查看: 7625|回复: 11
51单片机控制4相5线步进电机仿真与源码(按键+百分比send+UL2003+LCM12864)
ID:318520 发表于 2018-4-28 16:30 | 显示全部楼层 |阅读模式
LF20140408相5线步进电机+51单片机+UL2003+LCM12864+按键+百分比send 设计资料
步进电机仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. #include  "macro.h"
  2. uchar  buf_Direction;                  //设定步进电机的转向
  3. uint  set_speed;                          //设定步进电机的转速
  4. uchar step_motor_loop[8]={0x01,0x03,0x02,0x06,0x04,0x0C,0x08,0x09};
  5. uchar step_index;
  6. #define CST_STEP_MOTOR_Z      10                                  //正转
  7. #define CST_STEP_MOTOR_F       20                                  //反转
  8. #define CST_STEP_MOTOR_ST     0                            //停
  9. #define     fosc_12MHz                  12
  10. #define     fosc_24MHz                  24
  11. #define     fosc_setting                 fosc_12MHz
  12. //工作方式1
  13. #define CST_TIME_MS    1000
  14. #define CST_TH0          (65536-CST_TIME_MS*fosc_setting/fosc_12MHz)/256
  15. #define CST_TL0          (65536-CST_TIME_MS*fosc_setting/fosc_12MHz)%256
  16. uchar buf_SpeedString[]="    ";
  17. void iniLCD(void);
  18. void list_write_HZ_Str( int x1,int y1,  uchar *point ) ;
  19. void step_motor_driver(void)
  20. {
  21. static uint speed_delay=0;
  22. speed_delay++;
  23. if( buf_Direction==CST_STEP_MOTOR_Z)
  24.    {
  25.    P0=step_motor_loop[step_index];
  26.    if(speed_delay >=set_speed )
  27.      {
  28.       speed_delay =0;
  29.       step_index--;
  30.       if(step_index <=0)
  31.              step_index =7;
  32.           }
  33.    }
  34. else if( buf_Direction==CST_STEP_MOTOR_F)
  35.    {
  36.    P0=step_motor_loop[step_index];
  37.
  38.    if(speed_delay >=set_speed)
  39.      {
  40.       speed_delay =0;
  41.       step_index++;                                                   //大于7,从头再来
  42.       if(step_index >7)
  43.              step_index =0;
  44.           }
  45.         }
  46. else
  47.     {
  48.       speed_delay =0;
  49.       P0=0x00;
  50.     }
  51. }
  52. void caluate(void)
  53. {
  54. uchar temp=0;
  55. uint u16Temp=0;
  56. u16Temp=(100-set_speed)*100/85;
  57. buf_SpeedString[0]='0'+(u16Temp/100);
  58. buf_SpeedString[1]='0'+(u16Temp%100/10);
  59. buf_SpeedString[2]='0'+(u16Temp%100%10);
  60. buf_SpeedString[3]='%';
  61. list_write_HZ_Str(6,60,&buf_SpeedString);
  62. }
  63. //*********************************************************
  64. //******************按键处理程序****************************
  65. //************************************************************
  66. void key_Scan (void)
  67. {
  68. static uchar key_loose=0;
  69. uchar temp=0;
  70.   P1=0XFF;
  71. temp=P1&0xFF;
  72. if(key_loose >0)
  73.   {
  74.   if(temp==0xFF)
  75.      key_loose=0;
  76.   return;
  77.   }
  78. else if(temp !=0xFF)
  79.   {
  80.   key_loose=10;
  81.   temp=P1&0xFF;
  82.   switch(temp)
  83.          {
  84.           case 0xFE:
  85.                         buf_Direction=CST_STEP_MOTOR_Z;
  86.                         list_write_HZ_Str(6,20,"顺向");
  87.                          caluate();
  88.                           break;
  89.
  90.           case 0xFD:
  91.                         buf_Direction=CST_STEP_MOTOR_F;
  92.                           list_write_HZ_Str(6,20,"逆向");
  93.                             caluate();
  94.                           break;
  95.           case 0xFB:
  96.                         buf_Direction=CST_STEP_MOTOR_ST;
  97.                           list_write_HZ_Str(6,20,"停止");
  98.                           list_write_HZ_Str(6,60,"     ");
  99.                           break;
  100.           case 0xEF:
  101.                         if(buf_Direction !=CST_STEP_MOTOR_ST)
  102.                                      {
  103.                                           if(set_speed <80)
  104.                                              set_speed +=2;;      //减速
  105.                                               caluate();
  106.                                          }
  107.
  108.                                         break;
  109.           case 0xF7:
  110.                        if(buf_Direction !=CST_STEP_MOTOR_ST)
  111.                                      {
  112.                                           if(set_speed >14)
  113.                                              set_speed -=2;      //加速
  114.                                             caluate();
  115.                                          }
  116.
  117.                                         break;
  118.           default:
  119.                         break;                                //其它值返回
  120.          }
  121.   }
  122. }
  123. void isr_timer0 (void) interrupt 1 using 1
  124. {
  125. TH0=CST_TH0;
  126. TL0=CST_TL0;
  127. step_motor_driver();
  128. }
  129. void init_timer0(void)
  130. {
  131. TCON=0x00;
  132. TMOD=0x00;
  133. TL0=0x00;
  134. TH0=0x00;
  135. TCON=0x00;
  136. // Timer 0 C/T=0,定时工作方式
  137. //Timer 0 M1,M0=0,1 .work  mode 1 www.gdzs.si.gov.cn
  138. TMOD=0x01; //GATE=0,以运行控制位TR0 启动定时器0 C/T=0,定时工作方式
  139. TH0=CST_TH0;
  140. TL0=CST_TL0;
  141. TF0=0;//clear 0. count over flag.
  142. TR0=1;// enable TIMER0 ,start count
  143. ET0=1; //enable accept interrupt
  144. }
  145. //***********************主***控****程********序********************
  146. void main(void)
  147. {
  148.    P2=0xff;
  149.    P1=0xff;
  150.    P0=0Xff;
  151.    init_timer0();
  152. ……………………
  153. …………限于本文篇幅 余下代码请从51黑下载附件…………
4相5线步进电机 51单片机 UL2003 LCM12864 .zip (137.83 KB, 下载次数: 370)
参与人数 2黑币 +80 收起 理由
SD_FL + 30
ID:319747 发表于 2018-5-4 15:44 | 显示全部楼层
谢谢分享
ID:308785 发表于 2018-5-6 12:23 | 显示全部楼层
非常谢谢 你的思路
ID:323448 发表于 2018-5-6 14:31 | 显示全部楼层
不错,学习了
ID:331388 发表于 2018-5-18 14:45 | 显示全部楼层
感谢分享
ID:307437 发表于 2018-5-19 14:35 | 显示全部楼层
绝世好帖 刚刚好需要
ID:355787 发表于 2019-4-14 20:58 | 显示全部楼层
下载下来,工程文件打不开
ID:363260 发表于 2019-11-11 14:45 | 显示全部楼层
感谢大佬的分享哈哈哈哈
ID:124348 发表于 2020-5-27 17:00 | 显示全部楼层
LCM12864的应用真难找
ID:297735 发表于 2021-3-16 09:57 | 显示全部楼层
学习了  谢谢大佬
ID:608007 发表于 2021-6-26 15:05 | 显示全部楼层
感谢  楼主的程序分享
ID:822053 发表于 2022-4-9 18:22 | 显示全部楼层
绝对的大佬,按键的定义不是小白能找到的
