function varargout = untitled(varargin) % UNTITLED M-file for untitled.fig % UNTITLED, by itself, creates a new UNTITLED or raises the existing % singleton*. % % H = UNTITLED returns the handle to a new UNTITLED or the handle to % the existing singleton*. % % UNTITLED('CALLBACK',hObject,eventData,handles,...) calls the local % function named CALLBACK in UNTITLED.M with the given input arguments. % % UNTITLED('Property','Value',...) creates a new UNTITLED or raises the % existing singleton*. Starting from the left, property value pairsare % applied to the GUI before untitled_OpeningFcn gets called. An % unrecognized property name or invalid value makes property application % stop. All inputs are passed tountitled_OpeningFcn via varargin. % % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one % instance to run (singleton)". % % See also: GUIDE, GUIDATA, GUIHANDLES % Edit the above text to modify theresponse to help untitled % Last Modified by GUIDE v2.5 07-Sep-201313:47:05 % Begin initialization code - DO NOT EDIT gui_Singleton = 1; gui_State = struct('gui_Name', mfilename, ... 'gui_Singleton', gui_Singleton, ... 'gui_OpeningFcn',@untitled_OpeningFcn, ... 'gui_OutputFcn', @untitled_OutputFcn, ... 'gui_LayoutFcn', [] , ... 'gui_Callback', []); if nargin && ischar(varargin{1}) gui_State.gui_Callback = str2func(varargin{1}); end if nargout [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:}); else gui_mainfcn(gui_State, varargin{:}); end % End initialization code - DO NOT EDIT % --- Executes just before untitled is madevisible. function untitled_OpeningFcn(hObject,eventdata, handles, varargin) % This function has no output args, seeOutputFcn. % hObject handle to figure % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % varargin command line arguments to untitled (see VARARGIN) % 初始化 set(handles.caiji,'UserData',0); setappdata(handles.save,'ApplicationData',0); % Choose default command line output foruntitled handles.output = hObject; % Update handles structure guidata(hObject, handles); % UIWAIT makes untitled wait for userresponse (see UIRESUME) % uiwait(handles.figure1); % --- Outputs from this function arereturned to the command line. function varargout = untitled_OutputFcn(hObject,eventdata, handles) % varargout cell array for returning output args (see VARARGOUT); % hObject handle to figure % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Get default command line output fromhandles structure varargout{1} = handles.output; % --- Executes on button press in on. function on_Callback(hObject, eventdata,handles) % hObject handle to on (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) clc; s1 =instrfind('Type','serial','Port','COM1','Tag',''); % 查看端口是否存在 s2 =instrfind('Type','serial','Port','COM2','Tag',''); s3 =instrfind('Type','serial','Port','COM3','Tag',''); % 查看端口是否存在 s4 =instrfind('Type','serial','Port','COM4','Tag',''); % 获取参数值 if (isempty(s1) &&get(handles.port,'Value')==1 ) % 如果端口1存在,存创建端口 s= serial('COM1'); % 创建串口号 if(get(handles.botelv,'Value')==1) % 设置串口参数 s.BaudRate = 1200; elseif(get(handles.botelv,'Value')==2) s.BaudRate = 2400; elseif(get(handles.botelv,'Value')==3) s.BaudRate = 4800; elseif(get(handles.botelv,'Value')==4) s.BaudRate = 9600; elseif(get(handles.botelv,'Value')==5) s.BaudRate = 19200; elseif(get(handles.botelv,'Value')==6) s.BaudRate = 38400; elseif(get(handles.botelv,'Value')==7) s.BaudRate = 76800; elseif(get(handles.botelv,'Value')==8) s.BaudRate = 115200; end if(get(handles.jiaoyanw,'Value')==1) s.Parity = 'none'; % 无校验位 elseif(get(handles.jiaoyanw,'Value')==2) s.Parity = 'odd'; % 偶校验 elseif(get(handles.jiaoyanw,'Value')==3) s.Parity = 'even'; % 奇校验 end if(get(handles.dataw,'Value')==1) % 数据位 s.DataBits = 8; elseif(get(handles.dataw,'Value')==2) s.DataBits = 7; elseif(get(handles.dataw,'Value')==3) s.DataBits = 6; elseif(get(handles.dataw,'Value')==4) s.DataBits = 5; end if(get(handles.stopw,'Value')==1) % 停止位 s.StopBits = 1; elseif(get(handles.stopw,'Value')==2) s.StopBits = 1.5; elseif(get(handles.stopw,'Value')==3) s.StopBits = 2; end s.Timeout = 0.1; s.InputBufferSize = 3072; s.OutputBufferSize = 3072; s.ReadAsyncMode = 'continuous'; handles.sbuff = s; guidata(hObject, handles); s.BytesAvailableFcnMode = 'byte'; s.BytesAvailableFcnCount = 10; s.BytesAvailableFcn = {@recive_data, handles}; fopen(s); set(handles.caiji,'Enable','On'); set(handles.off,'Enable','On'); set(handles.on,'Enable','Off'); set(handles.edit1,'String','打开成功!'); set(handles.exit,'Enable','Off'); set(handles.edit1,'backgroundcolor',[0 1 0]); elseif (isempty(s2) &&get(handles.port,'Value')==2 ) % 如果端口2存在,存创建端口 s= serial('COM2'); % 创建串口号 if(get(handles.botelv,'Value')==1) % 设置串口参数 s.BaudRate = 1200; elseif(get(handles.botelv,'Value')==2) s.BaudRate = 2400; elseif(get(handles.botelv,'Value')==3) s.BaudRate = 4800; elseif(get(handles.botelv,'Value')==4) s.BaudRate = 9600; elseif(get(handles.botelv,'Value')==5) s.BaudRate = 19200; elseif(get(handles.botelv,'Value')==6) s.BaudRate = 38400; elseif(get(handles.botelv,'Value')==7) s.BaudRate = 76800; elseif(get(handles.botelv,'Value')==8) s.BaudRate = 115200; end if(get(handles.jiaoyanw,'Value')==1) s.Parity = 'none'; % 无校验位 elseif(get(handles.jiaoyanw,'Value')==2) s.Parity = 'odd'; % 偶校验 elseif(get(handles.jiaoyanw,'Value')==3) s.Parity = 'even'; % 奇校验 end if(get(handles.dataw,'Value')==1) % 数据位 s.DataBits = 8; elseif(get(handles.dataw,'Value')==2) s.DataBits = 7; elseif(get(handles.dataw,'Value')==3) s.DataBits = 6; elseif(get(handles.dataw,'Value')==4) s.DataBits = 5; end if(get(handles.stopw,'Value')==1) % 停止位 s.StopBits = 1; elseif(get(handles.stopw,'Value')==2) s.StopBits = 1.5; elseif(get(handles.stopw,'Value')==3) s.StopBits = 2; end s.Timeout = 0.1; s.InputBufferSize = 3072; s.OutputBufferSize = 3072; s.ReadAsyncMode = 'continuous'; handles.sbuff = s; guidata(hObject, handles); s.BytesAvailableFcnMode = 'byte'; s.BytesAvailableFcnCount = 10; s.BytesAvailableFcn = {@recive_data, handles}; fopen(s); set(handles.caiji,'Enable','On'); set(handles.off,'Enable','On'); set(handles.on,'Enable','Off'); set(handles.exit,'Enable','Off'); set(handles.edit1,'String','打开成功!'); set(handles.edit1,'backgroundcolor',[0 1 0]); elseif (isempty(s3) &&get(handles.port,'Value')==3 ) % 如果端口3存在,存创建端口 s= serial('COM3'); % 创建串口号 if(get(handles.botelv,'Value')==1) % 设置串口参数 s.BaudRate = 1200; elseif(get(handles.botelv,'Value')==2) s.BaudRate = 2400; elseif(get(handles.botelv,'Value')==3) s.BaudRate = 4800; elseif(get(handles.botelv,'Value')==4) s.BaudRate = 9600; elseif(get(handles.botelv,'Value')==5) s.BaudRate = 19200; elseif(get(handles.botelv,'Value')==6) s.BaudRate = 38400; elseif(get(handles.botelv,'Value')==7) s.BaudRate = 76800; elseif(get(handles.botelv,'Value')==8) s.BaudRate = 115200; end if(get(handles.jiaoyanw,'Value')==1) s.Parity = 'none'; % 无校验位 elseif(get(handles.jiaoyanw,'Value')==2) s.Parity = 'odd'; % 偶校验 elseif(get(handles.jiaoyanw,'Value')==3) s.Parity = 'even'; % 奇校验 end if(get(handles.dataw,'Value')==1) % 数据位 s.DataBits = 8; elseif(get(handles.dataw,'Value')==2) s.DataBits = 7; elseif(get(handles.dataw,'Value')==3) s.DataBits = 6; elseif(get(handles.dataw,'Value')==4) s.DataBits = 5; end if(get(handles.stopw,'Value')==1) % 停止位 s.StopBits = 1; elseif(get(handles.stopw,'Value')==2) s.StopBits = 1.5; elseif(get(handles.stopw,'Value')==3) s.StopBits = 2; end s.Timeout = 0.1; s.InputBufferSize = 3072; s.OutputBufferSize = 3072; s.ReadAsyncMode = 'continuous'; handles.sbuff = s; guidata(hObject, handles); s.BytesAvailableFcnMode = 'byte'; s.BytesAvailableFcnCount = 10; s.BytesAvailableFcn = {@recive_data, handles}; fopen(s); set(handles.caiji,'Enable','On'); set(handles.off,'Enable','On'); set(handles.on,'Enable','Off'); set(handles.exit,'Enable','Off'); set(handles.edit1,'String','打开成功!'); set(handles.edit1,'backgroundcolor',[0 1 0]); elseif (isempty(s4) &&get(handles.port,'Value')==4 ) % 如果端口4存在,存创建端口 s= serial('COM4'); % 创建串口号 if(get(handles.botelv,'Value')==1) % 设置串口参数 s.BaudRate = 1200; elseif(get(handles.botelv,'Value')==2) s.BaudRate = 2400; elseif(get(handles.botelv,'Value')==3) s.BaudRate = 4800; elseif(get(handles.botelv,'Value')==4) s.BaudRate = 9600; elseif(get(handles.botelv,'Value')==5) s.BaudRate = 19200; elseif(get(handles.botelv,'Value')==6) s.BaudRate = 38400; elseif(get(handles.botelv,'Value')==7) s.BaudRate = 76800; elseif(get(handles.botelv,'Value')==8) s.BaudRate = 115200; end if(get(handles.jiaoyanw,'Value')==1) s.Parity = 'none'; % 无校验位 elseif(get(handles.jiaoyanw,'Value')==2) s.Parity = 'odd'; % 偶校验 elseif(get(handles.jiaoyanw,'Value')==3) s.Parity = 'even'; % 奇校验 end if(get(handles.dataw,'Value')==1) % 数据位 s.DataBits = 8; elseif(get(handles.dataw,'Value')==2) s.DataBits = 7; elseif(get(handles.dataw,'Value')==3) s.DataBits = 6; elseif(get(handles.dataw,'Value')==4) s.DataBits = 5; end if(get(handles.stopw,'Value')==1) % 停止位 s.StopBits = 1; elseif(get(handles.stopw,'Value')==2) s.StopBits = 1.5; elseif(get(handles.stopw,'Value')==3) s.StopBits = 2; end s.Timeout = 0.1; s.InputBufferSize = 3072; s.OutputBufferSize = 3072; s.ReadAsyncMode = 'continuous'; handles.sbuff = s; guidata(hObject, handles); s.BytesAvailableFcnMode = 'byte'; s.BytesAvailableFcnCount = 10; s.BytesAvailableFcn = {@recive_data, handles}; fopen(s); set(handles.caiji,'Enable','On'); set(handles.off,'Enable','On'); set(handles.on,'Enable','Off'); set(handles.exit,'Enable','Off'); set(handles.edit1,'String','打开成功!'); set(handles.edit1,'backgroundcolor',[0 1 0]); else msgbox('串口不存在或被占用!'); set(handles.edit1,'String','打开失败!'); set(handles.edit1,'backgroundcolor',[1 0/255 0]); end % 中断处理程序 function recive_data(t, event, handles) if(getappdata(handles.caiji,'ApplicationData')~=0) % 收到单击采集信号的信息 g= handles.sbuff; [out,huanchongcout] = fread(g,10); % 读取数据 % plot(handles.axes1,out); %解析数据 if(out(1)==128 &&bitxor(bitxor(bitxor(bitxor(out(2),out(3)),out(4)),out(5)),out(6)) == out(7)) data2 = dec2bin(out(2),8); data3 = dec2bin(out(3),8); data4 = dec2bin(out(4),8); data5 = dec2bin(out(5),8); data6 = dec2bin(out(6),8); cur_data0 = 0; % 初始化脉冲值 cur_data1 = dec2bin(cur_data0,32); % 转成二进制,有效位数为32 cur_data1(1:4) = data6(5:8); cur_data1(5:11) = data5(2:8); cur_data1(12:18) = data4(2:8); cur_data1(19:25) = data3(2:8); cur_data1(26:32) = data2(2:8); cur_data2 = cur_data1; set(handles.current_data,'String',bin2dec(cur_data2)); end if(getappdata(handles.save,'ApplicationData') ~=0) % 开始存储数据 File = get(handles.save_play,'String'); fid = fopen(File,'a'); fprintf(fid,'%d\t',bin2dec(cur_data2)); fprintf(fid,'\n'); fclose(fid); end end % --- Executes on button press in off. function off_Callback(hObject, eventdata,handles) % hObject handle to off (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) s= handles.sbuff; % 传递 fclose(s); % 关闭串口设备对象 delete(s); % 删除内存中的串口设备对象 clear s; % 清除工作区间的串口设备对象 setappdata(handles.axes1,'ApplicationData',0); % 清空缓存数据 set(handles.axes1,'UserData',0); % 将计数器清0 set(handles.save,'UserData',0); % 将数据保存区清0 set(handles.edit1,'String','串口关闭'); set(handles.edit1,'backgroundcolor',[0 0/255 1]); set(handles.caiji,'Enable','Off'); set(handles.on,'Enable','On'); set(handles.save,'Enable','Off'); set(handles.off,'Enable','Off'); set(handles.exit,'Enable','On'); % --- Executes on selection change in port. function port_Callback(hObject, eventdata,handles) % hObject handle to port (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: contents = cellstr(get(hObject,'String'))returns port contents as cell array % contents{get(hObject,'Value')} returns selected item from port % --- Executes during object creation,after setting all properties. function port_CreateFcn(hObject, eventdata,handles) % hObject handle to port (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: popupmenu controls usually have awhite background on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on selection change inbotelv. function botelv_Callback(hObject,eventdata, handles) % hObject handle to botelv (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: contents =cellstr(get(hObject,'String')) returns botelv contents as cell array % contents{get(hObject,'Value')} returns selected item from botelv % --- Executes during object creation,after setting all properties. function botelv_CreateFcn(hObject,eventdata, handles) % hObject handle to botelv (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: popupmenu controls usually have awhite background on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on selection change indataw. function dataw_Callback(hObject, eventdata,handles) % hObject handle to dataw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: contents =cellstr(get(hObject,'String')) returns dataw contents as cell array % contents{get(hObject,'Value')} returns selected item from dataw % --- Executes during object creation,after setting all properties. function dataw_CreateFcn(hObject,eventdata, handles) % hObject handle to dataw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: popupmenu controls usually have awhite background on Windows. % See ISPC and COMPUTER. if ispc && isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on selection change injiaoyanw. function jiaoyanw_Callback(hObject,eventdata, handles) % hObject handle to jiaoyanw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: contents =cellstr(get(hObject,'String')) returns jiaoyanw contents as cell array % contents{get(hObject,'Value')} returns selected item from jiaoyanw % --- Executes during object creation,after setting all properties. function jiaoyanw_CreateFcn(hObject,eventdata, handles) % hObject handle to jiaoyanw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: popupmenu controls usually have awhite background on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on selection change instopw. function stopw_Callback(hObject, eventdata,handles) % hObject handle to stopw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: contents =cellstr(get(hObject,'String')) returns stopw contents as cell array % contents{get(hObject,'Value')} returns selected item from stopw % --- Executes during object creation,after setting all properties. function stopw_CreateFcn(hObject,eventdata, handles) % hObject handle to stopw (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: popupmenu controls usually have awhite background on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes during object creation,after setting all properties. function axes1_CreateFcn(hObject,eventdata, handles) % hObject handle to axes1 (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: place code in OpeningFcn topopulate axes1 if ispc &&isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on button press in caiji. function caiji_Callback(hObject, eventdata,handles) % hObject handle to caiji (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % data = handles.data; % 发送信号,传递给中断,将信号暂存在采集控件中 % t =str2num(get(handles.save_time,'String')); index =get(handles.save_lujin,'UserData'); % 是否设定存储路径 g = handles.sbuff; [a,b] = fread(g); if ( b==0 ) msgbox('当前无数据输入!'); set(handles.save,'Enable','Off'); else if(get(handles.caiji,'UserData')==0) set(handles.caiji,'String','停止采集'); set(handles.caiji,'BackgroundColor',[1 0 0]); setappdata(handles.caiji,'ApplicationData',1); % 用于传递给中断响应函数,可以接收并显示数据了 set(handles.caiji,'UserData',1); if( index~=0 ) % 设定存储条件 set(handles.save,'Enable','On'); else set(handles.save,'Enable','Off'); end else set(handles.caiji,'String','开始采集'); setappdata(handles.caiji,'ApplicationData',0); set(handles.caiji,'BackgroundColor',[0.8 0.8 0.8]); set(handles.caiji,'UserData',0); set(handles.save,'Enable','Off'); set(handles.save_time,'String',0); end end % --- Executes on button press in save. function save_Callback(hObject, eventdata,handles) % hObject handle to save (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % 发送开始存储信号,并带有时间控制功能 setappdata(handles.save,'ApplicationData',1); % g = handles.sbuff; % [data,b] = fread(g) t =str2num(get(handles.save_time,'String')); acc_time = t; % 中间变量 set(handles.time_play,'String',num2str(t)); fori = 1:t % 时间显示 pause(0.995); set(handles.time_play,'String',num2str(acc_time-1)); acc_time = acc_time-1; end setappdata(handles.save,'ApplicationData',0); % File = get(handles.save_play,'String'); % 获取存储路径 % fopen(File); % g= handles.sbuff; % [data,b] = fread(g) % fprintf(File,'%12.8e\t',data); % save ( File ,'uint8','data'); % --- Executes on button press in exit. function exit_Callback(hObject, eventdata,handles) % hObject handle to exit (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) close(gcbf); function save_play_Callback(hObject,eventdata, handles) % hObject handle to save_play (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: get(hObject,'String') returnscontents of save_play as text % str2double(get(hObject,'String')) returns contents of save_play as adouble % --- Executes during object creation,after setting all properties. function save_play_CreateFcn(hObject,eventdata, handles) % hObject handle to save_play (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: edit controls usually have a whitebackground on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes on button press insave_lujin. function save_lujin_Callback(hObject,eventdata, handles) % hObject handle to save_lujin (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) set(handles.save,'Enable','On'); [file, pathname, index] =uiputfile({'*.txt';'*.dat';'*.mat'},'文件另存为'); file1 = strcat(pathname,file); set(handles.save_play,'String',file1); set(handles.save_lujin,'UserData',index); % 判断是否设定了保存文件的路径 function save_time_Callback(hObject, eventdata,handles) % hObject handle to save_time (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: get(hObject,'String') returnscontents of save_time as text % str2double(get(hObject,'String')) returns contents of save_time as adouble % --- Executes during object creation,after setting all properties. function save_time_CreateFcn(hObject,eventdata, handles) % hObject handle to save_time (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: edit controls usually have a whitebackground on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end % --- Executes during object creation,after setting all properties. function time_play_CreateFcn(hObject, eventdata,handles) % hObject handle to time_play (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called function current_data_Callback(hObject,eventdata, handles) % hObject handle to current_data (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles structure with handles and user data (see GUIDATA) % Hints: get(hObject,'String') returnscontents of current_data as text % str2double(get(hObject,'String')) returns contents of current_data as adouble % --- Executes during object creation,after setting all properties. function current_data_CreateFcn(hObject,eventdata, handles) % hObject handle to current_data (see GCBO) % eventdata reserved - to be defined in a future version of MATLAB % handles empty - handles not created until after all CreateFcns called % Hint: edit controls usually have a whitebackground on Windows. % See ISPC and COMPUTER. if ispc &&isequal(get(hObject,'BackgroundColor'),get(0,'defaultUicontrolBackgroundColor')) set(hObject,'BackgroundColor','white'); end
