查看: 16691|回复: 33
stm32f103ADC测试程序,16路ADC采样+DMA传送数据
ID:349802 发表于 2018-6-11 20:56 | 显示全部楼层 |阅读模式
#include "adc.h"
#include "delay.h"
16路ADC采样DMA传输
调用Adc_Init()函数初始化设备,ADC循环采样
数据被DMA搬运到ADC_Value[ADC_CH_NUM]数组中
滤波后的数据在ADC_AfterFilter[ADC_CH_NUM]中
u16 ADC_Value[ADC_CH_NUM] = {0};
u16 ADC_AfterFilter[ADC_CH_NUM] = {0};
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB|
        RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE );          //使能ADC1通道时钟
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
        //PA1-PA7 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|
                                        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模拟输入引脚
        GPIO_Init(GPIOA, &GPIO_InitStructure);
                //PC4-C5 作为模拟通道输入引脚
        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
                        //PB0-B1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
/*定义DMA外设基地址,即为存放转换结果的寄存器*/
DMA_InitStructure.DMA_PeripheralBaseAddr =(u32)&(ADC1->DR);
/*定义内存基地址*/
DMA_InitStructure.DMA_MemoryBaseAddr =(u32)ADC_Value;
/*定义AD外设作为数据传输的来源*/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
/*指定DMA通道的DMA缓存的大小,即需要开辟几个内存空间,由ADC_CH_NUM这个宏决定*/
DMA_InitStructure.DMA_BufferSize = ADC_CH_NUM;
        /*设定寄存器地址固定*/
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
/*设定内存地址递加,即每次DMA都是将该外设寄存器中的值传到开辟的内存空间中*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
/*设定外设数据宽度 半字*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        /*设定内存的的宽度 半字*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        /*设定DMA工作再循环缓存模式*/
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
/*设定DMA选定的通道软件优先级*/
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_DeInit(ADC1);  //复位ADC1
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在独立模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE ;        //模数转换工作在扫描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE ;        //模数转换工作在连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //转换由软件而不是外部触发启动
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = ADC_CH_NUM;        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
        /*ADC通道编号*/
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 9, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 10, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10,11, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11,12, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12,13, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13,14, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14,15, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15,16, ADC_SampleTime_55Cycles5);
  ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        ADC_ResetCalibration(ADC1);        //使能复位校准
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待复位校准结束
        ADC_StartCalibration(ADC1);         //开启AD校准
        while(ADC_GetCalibrationStatus(ADC1));         //等待校准结束
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
16路ADC DMA采样.zip
382.42 KB, 下载次数: 713, 下载积分: 黑币 -5
16路ADC
参与人数 2黑币 +18 收起 理由
13149688123 + 10 很给力!
是各个环节 + 8 赞一个!
ID:340339 发表于 2018-6-26 13:55 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:374095 发表于 2018-7-18 15:07 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:376277 发表于 2018-7-22 17:17 | 显示全部楼层
不错,正需要
ID:388992 发表于 2018-9-28 11:54 | 显示全部楼层
最近在学习ADC DMA多通道采集。搞了好多天还没有成功。
ID:364557 发表于 2018-11-6 18:33 | 显示全部楼层
黑金不够呀大哥
ID:435528 发表于 2018-11-29 10:17 | 显示全部楼层
可以下载..........................................
ID:431123 发表于 2018-12-24 15:12 | 显示全部楼层
非常不错,很有帮助
ID:194625 发表于 2018-12-26 11:03 | 显示全部楼层
不错,可以学习下
ID:441972 发表于 2019-1-16 13:42 | 显示全部楼层
这个下载下来怎么是ALIENTEK 战舰STM32F103开发板实验17啊?怎么用呀?
ID:349802 发表于 2019-2-26 16:05 | 显示全部楼层
这只是工程名字而已,内容不一样啊
ID:479575 发表于 2019-2-28 08:10 | 显示全部楼层
谢谢分享!
ID:493236 发表于 2019-3-20 15:53 | 显示全部楼层
正好弄到ADC采样,可是黑金不够,很需要。。。
ID:265124 发表于 2019-3-28 23:18 | 显示全部楼层
真的太需要这个了
ID:387915 发表于 2019-4-22 21:34 | 显示全部楼层
你可以改时钟,IO口大致出不多,改完时钟应该就可以用
ID:387915 发表于 2019-4-22 21:36 | 显示全部楼层
学习了,感谢分享
ID:527812 发表于 2019-5-5 17:27 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:85129 发表于 2019-5-22 14:14 | 显示全部楼层
这个滤波的程序怎么没有?
ID:411900 发表于 2019-7-12 17:40 | 显示全部楼层
可以用,谢谢楼主!!!
ID:543162 发表于 2019-7-14 16:47 | 显示全部楼层
谢谢分享
ID:226089 发表于 2019-8-12 13:50 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:462389 发表于 2019-8-19 17:10 | 显示全部楼层
verygood
ID:269751 发表于 2019-8-19 18:16 | 显示全部楼层
mark,谢谢分享
ID:62077 发表于 2019-8-27 11:09 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:313048 发表于 2019-9-26 11:28 | 显示全部楼层
前排留名
ID:261884 发表于 2019-11-13 12:40 | 显示全部楼层
正需要,谢谢分享!~
ID:235223 发表于 2019-11-14 13:11 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:701882 发表于 2020-3-12 20:15 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:691773 发表于 2020-5-11 17:45 | 显示全部楼层
下载之后才发现没有
ID:662744 发表于 2020-7-6 10:19 | 显示全部楼层
正需要这个,感谢楼主
ID:808538 发表于 2020-7-27 16:28 | 显示全部楼层
正好弄到ADC采样,可是黑金不够
ID:1010606 发表于 2022-3-15 15:47 | 显示全部楼层
ID:333483 发表于 2022-8-29 15:05 | 显示全部楼层
试试看,怎么搞。。可以吧readme删掉。。
ID:1002032 发表于 2022-10-22 12:58 | 显示全部楼层
下载的文件哪里用到了DMA呀!怎么还是printf
