查看: 1186|回复: 0
新手一枚,求详细注释
ID:319848 发表于 2018-5-1 14:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
sbit Speak = P2^7;
sbit RED          = P3^3;
sbit GREEN = P3^4;
sbit Relay = P3^2;
sbit KEY1 = P1^3;
sbit KEY2 = P1^4;
sbit KEY3 = P1^5;
sbit KEY4 = P1^6;
sbit KEY5 = P1^7;
unsigned char idata RevBuffer[30];
unsigned char Card_Num;
void iccardcode();
//系统初始化
void InitializeSystem()
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
         M500PcdConfigISOType( 'A' );
unsigned char idata UID[4],Temp[4];
unsigned char Table[3];
unsigned char Num;
unsigned char Count,Countf,Count1,Count2,Count3,Count4,Count5,C_flag;
void Auto_Reader(void)
    if(PcdRequest(0x52,Temp)==0)
      if(PcdAnticoll(UID)==0)
                            Speak=0;delay_10ms(20);Speak=1;
                        Table[0]=UID[0]/100+0x30;
                        Table[1]=UID[0]/10%10+0x30;
                        Table[2]=UID[0]%10+0x30;
                        LCD1602_Disp_ZF(0x80+0x40,"Num:            ",16);
                        LCD1602_Disp_ZF(0x84+0x40,Table,3);
                        Count =  UID[0];
                        if((Count==Count1)||(Count==Count2)||(Count==Count3)||(Count==Count4)||(Count==Count5))
                                LCD1602_Disp_ZF(0x8a+0x40,"OK   ",5);
                                GREEN = 0;Relay=0;delay_10ms(200);Relay=1;GREEN = 1;
                                C_flag=1;
                                LCD1602_Disp_ZF(0x8a+0x40,"Error",5);
                                RED = 0;delay_10ms(200);RED = 1;
                                C_flag=2;
                        delay_10ms(200);
                           LCD1602_Disp_ZF(0x80+0x40,"Please Swipecard",16);
uchar DS1302_Table[7]={0};        //读取时间值
void Display_LCD2(uchar Dis_Hour,uchar Dis_Min,uchar Dis_Sec)
        uchar Dis_Table[8]="11:22:33";
        Dis_Table[0] = Dis_Hour/10+0x30;
        Dis_Table[1] = Dis_Hour%10+0x30;
        Dis_Table[3] = Dis_Min/10+0x30;
        Dis_Table[4] = Dis_Min%10+0x30;
        Dis_Table[6] = Dis_Sec/10+0x30;
        Dis_Table[7] = Dis_Sec%10+0x30;
        LCD1602_Disp_ZF(0x85,Dis_Table,8);
