查看: 819|回复: 0
DS1302
ID:345165 发表于 2018-6-5 08:56 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "ds1302.h"
unsigned char time_buf1[8] = {20,10,6,5,12,55,00,6};//空年月日时分秒周
unsigned char time_buf[8] ;                         //空年月日时分秒周
           向DS1302写入一字节数据
void Ds1302_Write_Byte(unsigned char addr, unsigned char d)
        unsigned char i;
        RST_SET;
        //写入目标地址:addr
        addr = addr & 0xFE;     //最低位置零
        for (i = 0; i < 8; i ++)
                if (addr & 0x01)
                        IO_SET;
                        IO_CLR;
                SCK_SET;
                SCK_CLR;
                addr = addr >> 1;
        //写入数据:d
                if (d & 0x01)
                        IO_SET;
                        IO_CLR;
                SCK_SET;
                SCK_CLR;
                d = d >> 1;
        RST_CLR;                                        //停止DS1302总线
           从DS1302读出一字节数据
unsigned char Ds1302_Read_Byte(unsigned char addr)
        unsigned char i;
        unsigned char temp;
        RST_SET;
        //写入目标地址:addr
        addr = addr | 0x01;//最低位置高
                if (addr & 0x01)
                        IO_SET;
                        IO_CLR;
                SCK_SET;
                SCK_CLR;
                addr = addr >> 1;
        //输出数据:temp
                temp = temp >> 1;
                if (IO_R)
                        temp |= 0x80;
                        temp &= 0x7F;
                SCK_SET;
                SCK_CLR;
        return temp;
           向DS1302写入时钟数据
void Ds1302_Write_Time(void)
    unsigned char i,tmp;
        for(i=0;i<8;i++)
            {                  //BCD处理
                tmp=time_buf1[i]/10;
                time_buf[i]=time_buf1[i]%10;
                time_buf[i]=time_buf[i]+tmp*16;
        Ds1302_Write_Byte(ds1302_control_add,0x00);                        //关闭写保护
        Ds1302_Write_Byte(ds1302_sec_add,0x80);                                //暂停
        //Ds1302_Write_Byte(ds1302_charger_add,0xa9);                        //涓流充电
        Ds1302_Write_Byte(ds1302_year_add,time_buf[1]);                //年
        Ds1302_Write_Byte(ds1302_month_add,time_buf[2]);        //月
        Ds1302_Write_Byte(ds1302_date_add,time_buf[3]);                //日
        Ds1302_Write_Byte(ds1302_day_add,time_buf[7]);                //周
        Ds1302_Write_Byte(ds1302_hr_add,time_buf[4]);                //时
        Ds1302_Write_Byte(ds1302_min_add,time_buf[5]);                //分
        Ds1302_Write_Byte(ds1302_sec_add,time_buf[6]);                //秒
        Ds1302_Write_Byte(ds1302_control_add,0x80);                        //打开写保护
           从DS1302读出时钟数据
void Ds1302_Read_Time(void)
        time_buf[1]=Ds1302_Read_Byte(ds1302_year_add);                //年
        time_buf[2]=Ds1302_Read_Byte(ds1302_month_add);                //月
        time_buf[3]=Ds1302_Read_Byte(ds1302_date_add);                //日
        time_buf[4]=Ds1302_Read_Byte(ds1302_hr_add);                //时
        time_buf[5]=Ds1302_Read_Byte(ds1302_min_add);                //分
        time_buf[6]=(Ds1302_Read_Byte(ds1302_sec_add))&0x7F;//秒
        time_buf[7]=Ds1302_Read_Byte(ds1302_day_add);                //周
        for(i=0;i<8;i++)
           {           //BCD处理
                tmp=time_buf[i]/16;
                time_buf1[i]=time_buf[i]%16;
                time_buf1[i]=time_buf1[i]+tmp*10;
                DS1302初始化
void Ds1302_Init(void)
        RST_CLR;                        //RST脚置低
        SCK_CLR;                        //SCK脚置低
    Ds1302_Write_Byte(ds1302_sec_add,0x00);
