- THE 1602 CHAR LCD LIB
- File Name: LCD.h
- Modified: NO
- Revision: 1.0
- #ifndef LCD_CHAR_1602_2005_4_9
- #define LCD_CHAR_1602_2005_4_9
- #include <intrins.h>
- //Port Definitions**********************************************************
- sbit LcdRs = P2^0;
- sbit LcdRw = P2^1;
- sbit LcdEn = P2^2;
- sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.数据端口
- //内部等待函数**************************************************************************
- unsigned char LCD_Wait(void)
- LcdRs=0;
- LcdRw=1; _nop_();
- LcdEn=1; _nop_();
- //while(DBPort&0x80);//在用Proteus仿真时,注意用屏蔽此语句,在调用GotoXY()时,会进入死循环,
- //可能在写该控制字时,该模块没有返回写入完备命令,即DBPort&0x80==0x80
- //实际硬件时打开此语句
- LcdEn=0;
- return DBPort;
- //向LCD写入命令或数据************************************************************
- #define LCD_COMMAND 0 // Command
- #define LCD_DATA 1 // Data
- #define LCD_CLEAR_SCREEN 0x01 // 清屏
- #define LCD_HOMING 0x02 // 光标返回原点
- void LCD_Write(bit style, unsigned char input)
- LcdEn=0;
- LcdRs=style;
- LcdRw=0; _nop_();
- DBPort=input; _nop_();//注意顺序
- LcdEn=1; _nop_();//注意顺序
- LcdEn=0; _nop_();
- LCD_Wait();
- //设置显示模式************************************************************
- #define LCD_SHOW 0x04 //显示开
- #define LCD_HIDE 0x00 //显示关
- #define LCD_CURSOR 0x02 //显示光标
- #define LCD_NO_CURSOR 0x00 //无光标
- #define LCD_FLASH 0x01 //光标闪动
- #define LCD_NO_FLASH 0x00 //光标不闪动
- void LCD_SetDisplay(unsigned char DisplayMode)
- LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
- //设置输入模式************************************************************
- #define LCD_AC_UP 0x02
- #define LCD_AC_DOWN 0x00 // default
- #define LCD_MOVE 0x01 // 画面可平移
- #define LCD_NO_MOVE 0x00 //default
- void LCD_SetInput(unsigned char InputMode)
- LCD_Write(LCD_COMMAND, 0x04|InputMode);
- //移动光标或屏幕************************************************************
- #define LCD_SCREEN 0x08
- #define LCD_LEFT 0x00
- #define LCD_RIGHT 0x04
- void LCD_Move(unsigned char object, unsigned char direction)
- if(object==LCD_CURSOR)
- LCD_Write(LCD_COMMAND,0x10|direction);
- if(object==LCD_SCREEN)
- LCD_Write(LCD_COMMAND,0x18|direction);
- //初始化LCD************************************************************
- void LCD_Initial()
- LcdEn=0;
- LCD_Write(LCD_COMMAND,0x38); //8位数据端口,2行显示,5*7点阵
- LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //开启显示, 无光标
- LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏
- LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC递增, 画面不动
- void GotoXY(unsigned char x, unsigned char y)
- if(y==0)
- LCD_Write(LCD_COMMAND,0x80|x);
- if(y==1)
- LCD_Write(LCD_COMMAND,0x80|(x-0x40));
- void Print(unsigned char *str)
- while(*str!='\0')
- LCD_Write(LCD_DATA,*str);
- str++;
- void LCD_LoadChar(unsigned char user[8], unsigned char place)
- unsigned char i;
- LCD_Write(LCD_COMMAND,0x40|(place*8));
- for(i=0; i<8; i++)
- LCD_Write(LCD_DATA,user[i]);
- #endif
复制代码 |
