按你的思路写,功能基本可以实现
- #include<reg52.h>
- #include <intrins.h>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #define uint unsigned int
- #define uchar unsigned char
- typedef union //定义共同类型
- unsigned int i; //i表示测量得到的温湿度数据(int 形式保存的数据)
- float f; //f表示测量得到的温湿度数据(float 形式保存的数据)
- } value;
- enum {TEMP, HUMI};
- sbit DATA = P3^1;
- sbit SCK = P3^0;
- sbit RS = P3^4;
- sbit RW = P3^5;
- sbit E = P3^6;
- sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.数据端口
- sbit CLK =P2^0;
- sbit ST =P2^1;
- sbit EOC =P2^2;
- sbit OE =P2^3;
- sbit ADDA =P2^5;
- sbit ADDB =P2^6;
- sbit ADDC =P2^7;
- sbit KEY =P3^3; //定义按键输入端口
- uint temp;
- uchar getdata;
- /******** 1602函数声明 ********/
- void LCD_Initial();
- void GotoXY(unsigned char x, unsigned char y);
- void Print(unsigned char *str);
- void LCD_Write(bit style, unsigned char input);
- /******** SHT11函数声明 ********/
- void s_connectionreset(void);
- char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);
- void calc_sth10(float *p_humidity ,float *p_temperature);
- void delay(int z) //z为毫秒数
- int x,y;
- for(x=z;x>0;x--)
- for(y=125;y>0;y--);
- //SHT11程序
- #define noACK 0 //继续传输数据,用于判断是否结束通讯
- #define ACK 1 //结束数据传输;
- #define STATUS_REG_W 0x06 //000 0011 0
- #define STATUS_REG_R 0x07 //000 0011 1
- #define MEASURE_TEMP 0x03 //000 0001 1
- #define MEASURE_HUMI 0x05 //000 0010 1
- #define RESET 0x1e //000 1111 0
- //写字节程序
- char s_write_byte(unsigned char value)
- unsigned char i,error=0;
- for (i=0x80;i>0;i>>=1) //shift bit for masking 高位为1,循环右移
- if (i&value) DATA=1; //和要发送的数相与,结果为发送的位
- else DATA=0;
- SCK=1;
- _nop_();_nop_();_nop_(); //延时3us
- SCK=0;
- DATA=1; //释放数据线
- SCK=1;
- error=DATA; //检查应答信号,确认通讯正常
- SCK=0;
- DATA=1;
- return error; //error=1 通讯错误
- //读字节程序
- char s_read_byte(unsigned char ack)
- unsigned char i,val=0;
- DATA=1; //释放数据线
- for(i=0x80;i>0;i>>=1) //高位为1,循环右移
- SCK=1;
- if(DATA) val=(val|i); //读一位数据线的值
- SCK=0;
- DATA=!ack; //如果是校验,读取完后结束通讯;
- SCK=1;
- SCK=0;
- DATA=1; //释放数据线
- return val;
- //启动传输
- void s_transstart(void)
- DATA=1; SCK=0; //准备
- _nop_();
- SCK=1;
- _nop_();
- DATA=0;
- _nop_();
- SCK=0;
- SCK=1;
- _nop_();
- DATA=1;
- _nop_();
- SCK=0;
- //连接复位
- unsigned char i;
- for(i=0;i<9;i++) //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
- SCK=1;
- SCK=0;
- s_transstart(); //启动传输
- //软复位程序
- char s_softreset(void)
- // resets the sensor by a softreset
- unsigned char error=0;
- s_connectionreset(); //启动连接复位
- error+=s_write_byte(RESET); //发送复位命令
- //温湿度测量
- unsigned error=0;
- unsigned int i;
- switch(mode) //选择发送命令
- case TEMP : error+=s_write_byte(MEASURE_TEMP); break; //测量温度
- case HUMI : error+=s_write_byte(MEASURE_HUMI); break; //测量湿度
- default : break;
- for (i=0;i<65535;i++) if(DATA==0) break; //等待测量结束
- if(DATA) error+=1; // 如果长时间数据线没有拉低,说明测量错误
- *(p_value) =s_read_byte(ACK); //读第一个字节,高字节 (MSB)
- *(p_value+1)=s_read_byte(ACK); //读第二个字节,低字节 (LSB)
- *p_checksum =s_read_byte(noACK); //read CRC校验码
- return error; // error=1 通讯错误
- //温湿度值标度变换及温度补偿
- const float C1=-4.0; // 12位湿度精度 修正公式
- const float C2=+0.0405; // 12位湿度精度 修正公式
- const float C3=-0.0000028; // 12位湿度精度 修正公式
- const float T1=+0.01; // 14位温度精度 5V条件 修正公式
- const float T2=+0.00008; // 14位温度精度 5V条件 修正公式
- float rh=*p_humidity; // rh: 12位 湿度
- float t=*p_temperature; // t: 14位 温度
- float rh_lin; // rh_lin: 湿度 linear值
- float rh_true; // rh_true: 湿度 ture值
- float t_C; // t_C : 温度 ℃
- t_C=t*0.01 - 40; //补偿温度
- rh_lin=C3*rh*rh + C2*rh + C1; //相对湿度非线性补偿
- rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //相对湿度对于温度依赖性补偿
- if(rh_true>100)rh_true=100; //湿度最大修正
- if(rh_true<0.1)rh_true=0.1; //湿度最小修正
- *p_temperature=t_C; //返回温度结果
- *p_humidity=rh_true; //返回湿度结果
- //1602程序
- //内部等待函数**************************************************************
- unsigned char LCD_Wait(void)
- RS=0;
- RW=1; _nop_();
- E=1; _nop_();
- E=0;
- return DBPort;
- //向LCD写入命令或数据********************************************************
- #define LCD_COMMAND 0 // Command
- #define LCD_DATA 1 // Data
- #define LCD_CLEAR_SCREEN 0x01 // 清屏
- #define LCD_HOMING 0x02 // 光标返回原点
- E=0;
- RS=style;
- RW=0; _nop_();
- DBPort=input; _nop_();//注意顺序
- E=1; _nop_();//注意顺序
- E=0; _nop_();
- LCD_Wait();
- //设置显示模式************************************************************
- #define LCD_SHOW 0x04 //显示开
- #define LCD_HIDE 0x00 //显示关
- #define LCD_CURSOR 0x02 //显示光标
- #define LCD_NO_CURSOR 0x00 //无光标
- #define LCD_FLASH 0x01 //光标闪动
- #define LCD_NO_FLASH 0x00 //光标不闪动
- void LCD_SetDisplay(unsigned char DisplayMode)
- LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
- //设置输入模式************************************************************
- #define LCD_AC_UP 0x02
- #define LCD_AC_DOWN 0x00 // default
- #define LCD_MOVE 0x01 // 画面可平移
- #define LCD_NO_MOVE 0x00 //default
- void LCD_SetInput(unsigned char InputMode)
- LCD_Write(LCD_COMMAND, 0x04|InputMode);
- //初始化LCD************************************************************
- E=0;
- LCD_Write(LCD_COMMAND,0x38); //8位数据端口,2行显示,5*7点阵
- LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //开启显示, 无光标
- LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏
- LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC递增, 画面不动
- //液晶字符输入的位置************************
- if(y==0)
- LCD_Write(LCD_COMMAND,0x80|x);
- if(y==1)
- LCD_Write(LCD_COMMAND,0x80|(x-0x40));
- //将字符输出到液晶显示
- while(*str!='\0')
- LCD_Write(LCD_DATA,*str);
- str++;
- void delayus(uchar us){
- uchar i;
- while(us--)
- for(i=0;i<120;i++)
- void init(){
- TMOD=0x21;
- TH0=(65536-200)/256;
- TL0=(65536-200)%256;
- TH1=0XFD;
- TL1=0XFD;
- PCON=0X00;
- SCON=0X50;
- ES=1;
- ET0=1;
- EA=1;
- TR1=1;
- TR0=1;
- void timer0()interrupt 1
- { TH0=(65535-200)/256;
- TL0=(65535-200)%256;
- CLK=~CLK;
- void adda(uchar z,uchar x,uchar c) //选输入通道
- ADDA=z;
- ADDB=x;
- ADDC=c;
- void DH() //测量温湿度模块
- unsigned int temp,humi;
- value humi_val,temp_val; //定义两个共同体,一个用于湿度,一个用于温度
- unsigned char error; //用于检验是否出现错误
- unsigned char checksum; //CRC
- uchar TEMP1[7]; //用于记录温度
- uchar HUMI1[7]; //用于记录湿度
- error=0; //初始化error=0,即没有错误
- error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //温度测量
- error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //湿度测量
- if(error!=0) s_connectionreset(); ////如果发生错误,系统复位
- else
- humi_val.f=(float)humi_val.i; //转换为浮点数
- temp_val.f=(float)temp_val.i; //转换为浮点数
- calc_sth10(&humi_val.f,&temp_val.f); //修正相对湿度及温度
- temp=temp_val.f*10;
- humi=humi_val.f*10;
- GotoXY(0,0); //选择温度显示位置
- Print(" %C"); //4格空格
- //设置温度显示位置
- TEMP1[0]=temp%1000/100+'0'; //温度十位
- TEMP1[1]=temp%100/10+'0'; //温度个位
- TEMP1[2]=0x2e; //小数点
- TEMP1[3]=temp%10+'0'; //温度小数点后第一位
- Print(TEMP1); //输出温度
- GotoXY(8,0); //设置湿度显示位置
- Print(" %RH");
- HUMI1[0]=humi%1000/100+'0'; //湿度十位
- HUMI1[1]=humi%100/10+'0'; //湿度个位
- HUMI1[2]=0x2E; //小数点
- HUMI1[3]=humi%10+'0'; //湿度小数点后第一位
- Print(HUMI1); //输出湿度
- delay(20); //等待足够长的时间,以进行下一次转换
- void printVolage() //测量电压模块
- uchar voltage[7];
- ST=0;
- OE=0;
- ST=1;
- ST=0;
- while(EOC==0);
- OE=1;
- getdata=P1;
- // send(getdata);
- OE=0;
- temp=getdata*1.0/255*500;
- temp=(float)temp;
- GotoXY(0,1); //选择温度显示位置
- voltage[0]=temp/100+'0'; //温度十位
- voltage[1]=0x2e; //小数点
- voltage[2]=temp/10%10+'0'; //温度个位
- voltage[3]=temp%10+'0'; //温度小数点后第一位
- Print(voltage);
- //主函数
- void main()
- uchar counter=0;
- KEY=1; //按键输入端口电平置高
- P1=0XFF;
- init();
- // LED=0;
- //P2=0XFF;
- adda(0,0,1);
- LCD_Initial(); //初始化液晶
- s_connectionreset(); //系统复位
- while(1)
- if(!KEY) //如果检测到低电平,说明按键按下
- delay(10); //延时去抖,一般10-20ms
- if(!KEY) //再次确认按键是否按下,没有按下则退出
- while(!KEY);//如果确认按下按键等待按键释放,没有释放则一直等待
- counter=!counter;//释放则执行需要的程序
- //主循环中添加其他需要一直工作的程序
- if(counter)
- DH(); //测量温湿度模块
- else
- printVolage(); //测量电压模块
复制代码 |
