查看: 4071|回复: 0
PMSA003 PM2.5传感器数据读取的python源程序与资料
ID:366196 发表于 2018-7-6 11:32 | 显示全部楼层 |阅读模式
PMSA003读取源程序
PM2.5/PM1.0/PM10 感應器
  • 可設定待機/正常模式
  • 輸出PM2.5/PM1.0/PM10量測數值
  • 與PMS-7003通用
python源码:
  1. import serial
  2. import time
  3. import sys
  4. import json
  5. import datetime
  6. import binascii
  7. class pmsA003():
  8.     def __init__(self, dev):
  9.         self.serial = serial.Serial(dev, baudrate=9600, timeout=3)
  10.     def __exit__(self, exc_type, exc_value, traceback):
  11.         self.serial.close()
  12.     def setIdel(self):
  13.         idelcmd = b'\x42\x4d\xe4\x00\x00\x01\x73'
  14.         ary = bytearray(idelcmd)
  15.         self.serial.write(ary)
  16.     def setNormal(self):
  17.         normalcmd = b'\x42\x4d\xe4\x00\x01\x01\x74'
  18.         ary = bytearray(normalcmd)
  19.         self.serial.write(ary)
  20.     def vertify_data(self):
  21.         if not self.data:
  22.             return False
  23.         return True
  24.     def read_data(self):
  25.         while True:
  26.             b = self.serial.read(1)
  27.             if b == b'\x42':
  28.                 data = self.serial.read(31)
  29.                 if data[0] == b'\x4d':
  30.                     self.data = bytearray(b'\x42' + data)
  31.                     if self.vertify_data():
  32.                         return self._PMdata()
  33.     def _PMdata(self):
  34.         d = {}
  35.         d['time'] = datetime.datetime.now()
  36.         d['apm25'] = self.data[6] * 256 + self.data[7]
  37.         d['apm10'] = self.data[4] * 256 + self.data[5]
  38.         d['apm100'] = self.data[8] * 256 + self.data[9]
  39.         return d
  40. if __name__ == '__main__':
  41.     print "starting..."
  42.     con = pmsA003('/dev/ttyAMA0')
  43.     d = con.read_data()
  44.     print(d)
全部资料51hei下载地址:
pmsA003.rar (593.06 KB, 下载次数: 22)
