本历程使用STM32F103VET6编写的电子日历,除了常有的日期和星期外,领加了24节气;
- /******************** (C) COPYRIGHT 2011 野火嵌入式开发工作室 ********************
- * 文件名 :main.c
- * 描述 :超强的日历,支持农历,24节气几乎所有日历的功能 日历时间以1970年为元年,
- * 用32bit的时间寄存器可以运行到2100年左右。
- * 实验平台:野火STM32开发板
- * 库版本 :ST3.0.0
- #include "stm32f10x.h"
- #include "stdio.h"
- #include "calendar.h"
- #include "date.h"
- __IO uint32_t TimeDisplay = 0;
- void RCC_Configuration(void);
- void NVIC_Configuration(void);
- void GPIO_Configuration(void);
- void USART_Configuration(void);
- int fputc(int ch, FILE *f);
- void RTC_Configuration(void);
- //u32 Time_Regulate(void);
- void Time_Regulate(struct rtc_time *tm);
- void Time_Adjust(void);
- void Time_Display(uint32_t TimeVar);
- void Time_Show(void);
- u8 USART_Scanf(u32 value);
- #define RTCClockSource_LSE
- u8 const *WEEK_STR[] = {"日", "一", "二", "三", "四", "五", "六"};
- u8 const *zodiac_sign[] = {"猪", "鼠", "牛", "虎", "兔", "龙", "蛇", "马", "羊", "猴", "鸡", "狗"};
- struct rtc_time systmtime;
- int main()
- /* System Clocks Configuration */
- RCC_Configuration();
- /* NVIC configuration */
- NVIC_Configuration();
- GPIO_Configuration();
- USART_Configuration();
- /*在启动时检查备份寄存器BKP_DR1,如果内容不是0xA5A5,则需重新配置时间并询问用户调整时间*/
- if (BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5)
- printf("\r\n\n RTC not yet configured....");
- /* RTC Configuration */
- RTC_Configuration();
- printf("\r\n RTC configured....");
- /* Adjust time by users typed on the hyperterminal */
- Time_Adjust();
- BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
- else
- /*启动无需设置新时钟*/
- /*检查是否掉电重启*/
- if (RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)
- printf("\r\n\n Power On Reset occurred....");
- /*检查是否Reset复位*/
- else if (RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)
- printf("\r\n\n External Reset occurred....");
- printf("\r\n No need to configure RTC....");
- /*等待寄存器同步*/
- RTC_WaitForSynchro();
- /*允许RTC秒中断*/
- RTC_ITConfig(RTC_IT_SEC, ENABLE);
- /*等待上次RTC寄存器写操作完成*/
- RTC_WaitForLastTask();
- #ifdef RTCClockOutput_Enable
- /* Enable PWR and BKP clocks */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
- /* Allow access to BKP Domain */
- PWR_BackupAccessCmd(ENABLE);
- /* Disable the Tamper Pin */
- BKP_TamperPinCmd(DISABLE); /* To output RTCCLK/64 on Tamper pin, the tamper
- functionality must be disabled */
- /* Enable RTC Clock Output on Tamper Pin */
- BKP_RTCOutputConfig(BKP_RTCOutputSource_CalibClock);
- #endif
- /* Clear reset flags */
- RCC_ClearFlag();
- /* Display time in infinite loop */
- Time_Show();
- void RCC_Configuration()
- SystemInit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
- void NVIC_Configuration()
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Configure one bit for preemption priority */
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- /* Enable the RTC Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- void GPIO_Configuration()
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure USART1 Tx (PA.09) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure USART1 Rx (PA.10) as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- * Function Name : USART_Configuration
- * Description : Configures the USART1.
- * Input : None
- * Output : None
- * Return : None
- void USART_Configuration()
- USART_InitTypeDef USART_InitStructure;
- USART_InitStructure.USART_BaudRate = 115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(USART1, &USART_InitStructure);
- USART_Cmd(USART1, ENABLE);
- * Function Name : fputc
- * Description : Retargets the C library printf function to the USART or ITM Viewer.
- * Input : None
- * Output : None
- * Return : None
- /* 将Printf内容发往串口 */
- USART_SendData(USART1, (unsigned char) ch);
- while (!(USART1->SR & USART_FLAG_TXE));
- return (ch);
- *函数名:RTC_Configuration
- *描述:配置RTC
- *输入:无
- *输出:无
- *返回:无
- void RTC_Configuration()
- /*允许PWR和BKP时钟*/
- /*允许访问BKP域*/
- /*复位备份域*/
- BKP_DeInit();
- #ifdef RTCClockSource_LSI
- /*允许LSI*/
- RCC_LSICmd(ENABLE);
- /*等待LSI准备好*/
- while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY)==RESET)
- /*选择LSI作为RTC时钟源*/
- RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
- #elif defined RTCClockSource_LSE
- /*允许LSE*/
- RCC_LSEConfig(RCC_LSE_ON);
- /*等待LSE准备好*/
- while(RCC_GetFlagStatus(RCC_FLAG_LSERDY)==RESET)
- /*选择LSE作为RTC时钟源*/
- RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
- #endif
- /* Enable RTC Clock */
- RCC_RTCCLKCmd(ENABLE);
- /*禁止Tamper引脚*/
- BKP_TamperPinCmd(DISABLE);/*为了将RTCCLK/64在Tamper引脚输出,Tamper功能必须被禁止*/
- /*允许RTC时钟在Tamper引脚上输出*/
- BKP_RTCCalibrationClockOutputCmd(ENABLE);
- #endif
- /*等待寄存器同步*/
- /*允许RTC秒中断*/
- /*设置分频系数*/
- RTC_SetPrescaler(31999); /*RTC周期=RTCCLK/RTC_PR=(32.000kHz/(31999+1))*/
- RTC_SetPrescaler(32767); /*RTC周期=RTCCLK/RTC_PR=(32.768kHz/(31767+1))*/
- #endif
- * Function Name : Time_Regulate
- * Description : Returns the time entered by user, using Hyperterminal.
- * Input : None
- * Output : None
- * Return : Current time RTC counter value
- //u32 Time_Regulate()
- // u32 Tmp_HH = 0xFF, Tmp_MM = 0xFF, Tmp_SS = 0xFF;
- // printf("\r\n==============Time Settings=====================================");
- // printf("\r\n Please Set Hours");
- // while (Tmp_HH == 0xFF)
- // Tmp_HH = USART_Scanf(23);
- // printf(": %d", Tmp_HH);
- // printf("\r\n Please Set Minutes");
- // while (Tmp_MM == 0xFF)
- // Tmp_MM = USART_Scanf(59);
- // printf(": %d", Tmp_MM);
- // printf("\r\n Please Set Seconds");
- // while (Tmp_SS == 0xFF)
- // Tmp_SS = USART_Scanf(59);
- // printf(": %d", Tmp_SS);
- // /* 返回用户输入值,以便存入RTC计数寄存器 */
- // return((Tmp_HH*3600 + Tmp_MM*60 + Tmp_SS));
- u32 Tmp_YY = 0xFF, Tmp_MM = 0xFF, Tmp_DD = 0xFF, Tmp_HH = 0xFF, Tmp_MI = 0xFF, Tmp_SS = 0xFF;
- printf("\r\n=========================Time Settings==================");
- printf("\r\n 请输入年份(Please Set Years): 20");
- while (Tmp_YY == 0xFF)
- Tmp_YY = USART_Scanf(99);
- printf("\n\r 年份被设置为: 20%0.2d\n\r", Tmp_YY);
- tm->tm_year = Tmp_YY+2000;
- Tmp_MM = 0xFF;
- printf("\r\n 请输入月份(Please Set Months): ");
- while (Tmp_MM == 0xFF)
- Tmp_MM = USART_Scanf(12);
- printf("\n\r 月份被设置为: %d\n\r", Tmp_MM);
- tm->tm_mon= Tmp_MM;
- Tmp_DD = 0xFF;
- printf("\r\n 请输入日期(Please Set Dates): ");
- while (Tmp_DD == 0xFF)
- Tmp_DD = USART_Scanf(31);
- printf("\n\r 日期被设置为: %d\n\r", Tmp_DD);
- tm->tm_mday= Tmp_DD;
- Tmp_HH = 0xFF;
- printf("\r\n 请输入时钟(Please Set Hours): ");
- while (Tmp_HH == 0xFF)
- Tmp_HH = USART_Scanf(23);
- printf("\n\r 时钟被设置为: %d\n\r", Tmp_HH );
- tm->tm_hour= Tmp_HH;
- Tmp_MI = 0xFF;
- printf("\r\n 请输入分钟(Please Set Minutes): ");
- while (Tmp_MI == 0xFF)
- Tmp_MI = USART_Scanf(59);
- printf("\n\r 分钟被设置为: %d\n\r", Tmp_MI);
- tm->tm_min= Tmp_MI;
- Tmp_SS = 0xFF;
- printf("\r\n 请输入秒钟(Please Set Seconds): ");
- while (Tmp_SS == 0xFF)
- Tmp_SS = USART_Scanf(59);
- printf("\n\r 秒钟被设置为: %d\n\r", Tmp_SS);
- tm->tm_sec= Tmp_SS;
- * Function Name : Time_Adjust
- * Description : Adjusts time.
- * Input : None
- * Output : None
- * Return : None
- //void Time_Adjust()
- // /* Wait until last write operation on RTC registers has finished */
- // RTC_WaitForLastTask();
- // /* 修改当前RTC计数寄存器内容 */
- // RTC_SetCounter(Time_Regulate());
- void Time_Adjust()
- /* Wait until last write operation on RTC registers has finished */
- /* Get time entred by the user on the hyperterminal */
- Time_Regulate(&systmtime);
- /* Get wday */
- GregorianDay(&systmtime);
- /* 修改当前RTC计数寄存器内容 */
- RTC_SetCounter(mktimev(&systmtime));
- * Function Name : Time_Display
- * Description : Displays the current time.
- * Input : - TimeVar: RTC counter value.
- * Output : None
- * Return : None
- //void Time_Display(u32 TimeVar)
- // u32 THH = 0, TMM = 0, TSS = 0;
- // /* Compute hours */
- // THH = TimeVar / 3600;
- // /* Compute minutes */
- // TMM = (TimeVar % 3600) / 60;
- // /* Compute seconds */
- // TSS = (TimeVar % 3600) % 60;
- // printf("Time: %0.2d:%0.2d:%0.2d\r", THH, TMM, TSS);
- static uint32_t FirstDisplay = 1;
- u8 str[15]; // 字符串暂存
- to_tm(TimeVar, &systmtime);
- if((!systmtime.tm_hour && !systmtime.tm_min && !systmtime.tm_sec) || (FirstDisplay))
- GetChinaCalendar((u16)systmtime.tm_year, (u8)systmtime.tm_mon, (u8)systmtime.tm_mday, str);
- printf("\n\r\n\r 今天农历:%0.2d%0.2d,%0.2d,%0.2d", str[0], str[1], str[2], str[3]);
- GetChinaCalendarStr((u16)systmtime.tm_year,(u8)systmtime.tm_mon,(u8)systmtime.tm_mday,str);
- printf(" %s", str);
- if(GetJieQiStr((u16)systmtime.tm_year, (u8)systmtime.tm_mon, (u8)systmtime.tm_mday, str))
- printf(" %s\n\r", str);
- FirstDisplay = 0;
- /* 输出公历时间 */
- printf("\r 当前时间为: %d年(%s年) %d月 %d日 (星期%s) %0.2d:%0.2d:%0.2d",
- systmtime.tm_year, zodiac_sign[(systmtime.tm_year-3)%12], systmtime.tm_mon, systmtime.tm_mday,
- WEEK_STR[systmtime.tm_wday], systmtime.tm_hour,
- systmtime.tm_min, systmtime.tm_sec);
- * Function Name : Time_Show
- * Description : Shows the current time (HH:MM:SS) on the Hyperterminal.
- * Input : None
- * Output : None
- * Return : None
- void Time_Show()
- printf("\n\r");
- /* Infinite loop */
- while (1)
- /* 每过1s */
- …………限于本文篇幅 余下代码请从51黑下载附件…………
超强日历(含24节气和闰平年).rar
(255.87 KB, 下载次数: 245)
