#include "led.h"
#include "stm32f10x.h"
#include "delay.h"
#include "sys.h"
/** I2C ???? */
#define I2C_PORT GPIOB
#define SDA_Pin GPIO_Pin_7
#define SCL_Pin GPIO_Pin_6
#define FAILURE 0
#define SUCCESS 1
u32 TimingDelay = 0;
void Delay_Ms(u32 nTime)
TimingDelay = nTime;
while(TimingDelay != 0);
//I2C³õʼ»¯
void i2c_init()
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = SDA_Pin | SCL_Pin;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; // //I2C±ØÐ뿪©Êä³ö
GPIO_Init(I2C_PORT, &GPIO_InitStructure);
//ÅäÖÃSDAΪÊäÈëģʽ
void SDA_Input_Mode()
GPIO_InitStructure.GPIO_Pin = SDA_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ;//GPIO_Mode_IPU
//ÅäÖÃSDAΪÊä³öģʽ
void SDA_Output_Mode()
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;//GPIO_Mode_AF_OD
void SDA_Output( uint16_t val )
if ( val ) {
GPIO_SetBits(I2C_PORT,SDA_Pin);
} else {
GPIO_ResetBits(I2C_PORT,SDA_Pin);
void SCL_Output( uint16_t val )
if ( val ) {
GPIO_SetBits(I2C_PORT,SCL_Pin);
} else {
GPIO_ResetBits(I2C_PORT,SCL_Pin);
uint8_t SDA_Input()
return GPIO_ReadInputDataBit( I2C_PORT, SDA_Pin);
void delay1(unsigned int n)
unsigned int i;
for ( i=0;i<n;++i);
//I2C×ÜÏßÆô¶¯
void I2CStart(void)
SDA_Output(1);delay1(500);
SCL_Output(1);delay1(500);
SDA_Output(0);delay1(500);
SCL_Output(0);delay1(500);
//I2C×ÜÏßÍ£Ö¹
void I2CStop(void)
SCL_Output(0); delay1(500);
SDA_Output(0); delay1(500);
SCL_Output(1); delay1(500);
SDA_Output(1); delay1(500);
//µÈ´ýÓ¦´ð
unsigned char I2CWaitAck(void)
unsigned short cErrTime = 5;
SDA_Input_Mode();
delay1(500);
while(SDA_Input())
cErrTime--;
delay1(500);
if (0 == cErrTime)
SDA_Output_Mode();
I2CStop();
return FAILURE;
SDA_Output_Mode();
return SUCCESS;
//·¢ËÍÓ¦´ðλ
void I2CSendAck(void)
delay1(500);
void I2CSendNotAck(void)
SDA_Output(1);
delay1(500);
//ͨ¹ýI2C×ÜÏß·¢ËÍÒ»¸ö×Ö½ÚÊý¾Ý
void I2CSendByte(unsigned char cSendByte)
unsigned char i = 8;
while (i--)
SDA_Output(cSendByte & 0x80); delay1(500);
cSendByte += cSendByte;
delay1(500);
//ͨ¹ýI2C×ÜÏß½ÓÊÕÒ»¸ö×Ö½ÚÊý¾Ý
unsigned char I2CReceiveByte(void)
unsigned char cR_Byte = 0;
SDA_Input_Mode();
while (i--)
cR_Byte += cR_Byte;
delay1(500);
cR_Byte |= SDA_Input();
SDA_Output_Mode();
return cR_Byte;
void WriteCmd(u8 data)//EEPROM_Wirte(0x0B);
{ /***дÈë***/
I2CStart(); //¿ªÊ¼
I2CSendByte(0x76); //oled µØÖ·
I2CSendAck();
I2CSendByte(0x00); //·¢ËÍ
I2CSendAck();
I2CSendByte(data); //дÈë
I2CSendAck();
I2CStop(); //Í£Ö¹
Delay_Ms(10);//µÈ´ý
//Random Read
u8 WriteDat(u8 add) //EEPROM_Read(i);
u8 a;
I2CStart(); //¿ªÊ¼
I2CSendByte(0x78); //´Ó´ËµØÖ·¿ªÊ¼¶ÁÊý¾Ý
I2CSendAck();
I2CSendByte(0x40);
I2CSendAck();
I2CSendByte(add); //дÈëACK
I2CSendAck();
I2CStop(); //Í£Ö¹
// I2CStart();
// I2CSendByte(0xA1); //ÏÂÒ»¸öµØÖ·
// I2CSendAck();
// a=I2CReceiveByte(); //½ÓÊÕÊý¾Ý£¬±£´æÓÚa
// I2CSendNotAck();
// I2CStop(); //Í£Ö¹
// return a;
void OLED_Init(void)
delay_ms(100); //????????
WriteCmd(0xAE); //display off
WriteCmd(0x20); //Set Memory Addressing Mode
WriteCmd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
WriteCmd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
WriteCmd(0xc8); //Set COM Output Scan Direction
WriteCmd(0x00); //---set low column address
WriteCmd(0x10); //---set high column address
WriteCmd(0x40); //--set start line address
WriteCmd(0x81); //--set contrast control register
WriteCmd(0xff); //???? 0x00~0xff
WriteCmd(0xa1); //--set segment re-map 0 to 127
WriteCmd(0xa6); //--set normal display
WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
WriteCmd(0x3F); //
WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
WriteCmd(0xd3); //-set display offset
WriteCmd(0x00); //-not offset
WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
WriteCmd(0xf0); //--set divide ratio
WriteCmd(0xd9); //--set pre-charge period
WriteCmd(0x22); //
WriteCmd(0xda); //--set com pins hardware configuration
WriteCmd(0x12);
WriteCmd(0xdb); //--set vcomh
WriteCmd(0x20); //0x20,0.77xVcc
WriteCmd(0x8d); //--set DC-DC enable
WriteCmd(0x14); //
WriteCmd(0xaf); //--turn on oled panel
void OLED_ON(void)
WriteCmd(0X8D); //?????
WriteCmd(0X14); //?????
WriteCmd(0XAF); //OLED??
void OLED_SetPos(unsigned char x, unsigned char y) //???????
WriteCmd(0xb0+y);
WriteCmd(((x&0xf0)>>4)|0x10);
WriteCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char fill_Data)//????
unsigned char m,n;
for(m=0;m<8;m++)
WriteCmd(0xb0+m); //page0-page1
WriteCmd(0x00); //low column start address
WriteCmd(0x10); //high column start address
for(n=0;n<128;n++)
WriteDat(fill_Data);
int main(void)
delay_init();
LED_Init();
i2c_init();
OLED_Init();
OLED_Fill(0Xff);
