#include <reg51.h>
#define LCDLCDDisp_Off 0x3e
#define LCDLCDDisp_On 0x3f
#define Page_Add 0xb8//页地址
#define LCDCol_Add 0x40//列地址
#define Start_Line 0xC0//行地址
/*****液晶显示器的端口定义*****/
#define data_ora P0 /*液晶数据总线*/
sbit LCDMcs=P2^4 ; /*片选1*/
sbit LCDScs=P2^3 ; /*片选2*/
sbit LCDDi=P2^0 ; /*数据/指令 选择*/
sbit LCDRW=P2^1 ; /*读/写 选择*/
sbit LCDEnable=P2^2 ; /*读/写 使能*/
unsigned char code Bmp1[]=
源文件 / 文字 : 来自剪贴板!武汉理工大学
宽×高(像素): 128×16
字模格式/大小 : 单色点阵液晶字模,纵向取模,字节倒序/256字节
数据转换日期 : 2010-7-29 17:52:57
显示的汉字:武汉理工大学
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x20,0x24,0x24,0x24,0xE4,0x24,0x20,0x20,0xFE,0x20,0x24,0x28,0x20,
0x00,0x20,0xC2,0x0C,0x80,0x60,0x04,0x7C,0x84,0x04,0x04,0xC4,0x3E,0x04,0x00,0x00,
0x88,0x88,0xF8,0x88,0x88,0x00,0xFC,0x24,0x24,0xFC,0x24,0x24,0xFE,0x04,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x20,
0x20,0x20,0x20,0x20,0xFE,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x60,0x3F,0x20,0x20,0x1F,0x12,0x12,0x10,0x07,0x18,0x20,0x40,0x78,
0x00,0x04,0x04,0x7E,0x41,0x40,0x20,0x10,0x0B,0x04,0x0B,0x10,0x20,0x60,0x20,0x00,
0x10,0x30,0x1F,0x08,0x48,0x40,0x4B,0x49,0x49,0x7F,0x49,0x49,0x6B,0x40,0x08,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x40,
0x20,0x10,0x08,0x06,0x01,0x02,0x04,0x08,0x10,0x20,0x60,0x20,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp2[]=
源文件 / 文字 : 信息工程学院
宽×高(像素): 128×16
数据转换日期 : 2010-7-29 18:34:04
显示的汉字:信息工程学院
0x00,0x80,0x40,0xF0,0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,
0x00,0x00,0x00,0xF8,0xA8,0xAC,0xAA,0xA8,0xA8,0xA8,0xFC,0x08,0x00,0x00,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,
0xA4,0xFC,0x26,0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0xFC,0x04,0x64,
0x9C,0x20,0x58,0x48,0x4A,0x4C,0x48,0x48,0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,
0x00,0x20,0x18,0x03,0x3A,0x42,0x46,0x5A,0x42,0x42,0x73,0x00,0x08,0x30,0x00,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,
0x01,0x7F,0x01,0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x7F,0x04,0x08,
0x47,0x41,0x21,0x1F,0x01,0x01,0x3F,0x41,0x41,0x79,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp3[]=
源文件 / 文字 : 通信工程
宽×高(像素): 128×
数据转换日期 : 2010-7-29 18:36:04
显示汉字:通信工程
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x42,
0xCC,0x00,0x00,0xF4,0x54,0x5C,0xF4,0x5C,0x56,0xF4,0x00,0x00,0x00,0x80,0x40,0xF0,
0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,0x00,0x08,0x08,0x08,
0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,0xA4,0xFC,0x26,
0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x10,
0x0F,0x10,0x20,0x5F,0x42,0x42,0x5F,0x42,0x52,0x5F,0x40,0x40,0x00,0x00,0x00,0x7F,
0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,0x20,0x20,0x20,0x20,
0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,0x01,0x7F,0x01,
0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp4[]=
源文件 / 文字 : 0606班
宽×高(像素): 128×16
数据转换日期 : 2010-7-29 18:37:59
显示的汉字:0606班
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x44,0x44,0xFC,0x44,0x04,0xC0,0x00,0xFE,0x84,0x84,
0xFC,0x84,0x84,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x10,0x10,0x0F,0x48,0x28,0x11,0x08,0x27,0x20,0x20,
0x3F,0x20,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
函数功能:LCD延时程序
入口参数:t
出口参数:
void LCDdelay(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++);
for(j=0;j<10;j++);
状态检查,LCD是否忙
void CheckState()
unsigned char dat,DATA;//状态信息(判断是否忙)
LCDDi=0; // 数据\指令选择,D/I(RS)="L" ,表示 DB7∽DB0 为显示指令数据
LCDRW=1; //R/W="H" ,E="H"数据被读到DB7∽DB0
do
DATA=0x00;
LCDEnable=1; //EN下降源
LCDdelay(2);//延时
dat=DATA;
LCDEnable=0;
dat=0x80 & dat; //仅当第7位为0时才可操作(判别busy信号)
while(!(dat==0x00));
函数功能:写命令到LCD程序,RS(DI)=L,RW=L,EN=H,即来一个脉冲写一次
入口参数:cmdcode
出口参数:
void write_com(unsigned char cmdcode)
CheckState();//检测LCD是否忙
LCDDi=0;
LCDRW=0;
P0=cmdcode;
LCDdelay(2);
LCDEnable=1;
LCDdelay(2);
LCDEnable=0;
函数功能:LCD初始化程序
入口参数:
出口参数:
void init_lcd()
LCDdelay(100);
LCDMcs=1;//刚开始关闭两屏
LCDScs=1;
LCDdelay(100);
write_com(LCDLCDDisp_Off); //写初始化命令
write_com(Page_Add+0);
write_com(Start_Line+0);
write_com(LCDCol_Add+0);
write_com(LCDLCDDisp_On);
函数功能:写数据到LCD程序,RS(DI)=H,RW=L,EN=H,即来一个脉冲写一次
入口参数:LCDDispdata
出口参数:
void write_data(unsigned char LCDDispdata)
LCDDi=1;
LCDRW=0;
P0=LCDDispdata;
LCDdelay(2);
LCDEnable=1;
LCDdelay(2);
LCDEnable=0;
函数功能:清除LCD内存程序
入口参数:pag,col,hzk
出口参数:
void Clr_Scr()
unsigned char j,k;
LCDMcs=0; //左、右屏均开显示
LCDScs=0;
for(k=0;k<8;k++)//控制页数0-7,共8页
write_com(Page_Add+k); //每页每页进行写
for(j=0;j<64;j++) //每页最多可写32个中文文字或64个ASCII字符
write_com(LCDCol_Add+j);
write_data(0x00);//控制列数0-63,共64列,写点内容,列地址自动加1
函数功能:左屏位置显示
入口参数:page,column,hzk
出口参数:
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
unsigned char j=0,i=0;
for(j=0;j<2;j++)
write_com(Page_Add+page+j);
write_com(LCDCol_Add+column);
for(i=0;i<64;i++)
write_data(Bmp[128*j+i]);
函数功能:右屏位置显示
出口参数:
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
for(j=0;j<2;j++)
for(i=64;i<128;i++)
init_lcd();
Clr_Scr();
LCDMcs=0; //左屏开显示
LCDScs=1;
Bmp_Left_Disp(0,0,Bmp1);// Bmp1为某个汉字的首地址
Bmp_Left_Disp(2,0,Bmp2);
Bmp_Left_Disp(4,0,Bmp3);
Bmp_Left_Disp(6,0,Bmp4);
LCDMcs=1; //右屏开显示
LCDScs=0;
Bmp_Right_Disp(0,0,Bmp1);
Bmp_Right_Disp(2,0,Bmp2);
Bmp_Right_Disp(4,0,Bmp3);
Bmp_Right_Disp(6,0,Bmp4);
这是程序 |
