keil4编译后灌入8051芯片内,在proteus上仿真实现pwm.很好地显示了自动代码生成的过程。pwm.mdl是模型文件,pwmsil_ert_rtw在环测试。pwmsil8051_ert_rtw是keil4文件夹。pwm.dsn是proteus仿真电路图。pwmsil8051_ert_rtw是keil4文件夹。pwm.dsn是proteus电路图。
  1. /*
  2. * File: pwmSIL.c
  3. *
  4. * Real-Time Workshop code generated for Simulink model pwmSIL.
  5. *
  6. * Model version                        : 1.11
  7. * Real-Time Workshop file version      : 7.6  (R2010b)  03-Aug-2010
  8. * Real-Time Workshop file generated on : Sun May 26 11:24:29 2013
  9. * TLC version                          : 7.6 (Jul 13 2010)
  10. * C/C++ source code generated on       : Sun May 26 11:24:30 2013
  11. *
  12. * Target selection: ert.tlc
  13. * Embedded hardware selection: Intel->8051 Compatible
  14. * Code generation objectives: Unspecified
  15. * Validation result: Not run
  16. */
  17. #include "pwmSIL.h"
  18. #include "pwmSIL_private.h"
  19. /* Named constants for Stateflow: '<Root>/Chart' */
  20. #define pwmSIL_IN_a                    (1U)
  21. #define pwmSIL_IN_b                    (2U)
  22. /* Block signals (auto storage) */
  23. BlockIO_pwmSIL pwmSIL_B;
  24. /* Block states (auto storage) */
  25. D_Work_pwmSIL pwmSIL_DWork;
  26. /* External inputs (root inport signals with auto storage) */
  27. ExternalInputs_pwmSIL pwmSIL_U;
  28. /* External outputs (root outports fed by signals with auto storage) */
  29. ExternalOutputs_pwmSIL pwmSIL_Y;
  30. /* Real-time model */
  31. RT_MODEL_pwmSIL pwmSIL_M_;
  32. RT_MODEL_pwmSIL *pwmSIL_M = &pwmSIL_M_;
  33. /* Model step function */
  34. void pwmSIL_step(void)
  35. {
  36.   uint16_T tmp;
  37.   uint8_T tmp_0;
  38.   uint8_T tmp_1;
  39.   /* Stateflow: '<Root>/Chart' incorporates:
  40.    *  Inport: '<Root>/In1'
  41.    *  Inport: '<Root>/In2'
  42.    *  Inport: '<Root>/In3'
  43.    *  Inport: '<Root>/In4'
  44.    *  Inport: '<Root>/In5'
  45.    *  Inport: '<Root>/In6'
  46.    *  Inport: '<Root>/In7'
  47.    *  Inport: '<Root>/In8'
  48.    */
  49.   /* Gateway: Chart */
  50.   /* During: Chart */
  51.   if (pwmSIL_DWork.temporalCounter_i1 < MAX_uint32_T) {
  52.     pwmSIL_DWork.temporalCounter_i1 = pwmSIL_DWork.temporalCounter_i1 + 1UL;
  53.   }
  54.   if (pwmSIL_DWork.is_active_c1_pwmSIL == 0) {
  55.     /* Entry: Chart */
  56.     pwmSIL_DWork.is_active_c1_pwmSIL = 1U;
  57.     /* Transition: '<S1>:13' */
  58.     /* Entry 'a': '<S1>:1' */
  59.     pwmSIL_DWork.is_c1_pwmSIL = pwmSIL_IN_a;
  60.     pwmSIL_DWork.temporalCounter_i1 = 0UL;
  61.     /* Embedded MATLAB Function 'bin2dec': '<S1>:16' */
  62.     /* '<S1>:16:2' */
  63.     if (pwmSIL_U.In8 > 1) {
  64.       tmp_0 = MAX_uint8_T;
  65.     } else {
  66.       tmp_0 = (uint8_T)(pwmSIL_U.In8 << 7);
  67.     }
  68.     if (pwmSIL_U.In7 > 3) {
  69.       tmp_1 = MAX_uint8_T;
  70.     } else {
  71.       tmp_1 = (uint8_T)(pwmSIL_U.In7 << 6);
  72.     }
  73.     tmp = (uint16_T)tmp_0 + (uint16_T)tmp_1;
  74.     if (tmp > 255U) {
  75.       tmp = 255U;
  76.     }
  77.     if (pwmSIL_U.In6 > 7) {
  78.       tmp_0 = MAX_uint8_T;
  79.     } else {
  80.       tmp_0 = (uint8_T)(pwmSIL_U.In6 << 5);
  81.     }
  82.     tmp += (uint16_T)tmp_0;
  83.     if (tmp > 255U) {
  84.       tmp = 255U;
  85.     }
  86.     if (pwmSIL_U.In5 > 15) {
  87.       tmp_0 = MAX_uint8_T;
  88.     } else {
  89.       tmp_0 = (uint8_T)(pwmSIL_U.In5 << 4);
  90.     }
  91.     tmp += (uint16_T)tmp_0;
  92.     if (tmp > 255U) {
  93.       tmp = 255U;
  94.     }
  95.     if (pwmSIL_U.In4 > 31) {
  96.       tmp_0 = MAX_uint8_T;
  97.     } else {
  98.       tmp_0 = (uint8_T)(pwmSIL_U.In4 << 3);
  99.     }
  100.     tmp += (uint16_T)tmp_0;
  101.     if (tmp > 255U) {
  102.       tmp = 255U;
  103.     }
  104.     if (pwmSIL_U.In3 > 63) {
  105.       tmp_0 = MAX_uint8_T;
  106.     } else {
  107.       tmp_0 = (uint8_T)(pwmSIL_U.In3 << 2);
  108.     }
  109.     tmp += (uint16_T)tmp_0;
  110.     if (tmp > 255U) {
  111.       tmp = 255U;
  112.     }
  113.     if (pwmSIL_U.In2 > 127) {
  114.       tmp_0 = MAX_uint8_T;
  115.     } else {
  116.       tmp_0 = (uint8_T)(pwmSIL_U.In2 << 1);
  117.     }
  118.     tmp += (uint16_T)tmp_0;
  119.     if (tmp > 255U) {
  120.       tmp = 255U;
  121.     }
  122.     tmp += (uint16_T)pwmSIL_U.In1;
  123.     if (tmp > 255U) {
  124.       tmp = 255U;
  125.     }
  126.     pwmSIL_DWork.v = (uint8_T)tmp;
  127.     pwmSIL_B.pwm = 1U;
  128.   } else {
  129.     switch (pwmSIL_DWork.is_c1_pwmSIL) {
  130.      case pwmSIL_IN_a:
  131.       /* During 'a': '<S1>:1' */
  132.       if (pwmSIL_DWork.temporalCounter_i1 >= (uint32_T)(pwmSIL_DWork.v / 10)) {
  133.         /* Transition: '<S1>:14' */
  134.         /* Exit 'a': '<S1>:1' */
  135.         /* Entry 'b': '<S1>:12' */
  136.         pwmSIL_DWork.is_c1_pwmSIL = pwmSIL_IN_b;
  137.         pwmSIL_DWork.temporalCounter_i1 = 0UL;
  138.         /* Embedded MATLAB Function 'bin2dec': '<S1>:16' */
  139.         /* '<S1>:16:2' */
  140.         if (pwmSIL_U.In8 > 1) {
  141.           tmp_0 = MAX_uint8_T;
  142.         } else {
  143.           tmp_0 = (uint8_T)(pwmSIL_U.In8 << 7);
  144.         }
  145.         if (pwmSIL_U.In7 > 3) {
  146.           tmp_1 = MAX_uint8_T;
  147.         } else {
  148.           tmp_1 = (uint8_T)(pwmSIL_U.In7 << 6);
  149.         }
  150.         tmp = (uint16_T)tmp_0 + (uint16_T)tmp_1;
  151.         if (tmp > 255U) {
  152.           tmp = 255U;
  153.         }
  154.         if (pwmSIL_U.In6 > 7) {
  155.           tmp_0 = MAX_uint8_T;
  156.         } else {
  157.           tmp_0 = (uint8_T)(pwmSIL_U.In6 << 5);
  158.         }
  159.         tmp += (uint16_T)tmp_0;
  160.         if (tmp > 255U) {
  161.           tmp = 255U;
  162.         }
  163.         if (pwmSIL_U.In5 > 15) {
  164.           tmp_0 = MAX_uint8_T;
  165.         } else {
  166.           tmp_0 = (uint8_T)(pwmSIL_U.In5 << 4);
  167.         }
  168.         tmp += (uint16_T)tmp_0;
  169.         if (tmp > 255U) {
  170.           tmp = 255U;
  171.         }
  172.         if (pwmSIL_U.In4 > 31) {
  173.           tmp_0 = MAX_uint8_T;
  174.         } else {
  175.           tmp_0 = (uint8_T)(pwmSIL_U.In4 << 3);
  176.         }
  177.         tmp += (uint16_T)tmp_0;
  178.         if (tmp > 255U) {
  179.           tmp = 255U;
  180.         }
  181.         if (pwmSIL_U.In3 > 63) {
  182.           tmp_0 = MAX_uint8_T;
  183.         } else {
  184.           tmp_0 = (uint8_T)(pwmSIL_U.In3 << 2);
  185.         }
  186.         tmp += (uint16_T)tmp_0;
  187.         if (tmp > 255U) {
  188.           tmp = 255U;
  189.         }
  190.         if (pwmSIL_U.In2 > 127) {
  191.           tmp_0 = MAX_uint8_T;
  192.         } else {
  193.           tmp_0 = (uint8_T)(pwmSIL_U.In2 << 1);
  194.         }
  195.         tmp += (uint16_T)tmp_0;
  196.         if (tmp > 255U) {
  197.           tmp = 255U;
  198.         }
  199.         tmp += (uint16_T)pwmSIL_U.In1;
  200.         if (tmp > 255U) {
  201.           tmp = 255U;
  202.         }
  203.         pwmSIL_DWork.v = (uint8_T)tmp;
  204.         pwmSIL_B.pwm = 0U;
  205.       }
  206.       break;
  207.      case pwmSIL_IN_b:
  208.       /* During 'b': '<S1>:12' */
  209.       if (pwmSIL_DWork.temporalCounter_i1 >= (uint32_T)((255 - pwmSIL_DWork.v) /
  210.            10)) {
  211.         /* Transition: '<S1>:15' */
  212.         /* Exit 'b': '<S1>:12' */
  213.         /* Entry 'a': '<S1>:1' */
  214.         pwmSIL_DWork.is_c1_pwmSIL = pwmSIL_IN_a;
  215.         pwmSIL_DWork.temporalCounter_i1 = 0UL;
  216.         /* Embedded MATLAB Function 'bin2dec': '<S1>:16' */
  217.         /* '<S1>:16:2' */
  218.         if (pwmSIL_U.In8 > 1) {
  219.           tmp_0 = MAX_uint8_T;
  220.         } else {
  221.           tmp_0 = (uint8_T)(pwmSIL_U.In8 << 7);
  222.         }
  223.         if (pwmSIL_U.In7 > 3) {
  224.           tmp_1 = MAX_uint8_T;
  225.         } else {
  226.           tmp_1 = (uint8_T)(pwmSIL_U.In7 << 6);
  227.         }
  228.         tmp = (uint16_T)tmp_0 + (uint16_T)tmp_1;
  229.         if (tmp > 255U) {
  230.           tmp = 255U;
  231.         }
  232.         if (pwmSIL_U.In6 > 7) {
  233.           tmp_0 = MAX_uint8_T;
  234.         } else {
  235.           tmp_0 = (uint8_T)(pwmSIL_U.In6 << 5);
  236.         }
  237.         tmp += (uint16_T)tmp_0;
  238.         if (tmp > 255U) {
  239.           tmp = 255U;
  240.         }
  241.         if (pwmSIL_U.In5 > 15) {
  242.           tmp_0 = MAX_uint8_T;
  243.         } else {
  244.           tmp_0 = (uint8_T)(pwmSIL_U.In5 << 4);
  245.         }
  246.         tmp += (uint16_T)tmp_0;
  247.         if (tmp > 255U) {
  248.           tmp = 255U;
  249.         }
  250.         if (pwmSIL_U.In4 > 31) {
  251.           tmp_0 = MAX_uint8_T;
  252.         } else {
  253.           tmp_0 = (uint8_T)(pwmSIL_U.In4 << 3);
  254.         }
  255.         tmp += (uint16_T)tmp_0;
  256.         if (tmp > 255U) {
  257.           tmp = 255U;
  258.         }
  259.         if (pwmSIL_U.In3 > 63) {
  260.           tmp_0 = MAX_uint8_T;
  261.         } else {
  262.           tmp_0 = (uint8_T)(pwmSIL_U.In3 << 2);
  263.         }
  264.         tmp += (uint16_T)tmp_0;
  265.         if (tmp > 255U) {
  266.           tmp = 255U;
  267.         }
  268.         if (pwmSIL_U.In2 > 127) {
  269.           tmp_0 = MAX_uint8_T;
  270.         } else {
  271.           tmp_0 = (uint8_T)(pwmSIL_U.In2 << 1);
  272.         }
  273.         tmp += (uint16_T)tmp_0;
  274.         if (tmp > 255U) {
  275.           tmp = 255U;
  276.         }
  277.         tmp += (uint16_T)pwmSIL_U.In1;
  278.         if (tmp > 255U) {
  279.           tmp = 255U;
  280.         }
  281.         pwmSIL_DWork.v = (uint8_T)tmp;
  282.         pwmSIL_B.pwm = 1U;
  283.       }
  284.       break;
  285.      default:
  286.       /* Transition: '<S1>:13' */
  287.       /* Entry 'a': '<S1>:1' */
  288.       pwmSIL_DWork.is_c1_pwmSIL = pwmSIL_IN_a;
  289.       pwmSIL_DWork.temporalCounter_i1 = 0UL;
  290.       /* Embedded MATLAB Function 'bin2dec': '<S1>:16' */
  291.       /* '<S1>:16:2' */
  292.       if (pwmSIL_U.In8 > 1) {
  293.         tmp_0 = MAX_uint8_T;
  294.       } else {
  295.         tmp_0 = (uint8_T)(pwmSIL_U.In8 << 7);
  296.       }
  297.       if (pwmSIL_U.In7 > 3) {
  298.         tmp_1 = MAX_uint8_T;
  299.       } else {
  300.         tmp_1 = (uint8_T)(pwmSIL_U.In7 << 6);
  301.       }
  302.       tmp = (uint16_T)tmp_0 + (uint16_T)tmp_1;
  303.       if (tmp > 255U) {
  304.         tmp = 255U;
  305.       }
  306.       if (pwmSIL_U.In6 > 7) {
  307.         tmp_0 = MAX_uint8_T;
  308.       } else {
  309.         tmp_0 = (uint8_T)(pwmSIL_U.In6 << 5);
  310.       }
  311.       tmp += (uint16_T)tmp_0;
  312.       if (tmp > 255U) {
  313.         tmp = 255U;
  314.       }
  315.       if (pwmSIL_U.In5 > 15) {
  316.         tmp_0 = MAX_uint8_T;
  317.       } else {
  318.         tmp_0 = (uint8_T)(pwmSIL_U.In5 << 4);
  319.       }
  320.       tmp += (uint16_T)tmp_0;
  321.       if (tmp > 255U) {
  322.         tmp = 255U;
  323.       }
  324.       if (pwmSIL_U.In4 > 31) {
  325.         tmp_0 = MAX_uint8_T;
  326.       } else {
  327.         tmp_0 = (uint8_T)(pwmSIL_U.In4 << 3);
  328.       }
  329.       tmp += (uint16_T)tmp_0;
  330.       if (tmp > 255U) {
  331.         tmp = 255U;
  332.       }
  333.       if (pwmSIL_U.In3 > 63) {
  334.         tmp_0 = MAX_uint8_T;
  335.       } else {
  336.         tmp_0 = (uint8_T)(pwmSIL_U.In3 << 2);
  337.       }
  338.       tmp += (uint16_T)tmp_0;
  339.       if (tmp > 255U) {
  340.         tmp = 255U;
  341.       }
  342.       if (pwmSIL_U.In2 > 127) {
  343.         tmp_0 = MAX_uint8_T;
  344.       } else {
  345.         tmp_0 = (uint8_T)(pwmSIL_U.In2 << 1);
  346.       }
  347.       tmp += (uint16_T)tmp_0;
  348.       if (tmp > 255U) {
  349.         tmp = 255U;
  350.       }
  351.       tmp += (uint16_T)pwmSIL_U.In1;
  352.       if (tmp > 255U) {
  353.         tmp = 255U;
  354.       }
  355.       pwmSIL_DWork.v = (uint8_T)tmp;
  356. ……………………
  357. …………限于本文篇幅 余下代码请从51黑下载附件…………
pwm-simulink.zip (472.35 KB, 下载次数: 41)
收藏收藏1 分享淘帖 顶 踩
ID:190374 发表于 2018-12-4 17:45 | 只看该作者
我也在做这个例子,但是我在生成hex文件后,在proteus里面仿真的时候,程序死在了startup.a51里面。请问这个你遇到过吗?
