查看: 1324|回复: 0
红绿灯
ID:343606 发表于 2018-6-2 17:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit RED_A=P1^0;     //东西向红灯
sbit YEL_A=P1^1;      //东西向黄灯
sbit GRE_A=P1^2;     //东西向绿灯
sbit RED_B=P1^3;     //南北向红灯
sbit YEL_B=P1^4;      //南北向黄灯
sbit GRE_B=P1^5;     //南北向绿灯
uchar Time_Count=0,Flash_Count=0,Operation_Type=1;     //分别用于计中断次数,计闪烁次数(2倍),保存当前状态值
void time0() interrupt 1    //T0定时器中断服务函数
TH0=(65536-50000)/256;    //重置定时器初值
TL0=(65536-50000)%256;
switch(Operation_Type)   //根据状态值执行相应语句
  case 1: RED_A=0;YEL_A=0;GRE_A=1;   //东西向绿灯亮
               RED_B=1;YEL_B=0;GRE_B=0;   //南北向红灯亮
               if(++Time_Count!=100)return;   //5s时间未到退出switch语句
         Time_Count=0;                  //5s时间到计数值清零
         Operation_Type=2;             //状态转移值变为2,准备状态转移
         break;               //退出switch语句
case 2: if(++Time_Count!=8)return;   //400ms未到退出switch语句
                Time_Count=0;
           YEL_A=!YEL_A;GRE_A=0;  //东西向黄灯闪,绿灯灭
           if(++Flash_Count!=10)return;   //闪烁5次未到退出
           Flash_Count=0;    //闪烁次数清零
           Operation_Type=3;   //状态转移值变为3,准备状态转移
           break;
  case 3: RED_A=1;YEL_A=0;GRE_A=0;   //东西向红灯亮
               RED_B=0;YEL_B=0;GRE_B=1;   //南北向绿灯亮
          if(++Time_Count!=100)return;    //5s未到退出
           Time_Count=0;
   Operation_Type=4;   //状态转移值变为4,准备状态转移
          break;
  case 4: if(++Time_Count!=8)return;   //0.4s未到退出
                Time_Count=0;
           YEL_B=!YEL_B;GRE_B=0;   //南北向黄灯闪烁,绿灯灭
           Flash_Count=0;
           Operation_Type=1;   //重新转移到状态1
           break;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TH0=(65536-50000)/256;    //定时50ms初值
  TR0=1;   //启动T0定时器
  while(1);
#include<reg52.h>
sbit RED_A=P1^0;
sbit YEL_A=P1^1;
sbit GRE_A=P1^2;
sbit RED_B=P1^3;
sbit YEL_B=P1^4;
sbit GRE_B=P1^5;
         Time_Count=0;
         Operation_Type=2;
         break;
                Time_Count=0;
           Flash_Count=0;
           Operation_Type=3;
           break;
           Time_Count=0;
   Operation_Type=4;
          break;
                Time_Count=0;
           Flash_Count=0;
           Operation_Type=1;
           break;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TR0=1;
  while(1);
