查看: 2605|回复: 0
51单片机数控直流电源代码
ID:324477 发表于 2018-5-13 11:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
uint aa,b,bb;
sbit p1=P2^7;
sbit p2=P2^6;
sbit p3=P2^5;
sbit p4=P2^4;
sbit dp=P0^7;
sbit an1=P1^4;
sbit an2=P1^5;
sbit an3=P1^6;
sbit CLK=P1^2;/*??DAC????*/
sbit CS=P1^1;
sbit DIN=P1^3;
uchar code SegCode[12] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xc1};
int moshi=0;
void DelayMs(uchar n)
        uchar j;
        while (n--)
                for (j = 0; j < 113; j++);
void keyscan1()        /*??*/
    if(an1==0)
     {  aa=0;
                bb=0;
    while(an1==0);
void keyscan2()        /*??1???1*/
    if(an2==0)
                         if(aa<100)
                                 aa=aa+1;
                     bb++;
    while(an2==0);
void keyscan3() /*??2???1*/
   if(an3==0)
           if(aa>0)
                         aa=aa-1;
             bb--;
  while(an3==0);
void display(void)
{  p1=0;p2=0;p3=0;p4=0;
          if(bb/100%10==0)
    P0=SegCode[10];
        P0=SegCode[bb/100%10];
        p1=1;p2=0;p3=0;p4=0;
        DelayMs(3);
        P0=SegCode[bb/10%10];
        dp=0;
        p1=0;p2=1;p3=0;p4=0;
        DelayMs(3);
        P0=SegCode[bb%10];
        p1=0;p2=0;p3=1;p4=0;
        DelayMs(3);
        P0=SegCode[11];
        p1=0;p2=0;p3=0;p4=1;
        DelayMs(3);
void DA_Conver(unsigned int DAValue)
      unsigned char i;
      DAValue <<= 6;
      CS =   0;
      CLK = 0;
      for(i = 0; i < 12; i++)
          DIN = (bit)(DAValue & 0x8000);
          CLK = 1;
          DAValue <<= 1;
         CLK = 0;
      CS = 1;
      CLK = 0;
float zh (float k)
  float DA;
  DA=k*1024/500;        /*2.5v????!*/
  return DA;  }
void init_timer()
    TMOD=0x01;
        TH0=(65536-3500)/256;
        TL0=(65536-3500)%256;
        EA=1;
        ET0=1;
        TR0=1;
{long DAValue=0;
  aa=0;
           init_timer();
    DAValue=zh(aa);  /*????*/
          DA_Conver(DAValue);
             keyscan1();
          keyscan2();
          keyscan3();
void time0() interrupt 1
         {          TH0=(65536-3500)/256;
        b++         ;
        if(b==2)
        {b=0;
          display(); }
