查看: 2585|回复: 1
51单片机独立按键的使用
ID:331343 发表于 2018-5-16 15:49 | 显示全部楼层 |阅读模式
51单片机独立按键的使用,主函数的c文件如下,完整工程文件在附件
#include<reg52.h>
sbit we = P2^7;                //数码管位选
sbit du = P2^6;                //数码管段选
sbit key_s2 = P3^0;        //S2按键未定义
uchar code leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x00  //自定义
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
          uchar num = 0;
          we = 1;           //数码管位选
          P0 = 127;  //选通第一个数码管,该数码管接低电平,其余为高电平
          we = 0;
                          du = 1;
                        P0 = leddata[num];
                        du =0;
                        if(key_s2 == 0)
                                delay(5); //软件延时
                                if(key_s2 == 0)
                                        num++;
                                while(!key_s2);//松手检测
                        if(num == 10)
                                num=0;
1独立按键.zip
13.43 KB, 下载次数: 4, 下载积分: 黑币 -5
ID:332416 发表于 2018-5-18 15:16 | 显示全部楼层
独立按键控制数码管时钟
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit K1=P3^4;
sbit K2=P3^5;
sbit K3=P3^6;
sbit K4=P3^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint aa;
uchar num1,num2,shi1,ge1,shi2,ge2;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void display(uchar num1,uchar num2)
        shi1=num1/10;
        ge1=num1%10;
        shi2=num2/10;
        ge2=num2%10;
        dula=1;
        P0=table[shi1];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(1);
        dula=1;
        P0=table[ge1];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay(1);
        dula=1;
        P0=table[shi2];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay(1);
        dula=1;
        P0=table[ge2];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xf7;
        wela=0;
        delay(1);
void key()
        if(K1==0)
                delay(5);
                if(K1==0)
                        TR0=0;
                        while(!K1);
        if(K2==0)
                delay(5);
                if(K2==0)
                        if(num1==0)
                                num1=60;
                        num1--;
                        while(!K2);
        if(K3==0)
                delay(5);
                if(K3==0)
                        num1++;
                        if(num1>=60)
                                num1=num1-60;
                        while(!K3);
        if(K4==0)
                delay(5);
                if(K4==0)
                        TR0=1;
                        while(!K4);
void inint()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        inint();
                key();
                display(num1,num2);
void zhongduan()interrupt 1
        aa++;
        if(aa==20)
                aa=0;
                num2++;
                if(num2==60)
                        num2=0;
                        num1++;
                        if(num1==60)
                                num1=0;
