希望有更好的可以一起分享上来
- LEADIY-M3测试程序示例V2.2
- 作者: Colin
- 版权所有: 深圳市软芯微电子科技有限公司
- 芯片型号: stm32f103CB
- #include "string.h"
- #include "stm32f10x.h"
- #include "sys.h"
- #include "usart.h"
- #include "delay.h"
- #include "drv_Uart.h"
- int16_t Gyro[3], Acc[3], Angle[3], Mag[3];
- int32_t Altitude, Pressure;
- float Temper, GyroDPS[3], AccG[3], MagGauss[3], AngleDeg[3];
- /*读两个字节组成一个16位数*/
- int16_t ReadW(void)
- unsigned char BufC;
- int16_t BufW;
- BufC = uartRead();
- BufW = (uint16_t)BufC;
- BufW = (int16_t)(((uint16_t)BufC << 8) | BufW);
- return BufW;
- int main(void)
- uint16_t BufW;
- /* 系统初始化*/
- systemInit();
- delay_ms(300);
- printf("LEADIY-M3 TEST V2\r\n");
- while (1)
- if(uartAvailable()) //检测是否收到LEADIY-M3数据
- BufC = uartRead(); //读一个字节
- if((BufC==0xA7)){ //判断是否为帧 头
- if (BufC==0x7A) { //判断是否为帧头
- switch(BufC) //帧类型判断
- case 0x70: //标识为角速度帧
- BufC = uartRead(); //帧长度,可不用
- BufC = uartRead(); //效验位
- Gyro[0] = ReadW(); //X轴
- Gyro[1] = ReadW(); //Y轴
- Gyro[2] = ReadW(); //Z轴
- /*GYRO的量程为2000度每秒*/
- /* 得到以"dps" ("度/秒")为单位的角速度值*/
- GyroDPS[0] = (float)Gyro[0]*4/16.4;
- GyroDPS[1] = (float)Gyro[1]*4/16.4;
- GyroDPS[2] = (float)Gyro[2]*4/16.4;
- printf("GYRO X:%d Y:%d Z:%d\r\n", Gyro[0], Gyro[1], Gyro[2]);
- printf("GyroDPS X: %.2f, Y: %.2f, Z: %.2f\r\n", GyroDPS[0], GyroDPS[1], GyroDPS[2]);
- break;
- case 0x71: //标识为加速度帧
- Acc[0] = ReadW(); //X轴
- Acc[1] = ReadW(); //Y轴
- Acc[2] = ReadW(); //Z轴
- /*ACC的量程为8G*/
- /*得到以"g"为单位的加速度*/
- AccG[0] = (float)Acc[0] / 4096;
- AccG[1] = (float)Acc[1] / 4096;
- AccG[2] = (float)Acc[2] / 4096;
- printf("ACC X:%d Y:%d Z:%d\r\n", Acc[0], Acc[1], Acc[2]);
- printf("AccG X:%.2f Y:%.2f Z:%.2f\r\n", AccG[0], AccG[1], AccG[2]);
- break;
- case 0x72: //标识为姿态帧
- Angle[0] = ReadW(); //X轴角度(横滚)
- Angle[1] = ReadW(); //Y轴角度(俯仰)
- Angle[2] = ReadW(); //Z轴角度(偏航)
- AngleDeg[0] = (float)Angle[0] / 100;
- AngleDeg[1] = (float)Angle[1] / 100;
- AngleDeg[2] = (float)Angle[2] / 100;
- if (AngleDeg[2]<0) AngleDeg[2] += 360; //将航向值转化到0---360度区间
- printf("ANGLE X:%d Y:%d Z:%d \r\n", Angle[0], Angle[1], Angle[2]);
- printf("AngleDeg X:%.2f Y:%.2f Z:%.2f \r\n", AngleDeg[0], AngleDeg[1], AngleDeg[2]);
- break;
- case 0x73: //标识为 地磁帧
- Mag[0] = ReadW(); //X轴
- Mag[1] = ReadW(); //Y轴
- Mag[2] = ReadW(); //Z轴
- /*地磁设置为2.5Ga*/
- /*得到以"Gauss"为单位的地磁*/
- MagGauss[0] = (float)Mag[0] / 660;
- MagGauss[1] = (float)Mag[1] / 660;
- MagGauss[2] = (float)Mag[2] / 660;
- printf("Mag X:%d Y:%d Z:%d \r\n", Mag[0], Mag[1], Mag[2]);
- printf("MagGauss X:%.2f Y:%.2f Z:%.2f \r\n", MagGauss[0], MagGauss[1], MagGauss[2]);
- break;
- case 0x74: //标识为温度、气压帧
- Temper = ReadW() / 10; //X轴
- BufW = ReadW(); //气压低16位
- Pressure = (int32_t)(((uint32_t)(ReadW() << 16))|BufW);
- printf("Temperature(Degree):%.2f Pressure(Pa):%d \r\n", Temper, Pressure);
- break;
- case 0x75: // 标识为高度帧
- BufW = ReadW(); //高度低16位
- /*得到以"CM"为单位的海拔高度*/
- Altitude = (int32_t)(((uint32_t)(ReadW() << 16))|BufW);
- printf("Altitude(cm):%d \r\n", Altitude);
- break;
- default: break;
陀螺仪资料.rar
(1.09 MB, 下载次数: 23)
