sbit RS = P2^0;
sbit RW = P2^1;
sbit EN = P2^2;
void Delayms(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
uchar Busy_Check()
uchar LCD_Status;
RS = 0;
RW = 1;
EN = 1;
Delayms(1);
LCD_Status = P0;
EN = 0;
return LCD_Status;
void Write_LCD_Command(uchar cmd)
while((Busy_Check()&0x80)==0x80);
RS = 0;
RW = 0;
EN = 0;
P0 = cmd;
EN = 1;
Delayms(1);
EN = 0;
void Write_LCD_Data(uchar dat)
RS = 1;
RW = 0;
EN = 0;
P0 = dat;
EN = 1;
Delayms(1);
EN = 0;
void Initialize_LCD()
Write_LCD_Command(0x38);
Delayms(1);
Write_LCD_Command(0x01);
Delayms(1);
Write_LCD_Command(0x06);
Delayms(1);
Write_LCD_Command(0x0c);
Delayms(1);
void ShowString(uchar x,uchar y,uchar *str)
uchar i = 0;
if(y == 0)
Write_LCD_Command(0x80 | x);
if(y == 1)
Write_LCD_Command(0xc0 | x);
for(i=0;i<16;i++)
Write_LCD_Data(str[i]);
