查看: 2239|回复: 0
51单片机制作计简易计算器的c程序源码
ID:357931 发表于 2018-6-24 18:09 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#include<math.h>
#include<stdlib.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit BUZZER=P1^0;
#define unchar unsigned char
#define unint unsigned int
void delay(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++)
  for(j=0;j<120;j++);
void busy()
RS=0;
RW=1;
E=1;
P0=0xff;
while((P0&0x80)==0x80);
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void write_com(unsigned char com)
busy();
RS=0;
RW=0;
E=1;
P0=com;
E=0;
void write_data(unchar date)
busy();
RS=1;
RW=0;
E=1;
P0=date;
E=0;
void init()
write_com(0x30);
write_com(0x0c);
write_com(0x01);
write_com(0x06);
void sendaddr(unchar n,unchar m)
switch(n)
  case 1:write_com(0x80+m);break;
  case 2:write_com(0x90+m);break;
  case 3:write_com(0x88+m);break;
  case 4:write_com(0x98+m);break;
void display(unchar n,unchar m,unchar*s)
sendaddr(n,m);
while(*s>0)
  write_data(*s);
  s++;
void clearscreen()
write_com(0x01);
void tishi()
clearscreen();
display(1,0,"超出计算范围");
display(2,0,"请按复位键");
display(3,0,"并重新输入");
display(4,0,"否则会出现错误");
void displayshu(unchar n,unchar m,long  rzt)
unchar i,j,k,x,p;
unchar t[10]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
unsigned char array[10];
array[9]=(int)rzt%10;
array[8]=((int)rzt/10)%10;
array[7]=((int)rzt/100)%10;
array[6]=((int)rzt/1000)%10;
array[5]=((int)rzt/10000)%10;
array[4]=((int)rzt/100000)%10;
array[3]=((int)rzt/1000000)%10;
array[2]=((int)rzt/10000000)%10;
array[1]=((int)rzt/100000000)%10;
array[0]=(int)rzt/1000000000;
sendaddr(n,m);
for(i=0;i<10;i++)
  if(array==0)
  p=i;
  break;
for(j=p+1;j<10;j++)
  t[k]=array[j];
  k++;
while(t[x]!=0xff)
  write_data(t[x]+0x30);
  x++;
void main(void)
unchar i,j,opt,p;
long b,c,rzt;
start:
init();
delay(20);
i=0;j=0;rzt=0;b=0;c=0;
write_com(0x80);
  P3=0xfe;
  if(P3!=0xfe)
   delay(40);
   if(P3!=0xfe)
    switch(P3&0xf0)
     case 0x70:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(0+0x30);
     b=b*10+0;
     i++;
     if(i==11)tishi();
     break;
     case 0xb0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(1+0x30);
     b=b*10+1;
     i++;
     if(i==11)tishi();
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(2+0x30);
     b=b*10+2;
     i++;
     if(i==11)tishi();
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(3+0x30);
     b=b*10+3;
     i++;
     if(i==11)tishi();
     break;
    if(P3!=0xfe);
    delay(30);
    while(P3!=0xfe);
  P3=0xfd;
  if(P3!=0xfd)
   delay(40);
   if(P3!=0xfd)
    switch(P3&0xf0)
     case 0x70:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(4+0x30);
     b=b*10+4;
     i++;
     if(i==11)tishi();
     break;
     case 0xb0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(5+0x30);
     b=b*10+5;
     i++;
     if(i==11)tishi();
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(6+0x30);
     b=b*10+6;
     i++;
     if(i==11)tishi();
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(7+0x30);
     b=b*10+7;
     i++;
     if(i==11)tishi();
     break;
    if(P3!=0xfd);
    delay(30);
    while(P3!=0xfd);
  P3=0xfb;
  if(P3!=0xfb)
   delay(40);
   if(P3!=0xfb)
    switch(P3&0xf0)
     case 0x70:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(8+0x30);
     b=b*10+8;
     i++;
     if(i==11)tishi();
     break;
     case 0xb0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     write_data(9+0x30);
     b=b*10+9;
     i++;
     if(i==11)tishi();
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     p=1;
     write_com(0x97);
     write_data(0x2b);
     opt=10;
     goto two;
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     p=1;
     write_com(0x97);
     write_data(0x2d);
     opt=10;
     goto two;
     break;
    if(P3!=0xfb);
    delay(30);
    while(P3!=0xfb);
  P3=0xf7;
  if(P3!=0xf7)
   delay(40);
   if(P3!=0xf7)
    switch(P3&0xf0)
     case 0x70:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     p=1;
     write_com(0x97);
     write_data(0x2a);
     opt=12;
     goto two;
     break;
     case 0xb0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     p=1;
     write_com(0x97);
     write_data(0x2f);
     opt=13;
     goto two;
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     clearscreen();
     goto start;
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     clearscreen();
     goto start;
     break;
    if(P3!=0xf7);
    delay(30);
    while(P3!=0xf7);
two:
  write_com(0x88);
   P3=0xfe;
   if(P3!=0xfe)
    delay(40);
    if(P3!=0xfe)
     switch(P3&0xf0)
      case 0x70:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(0+0x30);
      c=c*10+0;
      j++;
      if(j==11)tishi();
      break;
      case 0xb0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(1+0x30);
      c=c*10+1;
      j++;
      if(j==11)tishi();
      break;
      case 0xd0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(2+0x30);
      c=c*10+2;
      j++;
      if(j==11)tishi();
      break;
      case 0xe0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(3+0x30);
      c=c*10+3;
      j++;
      if(j==11)tishi();
      break;
     if(P3!=0xfe);
     delay(30);
     while(P3!=0xfe);
   P3=0xfd;
   if(P3!=0xfd)
    delay(40);
    if(P3!=0xfd)
     switch(P3&0xf0)
      case 0x70:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(4+0x30);
      c=c*10+4;
      j++;
      if(j==11)tishi();
      break;
      case 0xb0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(5+0x30);
      c=c*10+5;
      j++;
      if(j==11)tishi();
      break;
      case 0xd0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(6+0x30);
      c=c*10+6;
      j++;
      if(j==11)tishi();
      break;
      case 0xe0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(7+0x30);
      c=c*10+7;
      j++;
      if(j==11)tishi();
      break;
     if(P3!=0xfd);
     delay(30);
     while(P3!=0xfd);
   P3=0xfb;
   if(P3!=0xfb)
    delay(40);
    if(P3!=0xfb)
     switch(P3&0xf0)
      case 0x70:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(8+0x30);
      c=c*10+8;
      j++;
      if(j==11)tishi();
      break;
      case 0xb0:
      BUZZER=0;
      delay(80);
      BUZZER=1;
      write_data(9+0x30);
      c=c*10+9;
      j++;
     if(j==11)tishi();
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     if(p==0){write_com(0x97);write_data(0x2b);}
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     if(p==0){write_com(0x97);write_data(0x2d);}
     break;
    if(P3!=0xfb);
    delay(30);
    while(P3!=0xfb);
  P3=0xf7;
  if(P3!=0xf7)
   delay(40);
   if(P3!=0xf7)
    switch(P3&0xf0)
     case 0x70:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     if(p==0){write_com(0x97);write_data(0x2a);}
     break;
     case 0xb0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     if(p==0){write_com(0x97);write_data(0x2f);}
     break;
     case 0xd0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     goto answer;
     break;
     case 0xe0:
     BUZZER=0;
     delay(80);
     BUZZER=1;
     goto answer;
     break;
   if(P3!=0xf7);
   delay(30);
   while(P3!=0xf7);
answer:
  write_com(0x98);
  write_data(0x3d);
  if(c==0&&opt==13)
   display(2,0,"分母不能为零");
   clearscreen();
   goto start;
  switch(opt)
   case 10:rzt=(b+c);displayshu(4,2,rzt);break;
   case 11:rzt=(b-c);if(rzt<0){rzt=c-b;write_data(0x2d);}displayshu(4,2,rzt);break;
   case 12:rzt=(b*c);displayshu(4,2,rzt);break;
   case 13:rzt=(b/c);
   if((int)b%(int)c==0)
   rzt=rzt*1000;
   break;
  if(rzt>9999999999)
   clearscreen();
   display(2,1,"超出计算范围");
   delay(1000);
   goto start;
   P3=0xf7;
   if(P3!=0xf7)
    delay(40);
    if(P3!=0xf7)
     if((P3&0xf0)==0xe0)
      goto start;
     if(P3!=0xf7);
     delay(30);
     while(P3!=0xf7);
新建 Microsoft Word 文档 (2).docx
19.3 KB, 下载次数: 5, 下载积分: 黑币 -5
