c语言秒表单片机源程序如下:
- // File name :**.c
- // Descriptions :
- //Revision History
- //01 ****-**-** 10:07 Park
- // Create the file.
- #include<reg51.h>
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit beep=P3^7;
- unsigned char j,k,a1,a0,s=60;
- unsigned int m;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- void delay(unsigned char i)
- for(j=i;j>0;j--)
- for(k=125;k>0;k--);
- void display(unsigned char sh_c,unsigned char g_c)
- dula=0;
- P0=table[sh_c];
- dula=1;
- dula=0;
- wela=0;
- P0=0xfe;
- wela=1;
- wela=0;
- delay(5);
- P0=table[g_c];
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- delay(5);
- void main()
- TMOD=0x01;
- TR0=1;
- TH0=(65536-46080)/256;// 由于晶振为11.0592,故所记次数应为46080,计时器每隔50000微秒发起一次中断。
- TL0=(65536-46080)%256;//46080的来历,为50000*11.0592/12
- ET0=1;
- EA=1;
- while(1)
- if(m==20)
- { m=0;
- s--;
- a0=s%10;
- a1=s/10;
- display(a1,a0);
- if(s==0)
- TR0=0;//时间到,定时器关闭
- beep=0;//蜂鸣器响,报时。
- void time0() interrupt 1
- {TH0=(65536-46080)/256;
- m++;
10 C语言秒表.zip
(203.46 KB, 下载次数: 33)
