测控技术与仪器课程设计分享:
这是一个监测Si7021温湿度的课程设计采用stc单片机 带存储模块 按键模块 报警模块 具体程序在附件里面 全套设计
Altium Designer画的Si7021温湿度报警与控制电路原理图和PCB图如下:(51hei附件中可下载工程文件)
57271+Si7021温湿度传感器+高精度+I2C接口的源码(arduino与单片机各平台的都有)与资料下载:
Si7021温湿度传感器的整个系统单片机源程序如下:
- #include "get_data.h"
- //#include "L_lcd1602.h"
- #include <reg52.h>
- unsigned char r_24humid;
- unsigned char w_24humid;
- unsigned char s_24humid[3];//24C64温度量
- unsigned char r_24TemperH;
- unsigned char r_24TemperL;
- unsigned char w_24TemperH;
- unsigned char w_24TemperL;
- unsigned char s_24TemperH[3];
- unsigned char s_24TemperL[2]="11";//24c64湿度量
- unsigned char LC;
- unsigned char LC1;
- unsigned int storaddH=0x00;
- unsigned int storaddL=0x00;
- unsigned int reaaddH=0x00;
- unsigned int reaaddL=0x00;
- unsigned char k1value=0;
- unsigned char k2value=0;
- unsigned char k3value=0;
- unsigned char k4value=0;
- unsigned char S_Speed=0;//采样周期档1:5 second
- unsigned char S_Speeded[2];
- extern unsigned char pageflag;
- extern int scal;
- // unsigned char s_24temperd1[3];//24c64数据
- unsigned char temp_array[3]=" ";
- unsigned char temp_array1[2]=" ";//存小数位
- unsigned char Rf_Rec_Cnt;
- unsigned long cal_temp_u32=0;
- unsigned int cal_temp_u16=0;
- unsigned char RH_value;
- unsigned char TEMP_H;
- unsigned char TEMP_L;
- unsigned char gv_uart_buf[MAX_UART_BUF];
- unsigned char gv_uart_buflen;
- typedef struct _si7021_value_{
- union16 temp;
- union16 humi;
- unsigned char crc;
- }si7021_value_ST, *p_si7021_value_ST;
- si7021_value_ST gv_si7021_value;
- void Get_temper(void)
- measure_si7021 ( TEMP_HOLD_MASTER, (union16 *)(&gv_si7021_value.temp) );
- gv_uart_buf[2] = gv_si7021_value.temp.unchar[HSB];
- gv_uart_buf[3] = gv_si7021_value.temp.unchar[LSB];
- cal_temp_u16 = gv_uart_buf[2];
- cal_temp_u16 = cal_temp_u16 <<8;
- cal_temp_u16 += gv_uart_buf[3];
- cal_temp_u32 = cal_temp_u16;
- cal_temp_u32 = 17572* cal_temp_u32;
- cal_temp_u32 = cal_temp_u32 >>16;
- cal_temp_u32 = cal_temp_u32 -4685;
- TEMP_H = cal_temp_u32/100;
- w_24TemperH = TEMP_H;//24c64存储
- TEMP_L = cal_temp_u32%100;
- LC = TEMP_L;//24c64存储///////////////////////
- void Get_humidity()
- measure_si7021 ( HUMI_HOLD_MASTER, (union16 *)(&gv_si7021_value.humi) );
- gv_uart_buf[4] = gv_si7021_value.humi.unchar[HSB];
- gv_uart_buf[5] = gv_si7021_value.humi.unchar[LSB];
- cal_temp_u16 =(int*)gv_uart_buf[4];
- cal_temp_u16 += gv_uart_buf[5];
- cal_temp_u32 = 125* cal_temp_u32;
- cal_temp_u32 = cal_temp_u32-6;
- RH_value = (unsigned char*)cal_temp_u32;
- w_24humid=RH_value;//24c64存数据
- //hex_to_assic1(RH_value,temp_array);
- //write_string(0,0,"Humidity:");
- //write_string(9,0,temp_array);
- void showdata()
- hex_to_assic1(RH_value,temp_array);
- write_string(0,0,"Humidity:");
- write_string(9,0,temp_array);//湿度
- write_string(12,0,"% ");
- hex_to_assic1(TEMP_H,temp_array);
- write_string(0,1,"Temper:");
- write_string(7,1,temp_array);////////////////////////////
- write_string(10,1,".");
- hex_to_assic2(TEMP_L,temp_array1);
- write_string(11,1,temp_array1);///////////温度
- write_string(13,1,"du ");
- void L_24c64stor(void)
- w_24c64_data(storaddH,storaddL,w_24humid);
- if( storaddL!=0xff )
- storaddL=storaddL+1;
- if( storaddL==0xff&&storaddH!=0xff )
- storaddH=storaddH+1;
- if( storaddH==0xff)
- storaddH=0x00;
- storaddL=0x00;
- //r_24c64_data(0x00,0x00,&r_24humid);
- //hex_to_assic1(r_24humid, s_24humid);
- w_24c64_data(storaddH,storaddL,w_24TemperH);
- if( storaddH==0xff )
- storaddH=0x00;
- storaddL=0x00;
- w_24c64_data(storaddH,storaddL,LC);//存温度低八位
- storaddH=0x00;
- storaddL=0x00;
- //r_24c64_data(0x00,0x01,&r_24TemperH);
- //r_24c64_data(0x00,0x02,&LC1);////读温度低八位
- //hex_to_assic1(r_24TemperH, s_24TemperH);
- //hex_to_assic2(LC1, s_24TemperL);//显示温度低八位
- /*write_string(0,1,s_24humid);
- write_string(5,1,s_24TemperH);
- write_string(8,1,".");
- write_string(9,1,s_24TemperL);*/
- void L_24c64read(void)
- r_24c64_data(reaaddH,reaaddL,&r_24humid);
- if( reaaddL!=0xff)
- reaaddL=reaaddL+1;
- if( reaaddL==0xff&&reaaddH!=0xff )
- reaaddH=reaaddH+1;
- if(reaaddH==0xff )
- reaaddH=0x00;
- reaaddL=0x00;
- hex_to_assic1(r_24humid, s_24humid);
- r_24c64_data(reaaddH,reaaddL,&r_24TemperH);//读温度高位
- if( reaaddL!=0xff )
- if( reaaddH==0xff )
- reaaddH=0x00;
- reaaddL=0x00;
- hex_to_assic1(r_24TemperH, s_24TemperH);
- r_24c64_data(reaaddH,reaaddL,&LC1);////读温度低八位
- reaaddH=0x00;
- reaaddL=0x00;
- hex_to_assic2(LC1, s_24TemperL);//生成显示字符串--温度低八位
- void datapage()
- write_com(0x01);
- //delayms(1);
- L_24c64read();
- write_string(0,0,"data:");
- write_string(5,0,s_24humid);
- write_string(8,0,"%");
- write_string(9,0,s_24TemperH);
- write_string(12,0,".");
- write_string(13,0,s_24TemperL);
- write_string(15,0,"D");
- //delayms(1);
- L_24c64read();
- write_string(0,1,"data:");
- write_string(5,1,s_24humid);
- write_string(8,1,"%");
- write_string(9,1,s_24TemperH);
- write_string(12,1,".");
- write_string(13,1,s_24TemperL);
- write_string(15,1,"D");
- //while((!k1value)||(!k4value));
- k3value=0;
- k4value=0;
- while((!k3value)&&(!k4value))//K4 fanye K-3结束
- keyvalue();
- void speedpage()
- write_com(0x01);
- delayms(1);
- write_string(0,0,"Sample_Speed:");
- hex_to_assic2(S_Speed, S_Speeded);
- write_string(6,1,S_Speeded);
- //write_string(0,1,"Back_light:");
- //write_string(12,1,"off");
- while((!k1value))
- //k1value
- keyvalue();
- if(k2value==1)
- k2value=0;
- if(S_Speed==3) S_Speed=0;
- else S_Speed=S_Speed+1;
- if(S_Speed==0) scal=100;
- if(S_Speed==1) scal=6000;
- if(S_Speed==2) scal=12000;
- if(S_Speed==3) scal=36000;
- /*if(k4value==1)
- k4value=0;
- if(S_Speed>=1)
- S_Speed=S_Speed-1;
- write_string(12,0,S_Speeded);
- if(k2value==1)
- k2value=0;
- Back_light=1;
- //hex_to_assic2(S_Speed, S_Speeded);
- write_string(12,1,"on ");
- delayms(200);
- void Timer0Init(void) //500??@11.0592MHz
- TMOD = 0x01; //???16???????
- TH0 =0x4b;
- TL0 =0xfd; //50ms
- ET0 = 1; //????0??
- TR0 = 1;//?????0
- EA = 1; //????
- void keyint()
- K1=1;
- K2=1;
- …………限于本文篇幅 余下代码请从51黑下载附件…………
温湿度传感器设计.rar
(9.38 MB, 下载次数: 129)
