查看: 1670|回复: 0
基于STC90C516RD+单片机的矩阵密码锁
ID:334624 发表于 2018-5-21 09:12 | 显示全部楼层 |阅读模式
#include<reg52.h
#define DataPort P
#define KeyPort P1
sbit LATCH1=P2^2
sbit LATCH2=P2^3
unsigned char code dofly_DuanMa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
                                                   0x77,0x7c,0x39,0x5e,0x79,0x71}
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}
unsigned char TempData[10]
unsigned char code password[8]={1,2,3,4,5,6,7,8};
void DelayUs2x(unsigned char t)
void DelayMs(unsigned char t)
void Display(unsigned char FirstBit,unsigned char Num)
unsigned char KeyScan(void)
unsigned char KeyPro(void);
void Init_Timer0(void)
void main (void)
unsigned char num,i,j;
unsigned char temp[8];
bit Flag;
Init_Timer0();
while (1)
num=KeyPro();
if(num!=0xff)
   if(i==0)
         for(j=0;j<8;j++
         TempData[j]=0;
   if(i<8)
      temp[i]=dofly_DuanMa[num]
          for(j=0;j<=i;j++)
         TempData[7-i+j]=temp[j];
        i++;
        if(i==9
          i=0;
          Flag=1
          for(j=0;j<8;j++
             Flag=Flag&&(temp[j]==dofly_DuanMa[password[j]]);
          for(j=0;j<8;j++
         TempData[j]=0;
      if(Flag
             TempData[0]=0x3f
         TempData[1]=0x73
                 TempData[2]=0x79
                 TempData[3]=0x54
                 TempData[0]=0x79
         TempData[1]=0x50
                 TempData[2]=0x50
}void DelayUs2x(unsigned char t)
while(--t);
}void DelayMs(unsigned char t)
while(t--)
     DelayUs2x(245);
         DelayUs2x(245);
      static unsigned char i=0;
           DataPort=0
       LATCH1=1;
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit]
       LATCH2=1;
       LATCH2=0;
       DataPort=TempData[i]
       LATCH1=1;
       LATCH1=0;
           i++;
       if(i==Num)
              i=0;
TMOD |= 0x01;
//TH0=0x00;
//TL0=0x00;
EA=1;
ET0=1;
TR0=1;
}void Timer0_isr(void) interrupt 1
TH0=(65536-2000)/256;
TL0=(65536-2000)%256;
Display(0,8);
unsigned char cord_h,cord_l
KeyPort=0x0f;
cord_h=KeyPort&0x0f;
if(cord_h!=0x0f)
  DelayMs(10);
  if((KeyPort&0x0f)!=0x0f)
    KeyPort=cord_h|0xf0
    cord_l=KeyPort&0xf0
    while((KeyPort&0xf0)!=0xf0)
    return(cord_h+cord_l)
  }return(0xff);
switch(KeyScan())
  case 0x7e:return 0;break
  case 0x7d:return 1;break;
  case 0x7b:return 2;break;
  case 0x77:return 3;break;
  case 0xbe:return 4;break;
  case 0xbd:return 5;break;
  case 0xbb:return 6;break;
  case 0xb7:return 7;break;
  case 0xde:return 8;break;
  case 0xdd:return 9;break;
  case 0xdb:return 10;break;
  case 0xd7:return 11;break;
  case 0xee:return 12;break;
  case 0xed:return 13;break;
  case 0xeb:return 14;break;
  case 0xe7:return 15;break;
  default:return 0xff;break;
