查看: 1379|回复: 2
下降沿中断打开定时器计算每两个下降沿的时间
ID:191710 发表于 2018-6-27 09:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下降沿中断打开定时器计算每两个下降沿的时间。
void exint0_init()
        IT0=1;
        EX0=1;
void exint0_interrupt() interrupt 0
        TR0 = 0;
        SBUF=count_time;
        count_time=0;
        TR0 = 1;
void timer0_init()
        //16us进入一次中断
        AUXR |= 0x80;
        TMOD &= 0xF0;
        TL0 = 0x4F;
        TH0 = 0xFF;
        TF0 = 0;
        ET0=1;
void timer0_interrupt() interrupt 1
        count_time++;
        if(count_time>=96)
                TR0 = 0;
但是 通过串口 接收的数据发现不正确。有高手可以告诉我问题吗?
ID:191710 发表于 2018-6-27 09:47 | 只看该作者
00 10 00 F9 0E 40 00 40 00 20 00 00 00 00 40 40 00 10 00 00 00 20 00 00 20 00 00 10 00 A0 21 30 20 40 00 10 00 00 00 00 00 40 40 20 01 00 00 00 00 30 00 00 40 20 00 20 00 00 40 0F 41 00 20 00 00 00 00 41 40 00 00 00 00 08 20 00 00 20 00 20 00 21 00 00 00 00 40 10 00 00 00 00 00 00 40 41 00 00 00 00 00 60 00 00 40 20 00 60 00 00 40 00 40 00 01 00 00 00 00 00 40 40 20 00 00 00 00 00 F1 01 00 00 20 00 60 00 00 00 00 40 00 21 00 00 00 00 40 40 01 00 00 00 00 A0 1F 00 20 00 20 00 A0 00 00 00 00 40 00 10 00 00 00 00 00 40 40 01 00 00 00 00 60 1F 00 40 20 00 60 00 0F 40 00 40 00 10 00 00 00 00 00 40 40 20 00 00 00 00 00 F1 01 00 00 20 00 60 00 00 00 00 40 01 20 00 00 00 00 40 41 00 00 00 10 00 20 00 00 20 40 20 00 A0 00 1F 00 00 40 01 00 01 00 01 20 21 40 43 43 60 73 93 70 93 8C 8F 70 9E 53 73 4C 60 C8 48 CF 5F 60
这是 串口 接收的数据,不正确。
ID:360343 发表于 2018-6-27 15:54 | 只看该作者
这是 串口 接收的数据,不正确。
