这是改过的程序
- #include <REG52.h>
- #include<intrins.h>
- sbit K1=P1^2;
- sbit ALAM = P2^5; //报警
- sbit open_led=P2^3; //开锁指示灯
- /*LCD接口定义*/
- sbit LcdRS = P2^0; //lcd数据/命令选择端 数据1命令0
- sbit LcdRW = P2^1; //lcd读/写选择端 读1写0
- sbit LcdEn = P2^2; //lcd使能控制端 1有效
- sfr LcdIO = 0x80; //lcd数据接口 P0=0x80
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盘扫描控制表
- unsigned char countt0,second; //t0中断计数器,秒计数器
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"===Coded Lock==="}; //显示名称
- unsigned char code Error[] = {" error "}; //输入错误
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- char InputData[6]; //输入密码暂存区
- unsigned char CurrentPassword[6]={6,5,4,3,2,1}; //当前密码值
- unsigned char N=0; //密码输入位数记数
- unsigned char ErrorCont; //错误次数计数
- unsigned char KEY_SCAN,NUM;
- /****向LCD写入命令或数据部分****/
- #define LCD_COMMAND 0 // 输出指令
- #define LCD_DATA 1 // 输出数据
- #define LCD_CLEAR_SCREEN 0x01 // 清屏指令
- #define LCD_HOME 0x02 // 光标返回原点指令
- //=====================16us短延时==============================
- void Delay_short(unsigned int n)
- unsigned int i;
- for(i=0;i<n;i++)
- //=====================长延时==============================
- void Delay_long(unsigned char N)
- unsigned char i;
- unsigned int j;
- for(i=0;i<N;i++)
- for(j=0;j<315;j++) //一个循环16us,共5ms
- //=====================5ms延时==============================
- void Delay5Ms(void)
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延时==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- /*写LCD子程序 */
- /*入口参数:数据style=1 指令, style=0 input:写入的内容*/
- void LCD_Write(bit style, unsigned char input)
- LcdRS=style; //数据style=1 指令style=0
- LcdRW=0; //写
- LcdIO=input; //P0口输出
- Delay_short(10); //延时
- LcdEn=1; //lcd使能
- LcdEn=0; //停止
- /****初始化LCD程序****/
- void LCD_Initial()
- Delay_long(6); //延迟5*6=30ms
- LCD_Write(LCD_COMMAND,0x38); //8位数据端口,2行显示,5*7点阵
- LCD_Write(LCD_COMMAND,0x38); //发送三遍
- Delay_short(2); //延迟大于39us
- LCD_Write(LCD_COMMAND,0x0c); //显示模式设置:开启显示, 无光标 0x0c
- LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏 0x01
- Delay_short(100); //延迟大于1.53ms
- LCD_Write(LCD_COMMAND,0x06); //输入模式设置:AC递增, 画面不动 0x06
- /*液晶字符输入的位置定位程序*/
- /*入口参数:x范围:0-15 y范围:1,2*/
- void GotoXY(unsigned char x, unsigned char y)
- unsigned char address;
- if(y==1)
- address=0x80+x; //y=1显示在第一行
- else
- address=0xc0+x; //y=2显示在第二行
- LCD_Write(LCD_COMMAND, address);
- /*将字符串输出到液晶显示函数*/
- /*入口参数:字符串指针 */
- void Print(unsigned char *str)
- while(*str!='\0')
- LCD_Write(LCD_DATA,*str);
- str++;
- //==============将按键值编码为数值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- // case (0x18): k=3;break;
- // case (0x28): k=7;break;
- // case (0x48): k='#';break;
- // case (0x88): k='D';break;
- case (0x14): k=3;break;
- case (0x24): k=6;break;
- case (0x44): k=9;break;
- case (0x84): k='#';break;
- case (0x12): k=2;break;
- case (0x22): k=5;break;
- case (0x42): k=8;break;
- case (0x82): k=0;break;
- case (0x11): k=1;break;
- case (0x21): k=4;break;
- case (0x41): k=7;break;
- case (0x81): k='*';break;
- return(k);
- //=====================按键检测并返回按键值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P3=0xf0;
- if((P3&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P3^0xf0; //确定行线
- i=0;
- P3=a[i]; //精确定位
- while(i<4)
- col=~(P3&0xff); //确定列线
- break; //已定位后提前退出
- else
- i++;
- P3=a[i];
- else
- return 0xff;
- while((P3&0xf0)!=0xf0);
- return (row|col); //行线与列线组合后返回
- else
- return 0xff; //无键按下时返回0xff
- //=======================一声提示音,表示有效输入========================
- void OneAlam(void)
- unsigned char y;
- for(y=0;y<30;y++)
- ALAM=0;
- Delay_short(50);
- ALAM=1;
- Delay_short(50);
- //========================二声提示音,表示操作成功========================
- void TwoAlam(void)
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- //========================三声提示音,表示错误========================
- void ThreeAlam(void)
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- OneAlam();
- Delay5Ms();
- ALAM=1;
- //=======================输入密码错误超过三过,报警并锁死键盘======================
- void Alam_KeyUnable(void)
- P3=0x00;
- OneAlam();
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- GotoXY(0,2);
- Print(start_line);
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0;
- ALAM=1; //报警关
- ErrorCont=0; //密码错误输入次数清零
- open_led=1; //指示灯关闭
- N=0; //输入位数计数器清零
- //==========================确认键,并通过相应标志位执行相应功能===============================
- void Ensure(void)
- unsigned char i,j;
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i])
- i++;
- else
- ErrorCont++;
- if(ErrorCont==3) //错误输入计数达三次时,报警并锁定键盘
- GotoXY(0,2);
- Print(" KeypadLocked! ");
- TR0=1;
- do
- Alam_KeyUnable();
- while(TR0);
- return ;
- break;
- if(i==6) //密码正确输入
- GotoXY(0,2);
- Print(codepass);
- Delay400Ms();
- Delay400Ms();
- GotoXY(0,2);
- Print(LockOpen);
- TwoAlam(); //操作成功提示音
- //KEY_CLOCK=0; //开锁
- //pass=1; //置正确标志位
- open_led=0; //开锁指示灯亮
- for(j=0;j<6;j++) //将输入清除
- InputData[i]=0;
- while(1);
- else
- GotoXY(0,2);
- Print(Error);
- ThreeAlam(); //错误提示音
- Delay400Ms();
- GotoXY(0,2);
- InputData[i]=0;
- N=0; //将输入数据计数器清零,为下一次输入作准备
- void test_led()
- while(1)
- open_led=0;
- Delay400Ms();
- open_led=1;
- Delay400Ms();
- void test_alarm()
- while(1)
- ALAM=1;
- Delay_short(60);
- ALAM=0;
- Delay_short(60);
- void timer_init()
- TMOD=0x11;
- TL0=0xB0;
- TH0=0x3C;
- EA=1;
- ET0=1;
- TR0=0;
- void test_key()
- unsigned char code ascii[]={"0123456789ABCDEF"};
- KEY_SCAN=keynum();
- if(KEY_SCAN!=0xff)
- GotoXY(0,1);
- Print("key_code:0x");
- LCD_Write(LCD_DATA, ascii[KEY_SCAN/16]);
- LCD_Write(LCD_DATA, ascii[KEY_SCAN%16]);
- void keyscan() //按键扫描程序
- static bit key_sign=0; //按键自锁标志
- static bit sign=0;
- static unsigned char count=0;//计数变量
- unsigned char i;
- if(K1==0) //检测按键如果为0
- count++; //消抖计数
- if((count>=250)&&(key_sign==0))
- key_sign=1; //按键自锁标志置1
- sign=~sign;
- if(sign==1)
- for(i=0;i<N;i++)
- GotoXY(9+i,2);
- LCD_Write(LCD_DATA,InputData[i]+0x30);
- else
- for(i=0;i<N;i++)
- GotoXY(9+i,2);
- LCD_Write(LCD_DATA,'*');
- else //按键抬起
- key_sign=0; //按键自锁标志清0
- count=0; //消抖计数清0
- //==============================主函数===============================
- void main(void)
- unsigned char j;
- // test_led();
- // test_alarm();
- Delay400Ms(); //启动等待,等LCM讲入工作状态
- LCD_Initial(); //LCD初始化
- // while(1)
- // test_key();
- GotoXY(0,1);//日历显示固定符号从第一行第0个位置之后开始显示
- Print(name);//向液晶屏写日历显示的固定符号部分
- GotoXY(0,2);//时间显示固定符号写入位置,从第2个位置后开始显示
- Print(start_line);//写显示时间固定符号,两个冒号
- GotoXY(9,2); //设置光标位置
- LCD_Write(LCD_COMMAND,0x0f); //设置光标为闪烁
- // while(1);
- P3=0xFF;
- timer_init();
- Delay5Ms(); //延时片刻(可不要)
- N=0; //初始化数据输入位数
- while(1)
- if (!TR0)
- else
- KEY_SCAN = 0xff;
- NUM=coding(KEY_SCAN);
- switch(NUM)
- case 'A': ; break;
- case 'B': ; break;
- case 'C': ; break;
- case 'D': ; break;
- case '*': Cancel(); break; //取消当前输入
- case '#': Ensure(); break; //确认键,
- default:
- if(N<6) //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
- // unsigned char temp;
- OneAlam(); //按键提示音
- for(j=N;j<=N;j++)
- GotoXY(9+j,2);
- /* if(K1==0)
- GotoXY(9+N,2);
- temp=NUM+0x30 ;
- LCD_Write(LCD_DATA,temp);
- InputData[N]=NUM;
- N++;
- else //输入数据位数大于6后,忽略输入
- N=6;
- break;
- keyscan();
- //*********************************中断服务函数**************************************
- void time0_int(void) interrupt 1
- TL0=0xB0;
- TH0=0x3C;
- countt0++;
- if(countt0==20)
- countt0=0;
- second++;
- if(second==10)
- P3=0xf0;
- TL0=0xB0;
- TH0=0x3C;
- second=0;
- GotoXY(0,2);
- TR0=0; //关定时器
