最近淘到一片显示屏,用的是6963的芯片。在网上找了段驱动代码,但是自己读不懂...代码可以正常通过编译,说明代码是正确的。
而我不懂的是:- 程序中没有明显地定义液晶屏引脚与单片机的连接,而在第12 13行定义了两个xdata,后面的程序直接操作这两个变量,难道这样可以直接映射到IO口吗?
- 要是我实际线路连接不一样,我要怎么重新定义这些变量?
附单片机代码:
- //240*128液晶显示驱动程序
- //控制器件为:AT89S52
- //T6963C接口:直接访问形式
- //程序设计:卢印举
- #include <reg51.h>
- #include <math.h>
- #include <hzk.c>
- //信号管脚定义(全局变量)(注意:因为液晶数据口接P0,直接访问方式)
- unsigned char xdata Lcd_Cmd_Reg _at_ 0xfdff; // C/D-P2.0 CE-P2.1 p2.0=1 p2.1=0
- unsigned char xdata Lcd_Data_Reg _at_ 0xfcff; // C/D-P2.0 CE-P2.1 p2.0=0 p2.1=0
- //以8*8字符计算,显示屏横向、纵向可以显示的点阵坐标;左、上、右、下以及当前的位置坐标
- #define LCD_LEFT 0
- #define LCD_TOP 0
- #define LCD_RIGHT 239
- #define LCD_BOTTOM 127
- unsigned char data Lcd_CurrentX,Lcd_CurrentY,Lcd_Mask;
- unsigned char data LeftMask[]={0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01};
- unsigned char data RightMask[]={0xff,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe};
- //延时子程序
- void Lcddelay(unsigned int t)
- { unsigned int i,j;
- for(i=0;i<t;i++)
- for(j=0;j<10;j++)
- void lcdwc(unsigned char cmdcode)
- { while((Lcd_Cmd_Reg & 0x3) != 0x3) ; //当Lcd_Cmd_Reg低两位不同时为1
- Lcd_Cmd_Reg = cmdcode;
- void lcdwc2(unsigned char cmdcode,unsigned char cmddata)
- Lcd_Data_Reg = cmddata;
- while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
- void lcdwc3(unsigned char cmdcode,unsigned char cmddata,unsigned char cmddata2)
- Lcd_Data_Reg = cmddata2;
- void lcdwd(unsigned char dispdata) //写数据
- Lcd_Data_Reg = dispdata;
- Lcd_Cmd_Reg = 0xc0;
- unsigned char lcdrdata(void) //读数据
- Lcd_Cmd_Reg = 0xc5;
- return Lcd_Data_Reg;
- void lcdpos(void) //内部写数指针定位
- { unsigned int CurrentAddress;
- CurrentAddress = Lcd_CurrentY * 30 ;
- CurrentAddress += Lcd_CurrentX/8;
- lcdwc3(0x24,CurrentAddress & 0xff,CurrentAddress/256);
- unsigned char lcdrd(void) //读数据
- { lcdpos();
- return lcdrdata();
- void lcdcursornextbyte(void) //当前坐标移动到下一个点
- { Lcd_CurrentX+=8;
- if(Lcd_CurrentX > LCD_RIGHT)
- { Lcd_CurrentX = LCD_LEFT;
- Lcd_CurrentY++;
- if(Lcd_CurrentY > LCD_BOTTOM) Lcd_CurrentY = LCD_TOP;
- void displaybyte(unsigned char dispdata)
- { lcdpos();
- if(Lcd_Mask == 0xff) lcdwd(dispdata);
- else
- { unsigned char d=lcdrd();
- d&=(~Lcd_Mask);
- d|=(dispdata & Lcd_Mask);
- lcdwd(d);
- lcdcursornextbyte();
- void Fill_Scr(unsigned char FillData) //LCD整屏显示
- { Lcd_Mask=0xff;
- for(Lcd_CurrentX = LCD_LEFT,Lcd_CurrentY = LCD_TOP;1;)
- { displaybyte(FillData);
- if((Lcd_CurrentX == LCD_LEFT) && (Lcd_CurrentY == LCD_TOP)) break;
- void lcdreset() //初始化LCD屏
- { lcdwc(0x80);
- lcdwc(0x98);
- lcdwc3(0x42,0,0);
- lcdwc3(0x43,30,0);
- void displaychinesechardot(unsigned int Index);
- void displayenglishchardot(unsigned int Index);
- void putsizeimage(unsigned char XSIZE,unsigned char YSIZE,unsigned char code *s);
- void putchar(unsigned int uChar) //信息显示
- { unsigned int i;
- if(uChar<128)
- for(i=0;i != ENGLISHCHARNUMBER;i++)
- { if(uChar ==EnglishCode[i])
- { displayenglishchardot(i);
- break;
- else
- for(i=0;i != CHINESECHARNUMBER;i++)
- { if(uChar ==ChineseCode[i])
- { displaychinesechardot(i);
- break;
- void put_str(unsigned char code *s) //显示汉字或英文字符
- { unsigned int i;
- for (;*s != 0;s++)
- { i=*s;
- if(*s > 127)
- { s++;
- i=i*256+*s;
- if(i == '\n')
- if(Lcd_CurrentY > LCD_BOTTOM-CHINESECHARSIZE+1)
- Lcd_CurrentY=LCD_TOP;
- else
- Lcd_CurrentY+=CHINESECHARSIZE;
- putchar(i);
- void put_str_xy(unsigned char x,unsigned char y,unsigned char code *s)//显示汉字或英文字符
- { Lcd_CurrentX=x;
- Lcd_CurrentY=y;
- put_str(s);
- { unsigned char code *s;
- s=ChineseCharDot+Index*CHINESECHARDOTSIZE;
- if(Lcd_CurrentX > LCD_RIGHT-CHINESECHARSIZE+1)
- if(Lcd_CurrentY > LCD_BOTTOM-CHINESECHARSIZE+1) Lcd_CurrentY=LCD_TOP;
- putsizeimage(CHINESECHARSIZE,CHINESECHARSIZE,s);
- s=EnglishCharDot+Index*ENGLISHCHARDOTSIZE;
- if(Lcd_CurrentX > LCD_RIGHT-ENGLISHCHARSIZE+1)
- putsizeimage(ENGLISHCHARSIZE,CHINESECHARSIZE,s);
- void point(unsigned char bitdata)
- { if(bitdata==0)
- bitdata=0xf0+(0x7-(Lcd_CurrentX & 0x7));
- else
- bitdata=0xf8+(0x7-(Lcd_CurrentX & 0x7));
- Lcd_Cmd_Reg = bitdata;
- //绘制点子程序,最后一位为像素大小
- void pointxy(unsigned char x,unsigned char y,unsigned char bitdata)
- { Lcd_CurrentX=x;
- Lcd_CurrentY=y;
- lcdpos();
- point(bitdata);
- //画线子程序:最后一位为线条的像素宽度
- void linexy(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char bitdata)
- { //线
- unsigned char i,k;
- if(abs(y1-y0)>abs(x1-x0))
- { if(y1>y0)
- for(i=y0;i<=y1;i++)
- { if(x1>x0)
- { k=x1-x0;
- k*=(i-y0);
- k/=y1-y0;
- pointxy(x0+k,i,bitdata);
- else //x1<x0
- { k=x0-x1;
- k*=(i-y0);
- k/=y1-y0;
- pointxy(x0-k,i,bitdata);
- else //y1<y0
- for(i=y0;i>=y1;i--)
- { if(x1>x0)
- { k=x1-x0;
- k*=(y0-i);
- k/=y0-y1;
- else //x1<x0
- { k=x0-x1;
- k*=(y0-i);
- k/=y0-y1;
- else //abs(y1-y0)<abs(x1-x0)
- { if(x1>x0)
- for(i=x0;i<=x1;i++)
- { if(y1==y0)
- pointxy(i,y0,bitdata);
- else if(y1>y0)
- { k=y1-y0;
- k*=(i-x0);
- k/=x1-x0;
- pointxy(i,y0+k,bitdata);
- else //y1<y0
- { k=y0-y1;
- k*=(i-x0);
- k/=x1-x0;
- pointxy(i,y0-k,bitdata);
- else
- for(i=x0;i>=x1;i--)
- { if(y1==y0)
- else if(y1>y0)
- { k=y1-y0;
- k*=(x0-i);
- k/=x0-x1;
- else //y1<y0
- { k=y0-y1;
- k*=(x0-i);
- k/=x0-x1;
- void rect(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char bitdata)
- { //矩形
- linexy(x0,y0,x0,y1,bitdata);
- linexy(x0,y0,x1,y0,bitdata);
- linexy(x0,y1,x1,y1,bitdata);
- linexy(x1,y0,x1,y1,bitdata);
- { unsigned char k,lx,ly,a1,a2,x;
- Lcddelay(1000);
- k=Lcd_CurrentX&0X7;
- XSIZE+=k;
- x=Lcd_CurrentX;
- for(ly=0;ly<YSIZE;ly++,Lcd_CurrentY++)
- for(Lcd_CurrentX=x,lx=k,a1=0;lx<XSIZE;s++)
- { unsigned char p;
- a2=*s;
- for(p=0;p<k;p++)
- { a2>>=1;
- if((a1&0x1)==1) a2+=0x80;
- a1>>=1;
- lcdpos();
- p=XSIZE&0X7;
- if(lx<8)
- { if(XSIZE<8)
- { Lcd_Mask=LeftMask[k] & RightMask[p];
- a1=lcdrd();
- a1&=(~Lcd_Mask);
- a1|=(a2 & Lcd_Mask);
- lcdwd(a1);
- lx=XSIZE;
- Lcd_CurrentX+=XSIZE-k;
- else //XSIZE>=8
- { Lcd_Mask=LeftMask[k];
- a1=lcdrd();
- a1&=(~Lcd_Mask);
- lcdwd(a1);
- lx+=8-k;
- Lcd_CurrentX+=8-k;
- else if(lx>=XSIZE-p) //lx>=8
- { if(k>=p)
- { s--;
- a1=*s;
- a2=0;
- for(p=0;p<k;p++)
- { a2>>=1;
- a1>>=1;
- p=XSIZE&0X7;
- Lcd_Mask=RightMask[p];
- a1=lcdrd();
- a1&=(~Lcd_Mask);
- lcdwd(a1);
- lx+=p;
- Lcd_CurrentX+=p;
- else //lx>=8 and lx<XSIZE-p
- { lcdwd(a2);
- lx+=8;
- Lcd_CurrentX+=8;
- a1=*s;
- Lcd_CurrentY-=YSIZE;
- void main()
- lcdreset();
- Fill_Scr(0x55); //显示竖条
- Lcddelay(6000); //系统延时
- Fill_Scr(0xff); //显示黑屏
- Lcddelay(6000);
- // put_str_xy(0,0,"创新科技检测技术有限公司,联系电话0512-86163888");//显示汉字
- put_str("创新科技检测技术有限公司,联系电话0512-86163888");
- Fill_Scr(0x00);
- rect(12,12,88,88,6);
- Lcddelay(5000);
- //Fill_Scr(0xff);
- //rect(12,12,88,120,0);
- lcdreset();
复制代码 |
